03-29-2016, 02:57 PM | #326 |
Re: The 1960 - 1966 Chevrolet & GMC Pickups Factory Correct Restoration Thread
03-29-2016, 03:07 PM | #327 |
Check The Champ, Demonstrator
Great hubcap breakdown.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
03-29-2016, 03:44 PM | #328 |
Okay, going to edit the reproduction thing in the hubcap post. Not only are the ones I compared smaller top to bottom on the wings of the bowtie, I measured them with a dial caliper and the poor repop is much taller in the center. Heres all three. Original on left, the "Good" reproductions in the center and the currently available far right.
For the bowtie wings I will call them Original measures .593 GOOD reproduction .500 Poor reproduction .463 Center of bowtie or center square Original measures .890 tall GOOD reproduction .820 tall Poor reproduction .992 tall You can see now why the poor reproductions look so disproportioned. Also notice the ridge around the center is more rounded compared to the poor reproduction thats more pointed. Fine for many street trucks but this is a restoration thread. Hate to sound so over critical but that bowtie sucks !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK Last edited by 60-66; 03-29-2016 at 03:51 PM. |
03-29-2016, 10:06 PM | #329 |
Rollin' Old Skool
Great pics & references for this thread! I honestly have no clue if my chrome '66 hubcaps are original or repros, so I'll have to check them out more closely.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
03-29-2016, 10:07 PM | #330 | |
03-29-2016, 10:38 PM | #331 |
Wow! Incredibly thorough breakdown, 60-66. Thanks for taking the time and effort to do these comparisons.
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
03-30-2016, 09:06 AM | #332 |
I can add a bit of information for this thread in regards to the Hubcaps. In 1960, the correct hubcap for the GMC trucks was the 1957-1959 GMC caps.This was because when the 1960 model year was rolled out, GMC either forgot to design a new cap or it was not ready for production. The caps changed in 1961. I put the 1959 caps on my '60 as the early sales ads show them this way.
http://s1299.photobucket.com/user/jb...23904108567829 |
03-30-2016, 09:37 AM | #333 |
Thank you Jake . That's partially correct. The hubcap you posted is the same in design , yes. For 1960 AND 1961 GMCs , GMC grouped both years together as the "N" series . Both 1960 and 1961 received the same version hubcap with a paint change of a blue a center and blue outer ring accent. This is spelled out in the GMC parts books , dealer literature and data books. GMC did many things different than Chevrolet even though they are subtle differences , they make it a little tough sometimes.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
03-30-2016, 01:06 PM | #334 |
You can see both Painted and Chromed in this picture. I though about changing the color to blue, but the red matches the emblem as well, so it was a coin toss.
03-30-2016, 01:18 PM | #335 |
Yeah I here ya there. Painting these GMC caps would be a chore. Oem4me is quite talented in that field. He should do a hubcap "restoration" thread !!
04-07-2016, 10:09 PM | #336 |
i have a 1966 chevy c10 inline 6 and have a big issue. this truck was barned for 15 years and I just got it running, well kind of. I put a new carb on(1bbl rodchester) and new fuel line along with a new sending unit. I also put in new plugs and points, cap, rotor, timed it to 4 degrees advanced and it now will start takes some turning over but will start and idle but when I try driving it it wont come up to speed it just boggs down cant pull its own weight. what could be causing this? please help done all i can think of. thanks
04-07-2016, 10:15 PM | #337 | |
Posted via Mobile Device |
04-07-2016, 10:20 PM | #338 |
i'll try that in the morning thanks didnt think of that will keep you posted
04-07-2016, 10:27 PM | #339 |
I've seen that before and it was the points not set right but mine was also running a little warm along with that reset the points and work fine
04-08-2016, 11:17 AM | #340 |
Wrong thread for this subject. You'll probably get more views in the general 60-66 section or Engines and Drivetrain section.
04-08-2016, 10:45 PM | #341 |
tried new vacuum advance and set dwell to 30 and timing to 4btdc but still no power when i drive. the vacuum advance still does not move even when revved way up. took line off carb and with finger over hole and revving still feel no vac out of new carb should i feel the suction?
04-08-2016, 11:02 PM | #342 | |
Rollin' Old Skool
04-13-2016, 02:11 PM | #343 |
Hood Hinge and Spring Finish
Hood Hinge From research here looks like some hood hinges were silver cad, which mine looked like, weathered silver with some light rust/dirt. Also, some of the photos posted for Lambert, looked like they may have been blackish ones too??. Hood Hinge Springs Again research looks like they were kind of flat blackish, phosphate?? mine looked like this. Couple of photos of mine cleaned. Les |
04-14-2016, 08:16 AM | #344 |
Les , From my own group of trucks and personally , every truck Ive seen, 1960-1963 is Silver Cad with silver cad bolts and 1964-1966 is gray/Black phosphate with silver cad bolts .
1963 Silver Cad hinge gray phosphate spring 1964 Lambrecht truck . You can see the contrast in this picture of the 1964 between the cad plated bolts and gray phosphate hinge.
04-18-2016, 02:44 PM | #345 |
We've covered the paint/build order for the cab and the bed. How about the front sheet metal?
How was it all painted? Separately, then bolted together? I've never seen a good, unmolested truck: are the inner fender and core support bolts all painted, as though they were bolted together prior to painting? Grill surround? I've never paid attention to see if the flanges of the grill surround and the outer fenders are painted body color, or primer and bolted together before exterior paint. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
04-18-2016, 06:48 PM | #346 |
on the hood and hinge bolt using star washers did that change in 66 to flat washers does somebody have a original 66 to see
04-20-2016, 02:00 AM | #347 |
Yup. April 66 Fremont truck has flat washers.
05-05-2016, 04:45 PM | #348 |
Great thread. It has become my go to before the shop manual. Looking for pics of weather strip. I have not seen any. Just wondering may be the whole door. glass run channels etc... Thank you in advance!
05-13-2016, 01:51 PM | #349 |
this is great lots of possibilities
05-14-2016, 10:29 AM | #350 |
Learned something out the Hydra-matic today. My dipstickcap has always been loose so I decided to solder it and make it right. I glass bead blasted it and found this under the paint - cool. One more factory correct item.
