Garage wrench
85 Suburban w/5.3, leaking fuel at tank problem
I just recently completed swapping a 5.3/4L60E from an '05 Avalanche into my '85 Suburban. I am having an issue with fuel leaking and tank pressure. I'm using the stock '05 returnless fuel rail at the engine, an '87 Suburban baffled fuel tank w/vortec fuel pump and a corvette fuel filter/regulator. The issue I am having is a slight fuel leak ontop of the tank. Also, when I went to put gas in today I noticed a LOT of pressure built up in the system behind the fuel cap. First time this has happened. I do not know where I should check first or what it could possibly be. My initial guess is that the tank is not vented properly. When I put things together I just hooked up the pressure and return lines. I didn't do anything with venting the tank or running a vent line from the sender. That may be the problem, I don't know? Any input from fellow LS swappers?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
![]() Join Date: Dec 2012
Re: 85 Suburban w/5.3, leaking fuel at tank problem
This is the only picture I have on my phone of my sender. The small line I will run to vent up high. This vent has the flip over check valve already on the sender housing.
I would think you need a vented cap if you are not running a vent. I have seen some cap off this little vent line and use only a vented cap.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
You either need a vented cap which will not pass a emission test..... Or run the small line off the fuel sending unit to the original charcoal canister not 100% sure how to hook that up to the purge solenoid on top of the intake and have it work properly still trying to figure that out myself.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Garage wrench
Thanks for the input guys! Gives me somewhere to start.
