#76 |
Words under my name
![]() Join Date: Nov 2010
Re: Fuel filler options
WOW lots of cool ideas!!!! Wish some one thought of this stuff at the dealer while they were installing my saddle tanks on both sides......pretty ugly IMO
69 Chevy CST/10 "Project: Bloody Knuckles" ![]() 2010 VW Golf, daily driver Wrench Rookie |
#77 |
Fuel tank
Hey Hart Rod what gas tank did use for your truck? I love your idea! I will be going to Home Depot and get me two if them. I think I might go this way and do dual 21 gallon 74 truck tanks.
#78 | |
![]() Join Date: Apr 2005
Re: Fuel tank
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#79 |
I really like that, can you give some more details? Like what kind of cap that is, etc?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#80 |
![]() Join Date: Jun 2006
http://67-72chevytrucks.com/vboard/s...=269999&page=4
Check out post 92 for some good pics of mine. I gave my bodyman some pics and details, and this is what he came up with.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
#81 |
#82 | |
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
#83 |
One more...stepside
2006 Crew cab Z71 1972 Short Wide Step (under construction) |
#84 |
Future TOTM Winner
^ That's SHARP! Great idea.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
#85 |
Man of Mini-Talents
Here's one I saw in an ad just today...
![]() The wood panel is motorized, and it can allow access to air pumps etc, too. Link
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#86 |
#87 |
Here is a nice fuel filler install on '66. Saw this one on Ebay Hugger Orange 1966 SWB Fleet
#88 |
Here is a step by step DIY for a side marker light filler on a '68 stepside:
http://67-72chevytrucks.com/vboard/s...699#post599699 |
#89 |
Hi I am wanting to do this very thing any info you could give me I would appreciate it thanks steve
#90 |
Nice Ideas Here
#91 |
#92 |
#93 |
I used a Hagen flat retractable door. Mounted it in the rear inner fender. This picture does not show the door installed. Very clean look, but slow to fill.
John ![]() |
#94 |
Still Learning
#95 |
I've considered all options, but yours seems the simplest. Exactly where on the wheel tub did you put your hole. I've seen low back side and directly center on top.
T KX |
#96 |
![]() Join Date: Jul 2001
Not sure if I posted any pics of this set up elsewhere or not so went up to the shop and took a few of what I have. The fuel fill itself came from a 90s Chevy Lumina. Also had to fab a copper elbow I got from a plumber friend of mine to get the correct turn towards the under bed tank. Used fuel hose for both fill and vent lines. The fill cap is centered on the left driver side wheel well hump at about 12'' up from bed floor.
Fills quick with no burping at all. The hose for the tank vent I routed up over the wheel well hump using strap clamps and existing bolt holes. Did this about 10 years ago or more so and have been very pleased with it. Simple but effective. Hope it helps. ![]()
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 01-16-2019 at 03:30 PM. Reason: Added Pics |
#97 |
Hey I am trying to figure out how you made that hinge work as I like the idea.
How did you attach your hinge to your side marker light? Did you epoxy the hinge to the side marker? And what does your U- bracket that you made attach to? I sure would appreciate any input and thanks. I PMd you also about it. |
#98 | |
