Old 03-25-2016, 01:00 AM   #1
Ontcalimo
Lokar billet brake Pedal 1967-72 c10 defective ? What do you guys think?
I purchased a Lokar billet Pedal for 1967-72 c10. The pedal was sent directly from the factory. It appears to be missing two bolts and two nuts, but I am not sure if it is suppose to be like this. Is this defective? Would you guys return this item? Have any of you guys bought one like this one? I'm not please with quality as it seems there are two bolts and nuts missing. What do you guys think.
Thanks in advance.
Ontcalimo is offline   Reply With Quote
Old 03-25-2016, 06:42 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Lokar billet brake Pedal 1967-72 c10 defective ? What do you guys think?
I just got mine form Jegs. It came with all 4 screws and nuts. The directions state only using 2 of them. I used all 4.
Go to Lowes and buy 2 more S/S screws & nuts and be done.
I love the look of mine.
Instructions for install.
Step 3: Each Lokar aluminum cover has four
mounting holes. This is to accommodate
several applications. Typically
only two mounting holes are used per
installation. Choose the mounting
holes that will not interfere with the
pedal arm. If using two holes, be certain
that they are diagonal from each
other. We recommend using a 3/16"
transfer punch to accurately mark the
holes. The marks must be centered
in the holes on the Lokar aluminum
cover.
Here is the link to the instructions.
http://www.lokar.com/downloads/pdf-i...h-instruct.pdf
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-25-2016, 10:14 PM   #3
Ontcalimo
Thank you for response. I don't know why they drilled four holes. On was not drilled correctly.
Old 03-26-2016, 06:36 AM   #4
Andy4639
Old member
Andy4639's Avatar
I ordered the e brake one also to add. I'll have the whole look once it arrives. I like that brake pedal cover. It looks like a factory disc brake pedal now. that old pedal has looked out of place ever since I went to a automatic.
Old 03-27-2016, 11:14 AM   #5
Ontcalimo
I think I am going to buy the hand brake pedal too.
Old 03-27-2016, 02:54 PM   #6
Lattimer
Lattimer's Avatar
I bought the covers for my stock pedals so they would match when I installed the Lokar gas pedal. The instructions said to only use 2 bolts kitty-corner to each other. I would guess their complete pedals only use the 2 as well.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
