03-19-2016, 07:09 PM | #1 |
Return vs. return less fuel rail
My 6.0 has the old style fuel rail with the return line. Is it better to use the returnless fuel rail and corvette filter/regulator or my original setup. I have access to the later style if needed.
I just finished up my frame and I ready to start my LSx swap. I got my new spectra GM11C gas tank and it doesn't have the baffle. It is the same as my original tank (GM11B). So I'm a lilttle bummed out.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
03-19-2016, 07:36 PM | #2 |
Re: Return vs. return less fuel rail
I capped my return line on the fuel rail of my 6.0 and am running the vette filter/reg..no issues and works great.
03-19-2016, 07:51 PM | #3 |
What did you do with the vacuum diaphragm and vacuum line?
03-19-2016, 08:53 PM | #4 |
If it's in place go return. Less wear on pump bullheading less heating the fuel. Better down the road if you want more hp. All big fuel systems use a return.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
03-19-2016, 09:04 PM | #5 | |
Here are mine that I recently ordered, showing the baffle. |
03-19-2016, 09:38 PM | #6 | |
That is what I was thinking too. The new tank isn't stamped with the part number like my GM11B tank is. It only gas a small sticker on it with GM11A on it. Have no idea what GM11A tank is for.
03-19-2016, 09:44 PM | #7 |
It would be easier just to stay with the return system I have and just use a fuel filter designed for it.
03-19-2016, 09:47 PM | #8 |
And better for the system,parts and performance
03-19-2016, 10:16 PM | #9 |
I looked it up, it's an 80' and earlier Squarebody tank, looks to have a smaller filler neck.
03-20-2016, 12:02 AM | #10 |
I would use the return if you have it. A $10 fuel filter is way better when it comes time to change it than a $60 filter that can have a bad regulator straight out of the box. Also vacuum referenced fuel pressure versus a set pressure, so you have to tune for it. I'll never understand peoples infatuation with the returnless rail.....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-20-2016, 10:36 AM | #11 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-20-2016, 01:58 PM | #12 | |
03-23-2016, 05:21 PM | #13 |
For the record, my replacement GM11C gas tank came in today. This one has the pan inside the tank and the correct 1 5/8" filler neck.
03-23-2016, 06:56 PM | #14 |
