Old 03-17-2016, 05:37 PM   #1301
swampbog
swampbog's Avatar
Re: 1976 Square "Simple Green"
swampbog is offline   Reply With Quote
Old 03-17-2016, 05:39 PM   #1302
RodsGreen10
RodsGreen10's Avatar
Originally Posted by swampbog View Post
Thanks Swamp. It is above and beyond what I had even imagined really.
I will get a video and post it up. It is all brand new every bit of it. All mandrel bent and all TIG welded!! Complete 3" from front to back no neck downs. All custom!
RodsGreen10 is offline   Reply With Quote
Old 03-18-2016, 08:25 AM   #1303
RodsGreen10
Exhaust wrap wrap next and ready to roll out. Had to remove the stock shift rod for the exhaust so I could tuck it up high. But Lokar had the solution. You can see it in this pic here.
Old 03-18-2016, 02:34 PM   #1304
77BBGMC
77BBGMC's Avatar
Exhaust looks nice! You can't beat mandrel bent, I wish somebody in my area would've had the equipment when I had mine done. Waiting for the video...
77BBGMC is offline   Reply With Quote
Old 03-18-2016, 03:55 PM   #1305
RodsGreen10
Thanks man. Actually that is 3 universal kits total $310. 1 X pipe kit and 2 truck over the axle kit. Then I had to buy a few odd bends. It is all mandrel and put together then all TIG welded up. 3" from front to back.
THe X pipe is a universal from Jegs which is Dynomax I believe.
The 2 over the axle kits are FlowMaster universal kits for trucks.
You and everyone else can have the same thing. I just dig deep and look and plan and get lucky when it all works haha.
Old 03-18-2016, 05:00 PM   #1306
funkatation
Not to dump my issues on your thread, but I'm having start issues myself with the Fitech! It's different than yours I think, it takes three or four times to start and then it runs fine. Drove my truck home finally and it did great for 200 miles. Doesn't seem to matter if it's cold or hot. I put their fuel command center in hoping it would be easier but I don't know that it's all that great.
funkatation is offline   Reply With Quote
Old 03-19-2016, 01:47 AM   #1307
funkatation
Been on the phone with them tweaking and tweaking and still no luck.
Old 03-19-2016, 06:47 AM   #1308
RodsGreen10
Man thAt really sucks ass man. I know the feeling. Hope you get it straightened out.
Old 03-19-2016, 10:29 AM   #1309
funkatation
What distributor did you go with again? I've got the billet one from GM that looks like it was built by MSD with the heat module and they are junk.
Old 03-19-2016, 10:47 AM   #1310
RodsGreen10
Do you use vacuum advance? Need to know so I can show you which distributor you need. I do not use vacuum advance. So the part numbers will be different.
Old 03-19-2016, 10:50 AM   #1311
funkatation
I'm getting conflicting advice on it, but currently no.
Old 03-19-2016, 10:53 AM   #1312
RodsGreen10
No vacuum advance. Race HEI III.
Pertronix D71070 black cap. This is the one I run and love it!!
Pertronix D71071 red cap. Same but with red cap.
Old 03-19-2016, 02:22 PM   #1313
ray1970
Ray here.
Funkatation if you get it solved dont keep it a secret.
Mine runs great......Starting when warm not so good......
Ray.
ray1970 is offline   Reply With Quote
Old 03-19-2016, 02:29 PM   #1314
RodsGreen10
New rotors showed up today. This is the closest I could find that will match the Wiwood rotors when I do the rear conversion kit.
Old 03-19-2016, 10:03 PM   #1315
funkatation
So I've tried three modules on my HEI, and I can't get a consistent rpm during cranking. Most of the time it shows 0, gets enough spark to start and I see 500+. This is usually on the third try. Anyone have any ideas? Fitech says rpm during cranking is a must.
Old 03-19-2016, 10:22 PM   #1316
RodsGreen10
So you have tried 3 HEI modules and still no dice. Could it be that the FiTech has taken a **** lol. Check your coil also. Needs to be a thread about FiTech issues.
Old 03-19-2016, 10:32 PM   #1317
funkatation
Might have to! I've had 3 of these GM Performance Pro Billet Distributors. They come with the MSD Heat modules, and my truck does not like them! I've tried a cheap chinese module that came in a $40 distributor, and a Pertronix module yesterday. It eventually fires up and runs fine, I drove it for 200 miles and it was fine. Just getting the darn thing started!
Old 03-20-2016, 10:30 PM   #1318
funkatation
Can't wAit to hear your exhaust. Is it loud? My truck has flow masters and it's a bit much for me.
Old 03-21-2016, 06:59 AM   #1319
RodsGreen10
Sound and being loud is subjective. It sounds damn good IMO. I do not like blowmasters they have a tin sound IMO. I like my Borlas. And I will get a video they have a break in period on them they will sound different now than they will after about 250-500 miles. They keep getting deeper.
Old 03-21-2016, 06:42 PM   #1320
RodsGreen10
New exhaust videos coming tomorrow. If I have time to post them tomorrow haha!!
Old 03-22-2016, 09:54 PM   #1321
RodsGreen10
Ok took a short little crappy video after I picked up my truck. Only has 5 miles on the exhaust. I will get a better video tomorrow.
https://m.youtube.com/watch?v=gpL-eb...ature=youtu.be
Old 03-22-2016, 09:59 PM   #1322
RodsGreen10
Can't see the exhaust it is tucked up perfect only thing you can see is the frame.
Old 03-23-2016, 05:44 AM   #1323
RodsGreen10
Love LED headlights!! Nice being able to see in the morning!!
Old 03-24-2016, 06:23 PM   #1324
RodsGreen10
Got one side finished today. The Wilwood calipers look great.
Old 03-24-2016, 06:23 PM   #1325
RodsGreen10
A little closer view.
