Old 04-20-2016, 08:43 AM   #1
kerrdog
kerrdog's Avatar
Rear axle shifting to one side after installing lowering blocks
Hey guys reaching out for some help put bags on my truck and 3 inch blocks on the rear after I did my rear axle is shifted to the passenger side about 2 to 3 inches any help would be nice thanks
kerrdog is offline   Reply With Quote
Old 04-20-2016, 09:53 AM   #2
R.S.S.
R.S.S.'s Avatar
Re: Rear axle shifting to one side after installing lowering blocks
Sounds like you need an adjustable panhard bar.
R.S.S. is offline   Reply With Quote
Old 04-20-2016, 12:15 PM   #3
kerrdog
kerrdog's Avatar
Forgot to mention that I do have one that's why I'm so confused
Old 04-20-2016, 12:25 PM   #4
R.S.S.
R.S.S.'s Avatar
is it to the stock location or to the opposite trailing arm? The longer the panhard rod the less side deflection you will get while your suspension is moving through its limits.
Old 04-20-2016, 02:56 PM   #5
kerrdog
kerrdog's Avatar
It is a early classics bar that runs from drivers side frame to passenger side trailing arm.
Old 04-20-2016, 03:49 PM   #6
Boog
laying low
Boog's Avatar
Hey mississippi. A pic might help.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-20-2016, 04:48 PM   #7
R.S.S.
R.S.S.'s Avatar
Seeing as your axle has saddles that the u bolts go through (unless you've swapped axles) the only thing I can think of that could be causing this is your panhard bar. You've got to adjust it so your axle is centered at ride height. However, once this has been done it will still move your axle left to right when going through its range of motion.
Old 04-20-2016, 04:52 PM   #8
AnotherWs6
AnotherWs6's Avatar
Yeah, you have to adjust the bar with weight on the truck or it's no bueno.
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 04-20-2016, 05:17 PM   #9
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Did you leave the bracket that mounts on the trailing arm, at the trailing arm or did you move it up on top of the lower blocks? You want to keep it between the trailing arm mount with the blocks and axle on top of it (and the spacer on the other side).
As other said, you must adjust this with the full weight of the truck on the ground, ready to drive (i.e. bed on, drivetrain installed, basically ready to drive).
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-21-2016, 01:22 PM   #10
kerrdog
kerrdog's Avatar
Maybe these pics will help
Old 04-21-2016, 01:43 PM   #11
AnotherWs6
AnotherWs6's Avatar
So are you saying that the passenger side is pushed forward in the wheel well? That's what it looks like in the pic.
I'm a noob to these older trucks, but this happened twice to me on my 99 Silverado. The bolt that goes through the leaf spring pack sticks out on top. When you tighten the u-bolts that little head has to be positioned in a little hole in the upper bracket in order to keep the axle and u-bolt from walking up the springs and causing what you seem to have. Long story short that bolt has broken twice on me and I knew both times because one wheel would be wy out of whack in the wheel well.
So what keeps the wheel from walking on these things? You added blocks to it, my bet is that something is wrong there.
And yes, one side of the axle can move while the other stays in place. A lot.
Old 04-21-2016, 01:52 PM   #12
R.S.S.
R.S.S.'s Avatar
I am no expert as to where the panhard bracket should be located however, it you put it back in it's original location (under the block/sandwiching the trailing arm) that should fix the issue. Alternaitly it looks like you still have some adjustment in the panhard bar so by brining that in you can rec-enter your axle. not sure if there is enough adjustment left though.
Old 04-21-2016, 03:11 PM   #13
chevy_mike
chevy_mike's Avatar
You are supposed to leave the bracket on the trailing arm location, not raise it with the blocks. That will totally shift the rear end over since you changed the arc of the parhard bar. Move it back to the trailing arm. Blocks are only supposed to lift the axle itself.
Old 04-21-2016, 03:32 PM   #14
dwcsr
Hollister Road Co.
dwcsr's Avatar
Have an alignment shop in your area put it on the rack and do a 4 wheel alignment. That will tell you where your wheels are in relation to each other and what direction their pointing. Once you know that you'll know what to move were and how far. Getting it to look right in the wheel well only may have you dog tracking down the road. Fix your alignments and then adjust the bed if needed for looks
Old 04-21-2016, 03:40 PM   #15
AnotherWs6
AnotherWs6's Avatar
Brief hi-jack, apologies. My friend was following me the other day and said that my all stock c10 was dog tracking a little. How would I check & correct that if I decided I had nothing to do on day?
Old 04-21-2016, 04:07 PM   #16
R.S.S.
R.S.S.'s Avatar
Measurements from a known point on both sides of the frame to the centerline of the axle on both sides. that will tell you if you're out of whack.
Old 04-21-2016, 04:25 PM   #17
kerrdog
kerrdog's Avatar
Chevy Mike I think that's going to be my problem I did not even realize that I had done that I'm going to change it and I will post the results
