#176 | |
Re: 1963 GMC C30 panel truck
Got more panels fabed up. Here's the Inner A pillar |
#177 |
And the inner B pillar panel
#178 |
I got both panels welded in and the floor support bolted in. The outer rocker will go on tomorrow along with some paint. More to come
#179 |
Oooooo yeah!!!
![]() ![]() Time for a cold one! |
#180 |
Wow nice job man! You are in the home stretch now
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#181 |
Thanks! Back at work now. Should have some time next week and weekend to get some more done. I have been fixing up the new to me passengers side barn door hopefully get it done this weekend. Pictures to come
#182 |
Here is the passengers side barn door, thanks Perro13!
I got the rusty bottom patched and the whole door wire wheeled and painted. Bondo free!!!! I had to rebuild the latch I picked up off that 62 Suburban in Princton as well as modify the new lock/ push rod to match the length of the original. The latch push rod is shorter and I could not find and repos for the panel/ Suburbans out there. All works like a dream now. I Will be dropping the door off at a glass place this time.... Cracked the pane for the drivers side. Need some fresh rubber anyways. Hahaha. Luckily I got a spare pane from the new door. I have the highs all ready to go and some new hinge seals to go with them. I will be working down island next week so I will have some time in the evenings to get the door mounted, mess around with the drivers side door spacing and the door seals. Thanks for tuning in! |
#183 |
This door is in much better shape then my old one!
Side view. The rebuilt door latch, turned out awesome. |
#184 |
Working down island this week so I got a chance to bring the barn door down with me. I got some "smoke" tinted glass cut for both doors and the seals were salvageable! With a little adjustment I got them working pretty good! Still need to fab up some rubber door stops for the passengers side.
I also have a set of the OEM rear seals coming. Just about got the rear end all wrapped up. |
#185 |
Very pumped !
#186 |
Finally able to put my cowgirl where I want her hahaha
#187 |
It's looking really sharp
#188 |
![]() ![]() Join Date: Jul 2002
#189 |
#190 |
Sure that would be awesome, any updates on the panel?
#191 | |
Finally got the passengers side fender all smoothed out and got some POR on her, jeeze stuff rusts fast here hahaha. Got some time this weekend so hopefully I can get the fender all finished up. |
#192 |
Any recent progress on the panel Anthony?
#193 |
Hey Nik,
Thanks for checking in hahaha. I got the passengers side fender all back together, not super happy with how it turned out, but it's on... Will have to address it later. Went to the junk yard in Port Hardy and picked up a bunch of window seals and started to fit them around the door glass. I got the passengers side seals all done up, I think I looks good and should keep the water and wind out a bit better then the felts. |
#194 |
Another of the fender
#195 |
With the new seals
#196 |
The inside
#197 |
I also got the main door seal put in also. Super nice, I really like the precision seal product. Went in nice
#198 |
Good to hear the door rubber worked out well for you. I hear lots of complaints on the repop seals
#199 |
Do you have any more details on the window seals you used. Close up pictures? What they are out of?
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#200 | |
I will have to get some better close up pics for you next time I'm down to work on the truck. As for the seals, I know some may not want to hear this.... Hahaha they are out of a 2009 Ford. The ripper seamed to fit the window glide profile and had fresh rubber and the inside was felted. I'm not to picky as long as it works. The bottoms are out of a 2000's Chevy van. They have all been modified to fit. It's not perfect, but it actually turned out pretty good hahaha |
