Old 03-16-2016, 03:19 AM   #1
Tobraylor
67' k20 tire size dilemma
Getting ready for new tires on the k20. Wondering if any one has pics or suggestions for a tire size that will fit with no lift.
Tobraylor is offline   Reply With Quote
Old 03-16-2016, 08:59 AM   #2
FlameOut
Re: 67' k20 tire size dilemma
I'm running 33 / 12.5R15's with no problem on a stock height 72 K10. Plenty of room for a bigger tire
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 03-16-2016, 02:40 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
What size wheels do you have?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 03-16-2016, 11:04 PM   #4
Tobraylor
I'm running the stock 16" steel wheels
Old 03-16-2016, 11:19 PM   #5
72MARIO
72MARIO's Avatar
265 75 16 are about the biggest I have found fit with out rubbing
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-16-2016, 11:49 PM   #6
allchevy58
allchevy58's Avatar
Have 265/75R16 with 8X16 wheels on my 72, 285/75R16 rubbed when turning.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 03-17-2016, 04:17 AM   #7
Tobraylor
Thanks guys. I'm new to this forum thing and am really appreciating the fast feed back. I am considering a lift kit now to clear a little bigger tire. But if I don't thanks for the help.
Old 03-17-2016, 10:58 AM   #8
CanadianK10
Active Member
CanadianK10's Avatar
These are 32x11.5 R15 BF Goodrich K02's I'm going to run on my 67 K10 this year, the rims stick out a bit affording me some clearance on the inside. I haven't had them on the road yet but they look to clear much better than my old wheels. The K10 has no lift on it.
I had these on before, theyre 265/75 R16's and they would rub on my pitman arm at full right lock. I believe this summit link is what the K10 had on it, the previous owner installed them so I'm not 100% sure on that. The have a 5 inch back spacing while the mags above are only 3 to 4 inch buying me some room to run wider tires.
http://www.summitracing.com/int/part...60pl/overview/
Hope that helps
Adam
1967 K10 292, SM65 Transmission & NP205 Transfer Case
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=605048
CanadianK10 is offline   Reply With Quote
Old 03-17-2016, 04:02 PM   #9
Sicklajoie
The Niner
Sicklajoie's Avatar
Hope that helps
Adam
WOW what a beautiful truck!!
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
k20
