Old 03-27-2016, 12:53 PM   #1
davepl
davepl's Avatar
Will a 4L80E require shortening a driveshaft?
Anyone happen to know if there's enough room in the driveshafts and carrier bearing to take up the additional length of the 4L80E or will I wind up shortening a driveshaft?
I have the two-piece shaft, it's replacing the TH400. I can speculate as well as the next guy, just curious if anyone's done it before.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-27-2016, 03:11 PM   #2
67 chevelle
67 chevelle's Avatar
Re: Will a 4L80E require shortening a driveshaft?
yes
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 03-27-2016, 03:38 PM   #3
Thanos
Thanos's Avatar
Going with the 4l80e has a longer tail shaft and slightly longer body. I was told I could go with a 1 piece shaft when I do the swap and get rid of the old drive line and bearing.
Thanos is offline   Reply With Quote
Old 03-27-2016, 04:06 PM   #4
John H.
John H.'s Avatar
Dave, I have a 4x4 LWB one piece drive line you can use to shorten if you go that way.
John H. is offline   Reply With Quote
Old 03-27-2016, 04:25 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Will a 4L80E require shortening a driveshaft?
I had mine shortened for the 2 wheel drive LWB truck. Ended up having them put in a 1 piece due to their screw up. They cut the 2 peice to short.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-27-2016, 05:03 PM   #6
davepl
davepl's Avatar
Hmmm... mine's a Longhorn, so it's (wait for it) longer. I wonder if I could still get away with a one-piece?
Why did they use a two-piece anyway? Harmonics, or ground clearance, or what was the impetus I wonder?
Old 03-27-2016, 05:51 PM   #7
67 chevelle
being a longhorn , Id keep the 2 piece . one of the reasons [of many] they used the 2 piece design was because of length ,,,shortening your shaft is easy for a "competent" drive line shop
Old 03-27-2016, 06:07 PM   #8
Andy4639
Old member
Andy4639's Avatar
Talking Re: Will a 4L80E require shortening a driveshaft?
My LWB truck came with it. I had the one in the truck with the 700-r4 shortened. I bought another one for 20 bucks for a spare. Both where 2 piece shafts. I never had it cut though so when I did the 4l80e swap I had them cut it down. They screwed it up. They cut before they measured it twice! I really don't know what happened only they paid for it.
