Old 04-13-2016, 03:09 PM   #3576
enaberif
Re: Restoring Rusty
That truck with flow 40s will be a basically weekend cruiser. The drone and noise coming out of it will be so obnoxious
enaberif is offline   Reply With Quote
Old 04-13-2016, 07:28 PM   #3577
rich weyand
rich weyand's Avatar
Re: Restoring Rusty
That's what's on my DD. I like 'em.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 04-13-2016, 09:22 PM   #3578
Gregski
Gregski's Avatar
Re: Restoring Rusty
no time like the present, lets make things green
pic 1 - primered
pic 2 - first coat (I was taught that the first coats purpose / job is to make things tacky, simple as that, so sometimes fellers don't even expect a color change when you lightly coat the first coat) just sayin'
pic 3 - second light coat
pics 4 & 5 - third coat a bit heavier
I think I went four coats on this, light, light, medium, medium, would have gone more but had many more parts to paint and needed the paint for them
Gregski is offline   Reply With Quote
Old 04-13-2016, 09:27 PM   #3579
Gregski
Gregski's Avatar
Re: Restoring Rusty
I shot this top panel at the same time as the core, so it was painted exactly the same way four coats, light, light, medium, medium
Old 04-13-2016, 09:29 PM   #3580
Gregski
Gregski's Avatar
Re: Restoring Rusty
this may be the best pic I have so far of the final painted core and the top panel
the message here is don't touch it, don't mess with it, and by all means DON'T LET THE WIFE RUN THE DRYER (cause it vents right into our organic paint booth, ha ha)
Old 04-13-2016, 09:29 PM   #3581
Gregski
Gregski's Avatar
Re: Restoring Rusty
forgive me, but what's a DD?
Old 04-13-2016, 09:38 PM   #3582
Gregski
Gregski's Avatar
Re: Restoring Rusty
with those two pieces out of the way, we moved on to the doo dadz
Old 04-13-2016, 09:41 PM   #3583
Gregski
Gregski's Avatar
Re: Restoring Rusty
and two more, I'm telling you there was a lot of small bits to this job
Old 04-13-2016, 09:44 PM   #3584
flashed
Re: Restoring Rusty
Looks good ,great color .
flashed is offline   Reply With Quote
Old 04-13-2016, 09:44 PM   #3585
Gregski
Gregski's Avatar
Re: Restoring Rusty
and finally the bottom panel, this piece is the one that actually should be green
I would be lying to you all if I didn't tell you that I was tempted to paint this one black, just to mess wichu all, ha ha
FYI, so this was shot with Singe Stage (no base coat and top coat, just one coat with base and clear mixed together, aka the cheaper alternative) OMNI product, the baby brother of PPG, factory paint code match, good stuff
Old 04-13-2016, 09:48 PM   #3586
Gregski
Gregski's Avatar
Re: Restoring Rusty
so glad that parts all over, and here's my reward... ~ PARTS ~
these are supposed to be the slide in plastic tabs that hold the plastic grill, not an exact match and it bothers me a bit, the originals are oval
if I have to order the other ones it won't halt progress so I'm cool with that
Old 04-13-2016, 09:51 PM   #3587
Gregski
Gregski's Avatar
Re: Restoring Rusty
now this is where the Fun Level spiked to an all time high, the HURST bolt on sitck base arrived, and I couldn't be happier nor more proud of myself for doing this right and I will have a proper genuine HURST shifter to show for it, so happy
Old 04-13-2016, 09:55 PM   #3588
Gregski
Gregski's Avatar
Re: Restoring Rusty
man the timing couldn't have been more perfect, the postman dropped off the Hurst parts as soon as I was done with painting, and although I was tired, I went right for it, had to replace that hockey slip-in base with the proper bolt-on type
here they are side by side with anatomies of both
Old 04-13-2016, 10:00 PM   #3589
Gregski
Gregski's Avatar
Re: Restoring Rusty
then it was time to disassembly the stick itself, clean it properly by soaking the bits in Mineral spirits and cleaning them with a steel wire brush, and put it all back together with white lightning grease, man the action is so smooth on this baby now it's like a hair trigger, jk
love jobs like these, The Greg is so happy!
Old 04-13-2016, 10:07 PM   #3590
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
Like!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 04-13-2016, 10:24 PM   #3591
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
Great work as usual, can't wait to see the blacked-out trim out front of all the new green. About the Hurst shifter - were you kidding about it maybe hitting the dash?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-13-2016, 10:24 PM   #3592
Willowrun
Willowrun's Avatar
Re: Restoring Rusty
I'm impressed with the green paint and the match to the original color. I have done the same (using factory paint code to get color matched paint in a spray bomb) with mixed results. Typically, it seems as if the paint out of the can sprays too porous so my results have varied. Do you mind explaining more about what you are using? Maybe a pic of the spray can? Time between coats?
Old 04-13-2016, 10:27 PM   #3593
Gregski
Gregski's Avatar
Re: Restoring Rusty
we need to rebuild the actual Hurst shifter mechanism, but first let me take you back in time to show you how grimy she was when I bronged her home
so first we pop off the "dust" cover or the inspection plate, call it what you will, it lives below underneath the stick, and it was disgusting
Old 04-13-2016, 10:33 PM   #3594
daddyjeep
daddyjeep's Avatar
Re: Restoring Rusty
I like that you painted the parts that were "supposed" to be black body color. I'm anxious to see it all together.
DD = daily driver by the way.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 04-13-2016, 10:33 PM   #3595
Gregski
Gregski's Avatar
Re: Restoring Rusty
Thank you kindly, me too, can't wait to see it either, but if it don't work out I have something else up my sleeve, stay tuned, it's crazy cool.
honestly no idea, we shall see, the bendyness is way different than the stock stick as you can see
Old 04-13-2016, 10:37 PM   #3596
Gregski
Gregski's Avatar
Re: Restoring Rusty
yes sir, did the same on the inner fenders, and I love how those turned out, it gives the engine more depth, focuses your eyes on the prize, otherwise you pop the hood open and you see a black hole, at least that's what happens in my minds eye, I've always dug the body color engine bays, and there are some super clean ones, but you all know that
Old 04-13-2016, 10:40 PM   #3597
Gregski
Gregski's Avatar
Re: Restoring Rusty
so yeah with that bottom plate popped off here's what we see or I should say can't see in there (you may wanna put your sumich down before scrolling down, ha ha)
I think I already hit it with some WD40 and started the cleaning process
Old 04-13-2016, 10:44 PM   #3598
Gregski
Gregski's Avatar
Re: Restoring Rusty
like I said these are some old pics from the archives, ha ha but I think its worth sharing on how we got here, I am so excited to finally work on this shifter and hopefully soon be enjoying it
Old 04-13-2016, 10:49 PM   #3599
rich weyand
Re: Restoring Rusty
Daily Driver.
Rich Weyand
1978 K10 RCSB DD.
Old 04-13-2016, 10:50 PM   #3600
rich weyand
Re: Restoring Rusty
If your shifter ever starts to feel floppy and rattles, those two bolts have come loose.
Rich Weyand
1978 K10 RCSB DD.
