Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-15-2016, 12:35 AM   #1
1955 mancave
1955 mancave's Avatar
my new 64 tonka
well I few months back I picked up this 64 panel, it may not be in the best shape but that's fine !
so when I got it I discovered that the PO cut the front clip off and replaced it with a clip off a Cadillac escalade, not sure about the welding job so I just decided to find another frame and build it up the way I want it, since this is going to be my driver I wanted to make it as nice as I could, so this is what I have done so far.
so I got the frame home and it's like so rusted so I spent a couple of days cleaning, then did the Por-15 thing , swaped out the front cross member to one out of a 82 truck, I have purchased upper and lower tubular control arms and 3 inch dropped spindles and of course all new steering , brakes etc, the plan is 4 wheel disk brakes, I have a nice 350 & 700R4 the 12 bolt that was in the frame turned out to be needing more work than I wanted to do and the fact that its the 17 spline axle .
so I will see if I can post some pictures so you guys can take a look at this project.
1964 1 Ton flatbed service truck (sold)
1964 C-10 panel (project complete frame up build)
1957 210 post pearl orange
1955 mancave is offline   Reply With Quote
Old 04-15-2016, 12:38 AM   #2
1955 mancave
Re: my new 64 tonka
some pictures, I will try to keep them in order.
Old 04-15-2016, 12:43 AM   #3
1955 mancave
Re: my new 64 tonka
bringing it home and the rusted ole frame that I'm going to use
Old 04-15-2016, 12:46 AM   #4
1955 mancave
Re: my new 64 tonka
started the build with the new stuff
Old 04-15-2016, 12:47 AM   #5
1955 mancave
Re: my new 64 tonka
just more updates
Old 04-15-2016, 12:53 AM   #6
1955 mancave
Re: my new 64 tonka
so that's what I have done up to this point, tomorrow I am going to pull the rear end out of the old frame and get it home, clean it up get the disk brakes on, I am hoping that by the middle of may I should have the body back on this frame , I have purchased a few brackets from capt. fab and since I used his stuff in the other 64 truck that I built I decided to use them again.
Old 05-06-2016, 08:42 PM   #7
1955 mancave
Re: my new 64 tonka
I think I have this in the wrong section, can anyone help get this moved to the project section.
thank you
Henry.
Old 05-07-2016, 12:32 AM   #8
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: my new 64 tonka
Actually you do have it in the right place. If you really want it moved I can do that.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-07-2016, 05:01 PM   #9
1955 mancave
Re: my new 64 tonka
no lets leave it here then, I hope your panel is moving along.
Old 05-07-2016, 05:29 PM   #10
1955 mancave
Re: my new 64 tonka
more updates ! so I have the rear end back in and now i'm in the process of just getting all the little welding done, things like the new axle saddles , brake hose tabs, I have new u-bolts and lower brackets , I hope to have all this taken care of by the middle of the week, I cant weld because of my pacemaker , so I have a good friend taking care of that for me.
I will post some pictures soon.
Old 05-07-2016, 10:19 PM   #11
DPowers
One foot in front of the other
DPowers's Avatar
Re: my new 64 tonka
Nice progress.
DPowers is offline   Reply With Quote
Old 05-09-2016, 09:29 PM   #12
1955 mancave
Re: my new 64 tonka
thank you, I still hope to have the body back on this frame buy at least the end of may, just in time for the heat here to kick in. but I will try to get out in the morning and get some things taken care of
Old 05-17-2016, 09:57 PM   #13
1955 mancave
Re: my new 64 tonka
well today I was able to pick up my tires and wheels , I will try to get some pictures loaded in the next few min.
Old 06-12-2016, 08:49 PM   #14
Re: my new 64 tonka
Nice looking panel. Wish we could find them that clean down here
Old 06-12-2016, 10:07 PM   #15
1955 mancave
Re: my new 64 tonka
thanks , I was hoping to have the body back on the frame, but due to other things going on it did not happen maybe in like 4 weeks.
