![]() Join Date: Mar 2010
1965 Suburban or Short Truck chassis with powertrain
Chassis was great condition when I bought it no rust or damage Chassis was sandblasted and painted with POR 15 1986 C10 front suspension installed ( bolt it ) New CPP drop springs and drop spindles all new bearings All new front end parts:ball joints, energy suspension bushings, tie rods pitman arm , idler arm All new brake lines throughout right to master cylinder Matched master cylinder included!! 12 inch slotted front rotors with SSBC calipers 13 inch rear drums all new stuff Moser axels in late model 10 bolt posi rear end. 3:42 posi differential Power steering box refreshed large front sway bar unique rear sway bar new gas tank 31 gallons fuel lines with new filter/regulator combo Rear static fill air bags New trailing arm urethane bushings New Ride Tech rear shocks New Bell tech front shocks Fresh LS1 short block with NEW LS6 heads ( not rebuilt NEW) LS6 camshaft and LS6 intake, coil packs, wires, fuel rails and injectors Corvette balancer and driver side brackets Corvette hydraulic motor mounts Low mileage 4L65E trans with fresh convertor Complete dual exhaust 2 1/2 to back with Hemi turbo mufflers New urethane cab mounts included Chassis is ready for you body and ready to go This chassis will also fit Short Bed trucks!!! ( cut 4 inches off rear frame rails) All work was done 700 miles ago!!! asking 9999.00 NEW LOWERED PRICE 7999.99!!!!!!!!! Pictures coming soon SOLD SOLD SOLD Chassis with be at Turkey Rod run Daytona Beach in two weeks. Chassis has wheels and tires on it for transport call Scott 386 366 4244 or PM me here on forum This picture gives you an idea of ride height and stance.
65 burb On the road Mar 26th Finally Last edited by lucifer; 12-08-2015 at 08:30 PM. Reason: added info |
Re: 1965 Suburban chassis with LS6 eng trans
65 burb On the road Mar 26th Finally |
nice set up can I ask if you made ur tank or was it sourced from a vendor ? thx for ur time Hop
Save a tree support your local drag strip !!! |
#5 | |
eBay item number: 371093866486
Moderator
![]() ![]() Join Date: Aug 2011
Nice tank, think that'd fit in a 64 C10?
You may have to relocate a crossmember to fit it.
Price drop to 9000.00
This chassis with be at the Daytona Turkey Rod swap meet! Please call me if interested. I have a tow dolly so you can drive away with the chassis!!! scott 386 366 4244
Mahalo !!!!!
man super thx they have them for 89.95 free shipping on ebay what a deal FYI for anyone looking for big tank. ,,,and doesn't mind no spare tire provision
Glad I could help!!
Chassis still available Buy it at the Turkey Rod swap meet
![]() price drop now only 7999.00 at turkey rod swap meet row 94 spot 2060
TTT
Ok I will separate the engine and trans from the chassis Chassis no engine trans offered for 3800.00
TTT weekend deal
#15 |
Hello I have a 65 and need the rear cargo door latch assembly for the right side. If you have it I'm highly interested thanks.
