03-08-2016, 07:33 AM | #26 |
Re: Zippys 50'
After blasting we started on installing a new cab floor.
Thanks to DWSR for documenting this process and answering some questions before we started it. I even bought the tool you recommended it was a huge help. We cleaned the rust and used rust encapsulator on the hidden areas before the new parts went in. Last edited by Iplumb; 03-08-2016 at 07:35 AM. Reason: auto corrected dwsr |
03-10-2016, 07:05 AM | #27 |
Re: Zippys 50'
We kept working on cab repairs.
Drivers side cab corner inner and outer Jacob also filled all the fire wall holes we did not need |
03-10-2016, 07:07 AM | #28 |
Re: Zippys 50'
Passenger Cab Corner
03-10-2016, 08:02 PM | #29 |
Re: Zippys 50'
Nice work...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-10-2016, 09:14 PM | #30 |
Re: Zippys 50'
Iplumb, great father son project. It is going to be a great truck when finished. Keep up the great work.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
03-11-2016, 07:15 AM | #31 |
Re: Zippys 50'
Shannon and Jim,
Thank you! Mike |
03-11-2016, 12:09 PM | #32 |
Re: Zippys 50'
Iplumb
Wow...another AD style truck in upstate NY..I am on the eastern side of the state about 20 minutes North of Albany NY... Looks like a cool project....love to see a family working together on something like this....(I work alone on mine...) Love seeing a younger person working on something besides always fiddling with those cell phones... looks like you guys will have this done in record time...keep up the awesome work... MikeC |
03-11-2016, 09:41 PM | #33 |
Re: Zippys 50'
Thanks MikeC!
Very happy to be having the time with Jake. Wish it was record time though - lost 2 1/2 yrs in so far Mike |
03-11-2016, 11:18 PM | #34 |
Re: Zippys 50'
looks like you are moving right along.
you'll probably be done before I am. if you get done by October, there is a nice fall show at Peak n Peak. Come on down.
53 Chevy Pickup |
03-12-2016, 04:48 AM | #35 |
Re: Zippys 50'
Donandal - If all goes to plan it will be done. It would be a fun trip down, I see you are not far away.
More cab repair pics |
03-12-2016, 06:40 AM | #36 |
Re: Zippys 50'
typical rust for these trucks,
on my 53, the brace for the hinges that sits inside the lower hinge pocket was badly rusted, and provided no support for the hinge where it registers on the tab, so I replaced that also. your repairs look nice!
53 Chevy Pickup |
03-14-2016, 06:22 PM | #37 |
Re: Zippys 50'
The original bed and rear fenders needed a lot of love to get them in shape.
We also want to run wider tires in the rear so we ordered mini tubs. Purchased a new bed and rear fenders. We had to set it on the frame to see what it looked like. |
03-15-2016, 04:17 PM | #38 |
Re: Zippys 50'
It Runs!
We mounted up the motor and transmission. It was very very cool to get it started. Still way more to do - This was before we got the shroud and electric fan on it. |
03-15-2016, 07:47 PM | #39 |
Re: Zippys 50'
Congratulations on the first start! The rear inner fenders look really good and I've never seen them before. Where did they come from?
Dwcsr has great knowledge, so I am curious on what tool he suggested that you mentioned in post 26. Figure I can learn something. Thanks Iplumb. |
03-15-2016, 08:18 PM | #40 |
Re: Zippys 50'
Ditto to what AD asked..whered the mini tubs come from..those look clean.
03-16-2016, 06:39 AM | #41 |
Re: Zippys 50'
Thank you guys
The Mini Tubs are from Dan Carpenters. Great info on installing them as well. The tool Dwcsr recommended is a Steck seem buster part # 20015. I also bought the angled one. Very well worth the price of admission in my book. Mike |
03-17-2016, 08:07 AM | #42 |
Re: Zippys 50'
Man looks great! everything about it is killer. The thing about that sbc is you know whats in there and how it went together. I bet more care went into that than any create motor.
Jeff
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
03-17-2016, 08:14 AM | #43 | |
Re: Zippys 50'
There is one of the benefits of following builds here...learning from each other. Thanks again! |
03-17-2016, 03:46 PM | #44 |
Re: Zippys 50'
Doug - you are very welcome. I agree on the learning from each other. There is no way I could have figured out all this stuff on my own!
Thanks Jeff! |
03-17-2016, 04:16 PM | #45 |
Re: Zippys 50'
Very cool build.
I know what you mean about the sheetmetal work - I thought I was just ridiculously slow but it seems like everyone's progress slows way down at that point. You just have to trudge on. What ya'll have done so far looks awesome. Glad you got the engine fired! That always provides a lot of motivation to get more stuff done. Just keep the updates rolling in - seeing other's progress provides inspiration and ideas for everyone.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and 47RH AOD transmission http://67-72chevytrucks.com/vboard/s...d.php?t=640042 |
03-18-2016, 06:40 AM | #46 |
Re: Zippys 50'
Thank you II Slow
We installed a three point seat belt set from Julianos. Also patched up the dash and fit the new ignition switch, wiper switch and light switch. Turned the cab up on its front and final welded the bottom with it off the dolly. Next step - re mount it to the frame and complete my 56 item checklist of items to do before the cab goes to paint. |
03-23-2016, 04:43 PM | #47 |
Re: Zippys 50'
Almost ready to get the cab to the painter...
Re set the cab on the chassis to final fabricate everything pre paint to be in a "no holes after paint" mode. |
03-24-2016, 10:58 AM | #48 |
Re: Zippys 50'
wow...you guys are fast. He'll be driving this summer! keep it up!
03-24-2016, 03:50 PM | #49 |
Re: Zippys 50'
Thanks iowaboy
Its been a journey but we are closer to the end... |
04-03-2016, 08:39 AM | #50 |
Re: Zippys 50'
Jacob and I finished fitting all of the in cab items and controls.
Some final welds and off the painter it goes. A little rant... Why is it that nothing ever just fits? We buy (and pay for it) it to fit - but there is always "some assembly required". IE it does NOT just fit - or the instructions are written by someone with a crayon and no practical sense of order or direction. The exception I would say in my experience has been Lokar - they should be the goal other manufacturers shoot for. End Rant. Mike |
