Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 03-18-2016, 10:10 AM   #51
mingoman
Re: 1996 GMC K3500 DRW, Extended Cab, Flatbed, 454, NV-4500
Originally Posted by 83GMCK2500 View Post
Yup, friends and I had 3-4 kicking around, it came from one of those two. All I did was swap my odo into it, add the LEDs, and paint over PRND321 & Apply Brake to Shift from Park.
Just about every other day is a fill-up and ~250 miles on the trip.
Love the led look! Was it all that hard to change out?
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 11-16-2016, 04:20 PM   #52
Aruba1
Hey, that is an amazing truck that you got there. I got the same NV4500 transmission in my 1972 GMC C30 but nobody on this forum (nor Google himself :-() was able to tell me what PTO will work on the 1996 NV4500. Is there any way you can check the PTO part number on your truck? Please :-)
Aruba1 is offline   Reply With Quote
Old 11-16-2016, 04:39 PM   #53
83GMCK2500
Thank you. I just used this and found a few. https://www.chelseaptoapps.com/Home/Configuration Go there, click North America, choose New Venture and which version of the 4500 you have, it'll list a few.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 11-16-2016, 08:28 PM   #54
Wide Open
Prior to the accident, I accomplished one of the tasks I've had on the back burner. BRAKE UPGRADE! Anyone watch that Alaska Off-Road Warriors show? The lower 48 team? I've had the pleasure of talking with both of them on multiple occasions. Carl owns/runs Jantz Engineering near where I used to live & work, I had him machine the upper and lower ball joint tapers in a set of GMT-800 knuckles for me to the correct diameter for the -400 ball joints. During the brake upgrade I installed new upper and lower ball joints, lower control arm bushings, sway bar bushings, and sway bar end links.
Good-bye...
Hello
Coming together
So much bigger
What size rotors did you end up with?
Aren't the stock GMT 400's ones around 12"?
Wide Open is offline   Reply With Quote
Old 11-17-2016, 01:47 AM   #55
83GMCK2500
Stock front rotor on a DRW truck is GM: 12549137, AC Delco: #177-804
What I put on was the rotor that came with those suspension parts off of a 2000 K2500 (GMT-800) and it is GM: 15942195, AC Delco: #177-1038
Stock: 12.5 in x 1.535 in
Current: 12.795 in x 1.5 in
When I need to replace the front brakes I will likely move to the GMT-800 DRW front rotors, P/N's: 15733625/#177-878 which are the exact same dimensions as current. Where they differ is in the thickness of the wear surface, the DRW ones are much thicker. Visually the region of the rotor where the vanes are is half as wide.
Devin
New Daily, the '96
Old 03-02-2017, 04:29 PM   #56
95 S_Trucker
95 S_Trucker's Avatar
I am curious how the tie rod was adapted. I am gathering parts to do this on my 99. The GMT800 uses a smaller tie rod taper than the GMT400. Did you get a different outer tie rod or use an adapter?
95 S_Trucker is offline   Reply With Quote
Old 03-03-2017, 07:21 AM   #57
95 S_Trucker
Thanks for the PM. I gonna post this for reference. 99-00 GMT800 knuckles have a different tie rod taper than 01-07. It is very hard to locate a set of used 99-00 knuckles, and they are superseded to the later ones by gm. I already have a set of 01-07 knuckles.
I will most likely have a GMT400 outer tie rod shortened and machined to M14, and use a standard 01-07 outer tie rod.
When I do this, I will post a build thread and parts used.
Old 10-12-2017, 10:42 AM   #58
74CustomK20
74CustomK20's Avatar
Just found this looking for cab swap ideas. I have a 98 k2500 and my only thing I'd the wiring. The 98 is a 6.5 TD and my parts 97 k1500 is a 5.7L. how did you go about the wiring?
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 10-12-2017, 12:07 PM   #59
83GMCK2500
Swapped all of my wiring into the donor cab. Pulled both dashes, set them on sawhorses, removed the ducting and parts I needed to give me access to the harness and swapped them.
Devin
New Daily, the '96
Old 10-13-2017, 10:50 PM   #60
74CustomK20
Awesome. So it separates then under the dash somewhere? I'm familiar with the 73-87 wiring just not anything this new.
Big Nate
