Old 03-19-2016, 07:09 PM   #1
65standard
65standard's Avatar
Return vs. return less fuel rail
My 6.0 has the old style fuel rail with the return line. Is it better to use the returnless fuel rail and corvette filter/regulator or my original setup. I have access to the later style if needed.
I just finished up my frame and I ready to start my LSx swap.
I got my new spectra GM11C gas tank and it doesn't have the baffle. It is the same as my original tank (GM11B). So I'm a lilttle bummed out.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 03-19-2016, 07:36 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Return vs. return less fuel rail
I capped my return line on the fuel rail of my 6.0 and am running the vette filter/reg..no issues and works great.
Old 03-19-2016, 07:51 PM   #3
65standard
65standard's Avatar
What did you do with the vacuum diaphragm and vacuum line?
Old 03-19-2016, 08:53 PM   #4
Robznob11
Robznob11's Avatar
If it's in place go return. Less wear on pump bullheading less heating the fuel. Better down the road if you want more hp. All big fuel systems use a return.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 03-19-2016, 09:04 PM   #5
foamypirate
foamypirate's Avatar
It was probably boxed incorrectly. The GM11C and GM1C should definitely have baffles in them. I would return and ask for a new one.
Here are mine that I recently ordered, showing the baffle.
foamypirate is offline   Reply With Quote
Old 03-19-2016, 09:38 PM   #6
65standard
65standard's Avatar
Originally Posted by foamypirate View Post
It was probably boxed incorrectly. The GM11C and GM1C should definitely have baffles in them. I would return and ask for a new one....
That is what I was thinking too. The new tank isn't stamped with the part number like my GM11B tank is. It only gas a small sticker on it with GM11A on it. Have no idea what GM11A tank is for.
Old 03-19-2016, 09:44 PM   #7
65standard
65standard's Avatar
It would be easier just to stay with the return system I have and just use a fuel filter designed for it.
Old 03-19-2016, 09:47 PM   #8
Robznob11
Robznob11's Avatar
And better for the system,parts and performance
LED TAILS
Old 03-19-2016, 10:16 PM   #9
foamypirate
I looked it up, it's an 80' and earlier Squarebody tank, looks to have a smaller filler neck.
Old 03-20-2016, 12:02 AM   #10
ls1nova71
ls1nova71's Avatar
I would use the return if you have it. A $10 fuel filter is way better when it comes time to change it than a $60 filter that can have a bad regulator straight out of the box. Also vacuum referenced fuel pressure versus a set pressure, so you have to tune for it. I'll never understand peoples infatuation with the returnless rail.....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-20-2016, 10:36 AM   #11
Hart_Rod
Hart_Rod's Avatar
It's easy..............................................!
Hart_Rod is offline   Reply With Quote
Old 03-20-2016, 01:58 PM   #12
foamypirate
I used it because that's how my LQ9 came. $60 is way too much to pay for the filter, I got mine for $30, WIX brand.
Old 03-23-2016, 05:21 PM   #13
65standard
65standard's Avatar
For the record, my replacement GM11C gas tank came in today. This one has the pan inside the tank and the correct 1 5/8" filler neck.
Old 03-23-2016, 06:56 PM   #14
foamypirate
Right on!
