Old 03-12-2016, 02:53 AM   #226
swamp rat
swamp rat's Avatar
Re: 67 long box
What did you do to prep the inner fenders for the satin black? just sand or sand blast? I may have missed it.
Great work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-12-2016, 03:02 AM   #227
swamp rat
swamp rat's Avatar
Re: 67 long box
This stuff for the fender wells??
http://www.goodspeedmotoring.com/wur...ard-spray.html
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-12-2016, 09:52 AM   #228
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Originally Posted by swamp rat View Post
Thanks the new inner fenders were just sanded and sprayed . I had to cover a few spots with primmer on bare metal before painting it with chassis saver black to seal, then a paintable rubberized rocker guard, sanded between paint and stone guard so it stays on. Same as the stuff you posted. Don't use the asphalt spray undercoating as it's not paintable and doesn't dry. The outer fenders inners are painted with auto paint.
Metaldoc is offline   Reply With Quote
Old 03-13-2016, 01:58 PM   #229
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Power lock actuators put in.
Old 03-13-2016, 02:14 PM   #230
cleanfreak
cleanfreak's Avatar
Re: 67 long box
You know we're going to ask what those were out of , fit like they were made for 67-72! Thanks for the great picture too.
cleanfreak is offline   Reply With Quote
Old 03-13-2016, 03:07 PM   #231
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I wish I knew, I bought them at a swap meet for 5 bucks and they fit perfect. I drilled the two mount holes and the bar had the holes in the to slip over the top lock bar. It was total luck they fit like this. I would say they came from mid 80's gm car.
Old 03-13-2016, 07:19 PM   #232
notchbackgta
Re: 67 long box
I was going to ask what the rod came from, but that actuator is from basically 80's GM vehicle, as you already said. Now I see I won't have to do much fiddling to make the locks work, I just need to find the connector for the actuators and I am in business
notchbackgta is offline   Reply With Quote
Old 03-14-2016, 07:05 PM   #233
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I started grinding out the chips and surface rust, now I've got to paint the spots I touched up, which is the whole inside panel on both. So out with the glass, trim, and latch.
Old 03-16-2016, 01:44 AM   #234
Metaldoc
Metaldoc's Avatar
Re: 67 long box
The doors turned out great.
Old 03-18-2016, 05:35 PM   #235
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Re: 67 long box
Glad I had the awesome opportunity to meet the Metaldoc in person. Great to see your work first hand. What a great guy! Love your vision for the truck. I'm anticipating the the final product. Thanks again for the great ideas, dome light and the CST emblems.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 03-19-2016, 04:07 AM   #236
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Excellent visit, glad you could use the parts. It's nice to see there is passion in all ages to build not only trucks but all makes of rides. I just talked to my buddy that's 17 and renewing a 68 and is looking for stuff as well. Thanks Cunuckvetter and the same back at ya. I will be driving this soon, fingers crossed.
Derek
Old 03-20-2016, 09:54 PM   #237
88Stanger
88Stanger's Avatar
Re: 67 long box
nice build, im doing the wiring thing also, what a long process!!!!
88Stanger is offline   Reply With Quote
Old 03-21-2016, 03:27 AM   #238
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Wiring is not an easy process and is a pita. I made a list of options I wanted then added each circuit, crossed it off the list and carried on. I tried to break up the time and do other stuff at the same time. Nothing is impossible.
Thanks Derek
Old 03-21-2016, 08:56 AM   #239
Bomp
Bomp's Avatar
Re: 67 long box
Doors are looking great. Will be adding door locks to the list for my build.
Bomp is offline   Reply With Quote
Old 03-27-2016, 06:30 PM   #240
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Got the rad saddle cleared to keep all the black parts the same color of satin black. Blasted and painted most of the fenders hardware, I know I'll find more. 5 gal stir sticks work great for the bolts Easy to hold for blasting and painting.
Old 04-03-2016, 12:21 PM   #241
Metaldoc
Metaldoc's Avatar
Re: 67 long box
repaired the dash pad and recovered it. Looks brand new.
Old 04-03-2016, 12:25 PM   #242
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Repainted the black in the trim to make it noticeable . Dash pad in
Old 04-03-2016, 07:42 PM   #243
Advanced Design
Advanced Design's Avatar
Re: 67 long box
Nice repair on the dash pad!
Advanced Design is offline   Reply With Quote
Old 04-03-2016, 09:17 PM   #244
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks it turned out real nice , on the first try and a first time for me. I'm too cheap to pay people to do this or to buy it.
Old 04-05-2016, 10:08 PM   #245
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Plumbing for A/C and condenser all in. Headlight buckets in with new adjust mounting screws.
Old 04-06-2016, 11:07 PM   #246
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I just found out all my masking paper in the pics, the red colored stuff, is meat packing paper. Stuff works great and I got the roll at a garage sale for 2 bucks and still have half left.
Old 04-07-2016, 10:38 PM   #247
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Fenders ready to hang. Needle painted with nail polish in the emblems. This color looks perfect and has a bit of pearl in it to look transparent. Redid the black strip in the trim. It's the little things.
Old 04-08-2016, 12:34 AM   #248
downbytheriver
downbytheriver's Avatar
Re: 67 long box
Haha gotta love the ironic choice in nail polish name.
Sometimes cracking one of these trucks open feels like exactly that.
68 SWB 5.3 turbo build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=578220
downbytheriver is offline   Reply With Quote
Old 04-08-2016, 09:57 AM   #249
Metaldoc
Metaldoc's Avatar
Re: 67 long box
This whole build has been a challenge, But fun, I'm close to 1000 hours under in now and not done yet. I just wanted to get it pass a safety to full on resto. Every piece I took off needed something done to it. Russian roulette yup should I replace it, paint it, cover it, leave it, blast it, nos piece, repop piece or should I make it. I do have to say that color has the right red to orange hue looks factory coated.
Old 04-10-2016, 03:21 PM   #250
Metaldoc
Metaldoc's Avatar
Re: 67 long box
It is looking purdy. Had to check seat to shifter to dash clearance so I had to toss the dash in and wheel on. It felt good sitting in there.
