#126 | |
Re: Hooker 73-87 GM truck LS swap system
#127 |
![]() Join Date: Jul 2012
Toddoky, I appreciate your involvement here so I bought some Hooker manifolds.
#128 |
#129 | |
#130 |
Guys,
Does anyone have the dimension / length of the down pipe 70701403-RHKR from the mounting flange to the bottom of the pipe? I am trying to determine if it will work for my 48 Suburban. This is the downpipe for the 73 to 87 LS swap using Hooker components. Thank you! |
#131 | |
Driver side- 9.25" Passenger side- 9.75" |
#132 | |
Been following your product development over on LS1Tech too. You are a huge help for this hobby. Any plans to do a system for the late 60's early 70's B bodies? |
#133 |
Glad to help Doug. I don't know what's coming my way following the 64-67 A-body system I'm working on now, but I've not heard anyone on the management team mention the B-bodies yet...I'll be sure to mention them.
#134 |
Still waiting for the 67-72 truck parts.
#135 |
#136 |
I would vote for that too!
#137 |
Todd,
Thanks again for the measurements. Today I was able to try the downpipes and it looks like they will work for my application. It would be helpful for a lot of builders if Holley could provide the dimensions for all the downpipes, as you provided for me above, in product listings. Also, these downpipes had a lot of sanding debris left in the pipe. I don't know if all of them produced are the same .... and someone somewhere is going to miss cleaning out the debris. My concern would be the debris could migrate back into the engine or possibly contaminate an O2 sensor. The instructions with the down pipes didn't advise to check or clean them. Perhaps they could be revised. Or better yet the production process could include a cleaning as one of the last steps. Just some suggestions for continuous improvement. |
#138 | |
As far as dimensions of the adapters goes, I supplied you with those measurement as a courtesy as a fellow member here, but it's not something we will be doing overall since all of the new Hooker LS swap components are application-specific by design and not intended for use as universal fit components. Providing measurements is troublesome as they can be misinterpreted by a user and cause poor fitment and brand impressions, or prompt calls to the tech service department asking for a similar pipe to be made for them that has an additional 2 degrees of bend in it or some more rotation between the bends...I think you can see what a can of worms it opens up. Universal parts usually have a high ratio of returns associated with them and just doesn't represent the direction of development for new Hooker products these days. Guys like yourself giving first-hand use experience with using Hooker parts on custom applications is far more valuable to a potential user I believe. |
#139 | |
And at same time, I certainly understand how many people would misunderstand fitment dimensions, wanting custom modification for mass produced prices / capabilities. Then be upset with the company when they can't have it. Thanks again for all your support. |
#140 | |
#141 |
Holley must be really busy, 5 to 6 week wait for headers.
#142 |
#143 |
#144 |
I ordered the 70101504-1HKR model back on 3/19 and I called Holley yesterday because my order still said processing and was told none will be shipped until 4/28. I'm not really in a hurry because my build doesn't start till mid May. Is there a back order for exhaust part 70501415-RHKR? If so I should order soon. Thanks for your help.
#145 | |
#146 |
On the Holley website there is a note that says the exhaust doesn't fit on trucks with the 56" long leaf springs. Is that for both rear and side exit pipes?
#147 |
Yes, the exclusion is applicable to both exit styles. The rear spring perch location on trucks with the 56" springs is directly in the path of the designed frame attachment point of the tailpipe hangers of the Hooker exhaust systems. If you wanted to install either system on a truck equipped with such springs, you would have to fabricate new hangers that attach in a different location.
#148 |
I got my headers last week. Just thought I'd post a picture of them. 1 7/8" primary, mild steel with ceramic coating.
#149 |
toddoky,
Are power steering hoses available or suggested for use withn the accessory kit? (forgive me if it is in the paperwork....I didn't see it) Thanks, Barry |
#150 |
No, there's no particular PS hoses called out in the instructions of any of the components...the lab tech who does all the final assembly of our swap projects normally makes custom hoses using Aeroquip fittings and hose.
