Old 07-07-2015, 10:07 PM   #26
77K10Silverado
77K10Silverado's Avatar
Re: 1974 Stepside Project
Yes!! Nice big pics and hard work. Subscribed!!!
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 07-08-2015, 05:22 PM   #27
chevytrucksforme
Thanks Mike! I'm really liking your build as well. Truck looks good.
Rick
chevytrucksforme is offline   Reply With Quote
Old 07-09-2015, 08:40 PM   #28
rusty76
rusty76's Avatar
Man your on a ball.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 07-10-2015, 03:19 PM   #29
chevytrucksforme
Originally Posted by rusty76 View Post
Man your on a ball.
Thanks! Really like reading the story behind your build.
Old 08-05-2015, 01:49 PM   #30
chevytrucksforme
Been busy working on getting the right side metal work done. I was able to get the outer rocker mounted as well as the cab corner. I've definitely learned that doing butt welds is a real pain! It takes a lot of patience.
This is some finish welding of the floor pan and under seat patch.
Outer rocker and cab corner going on.
I definitely had the gaps too wide for the butt welds and caused tons of blow through. Had to really work at getting my welder set up right and got a little better as I progressed. I'll have some updated pics later.
Old 08-07-2015, 11:16 AM   #31
chevytrucksforme
This is where I am currently. Still have some finish welding and plenty of grinding to do.
Not sure why the new pan had this kick-up on the corner but I'll need to relief cut it to fit properly.
Old 08-07-2015, 02:14 PM   #32
willem445
willem445's Avatar
Love the detailed pics of rust repair. I need to do it myself one of these days.
willem445 is offline   Reply With Quote
Old 08-07-2015, 09:59 PM   #33
rusty76
rusty76's Avatar
Boy I wish I could say I've gotten stuff done. But honestly life has been in the way here lately. Great work on the patching. It looks great.
My build thread
Crossmembers CC
Old 08-07-2015, 10:04 PM   #34
Super_Dave
Super_Dave's Avatar
Yeah, I was wondering the same thing myself. Seems odd to come that way...
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
Old 04-20-2016, 01:18 AM   #35
Jrgunn5150
I'm in the middle of all this myself, have any update's? It's nice to find someone who didn't just drop it off at a shop, AND who took pics lol.
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 04-21-2016, 08:54 AM   #36
chevytrucksforme
Hey guys, it has been a little while since I've posted any updates. Just like a lot of you, other things get in the way of working on the project so it's been slow recently.
I did get the frame all stripped down, rust proofed and painted. Not sure why I didn't take pictures of the finished product but I'll get some when I get the garage organized better.
Currently working on the driver's side rust repair. Just like the other side I'm replacing floor, inner rocker, outer rocker, cab support and kick panel. This side isn't as bad but I decided to go ahead and replace everything since I already had the replacement panels.
I turned the cab over with the floor up for starters just to have easier access to the cab support. Added some casters to a pallet and laid the cab on it so I can still move it around.
[/URL]
A look at the bottom of the passenger side repairs. Not finished yet. I still have some welding and clean up to do.
[/URL]
Driver's side before cutting things out.
[/URL]
[/URL]
New support welded in.
[/URL]
Old 04-21-2016, 08:55 AM   #37
chevytrucksforme
Thanks Jr! You motivated me to post an update!!
Old 04-21-2016, 01:02 PM   #38
daddyjeep
daddyjeep's Avatar
I am in the middle of the same rust repair myself. A couple things I have learned about but welds....I find it works best to cut through the new steel and through the old steel at the same time with a .040" cut off wheel. This gives you a perfect and consistent gap. I also bought some but weld clamps from Harbor Freight. This made my work much cleaner.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 04-21-2016, 05:11 PM   #39
chevytrucksforme
Thanks, I believe I saw that idea on one of Kevin Tetz's videos as well. I definitely need to try it cause my cuts aren't matching up well at all right now.
I like your truck build. Looking to get a crew cab myself after I get a little further on this one.
Old 04-21-2016, 06:03 PM   #40
Jrgunn5150
And I appreciate it! The pics are really helpful, I'm going to be working on mine this weekend.
J.R.
Old 04-24-2016, 09:23 PM   #41
chevytrucksforme
Got the cab back on all fours, finished cutting out the driver's side rockers and rough fit the new inner and outer rockers. Pretty productive weekend even though I was also building some planters for my wife.
Old 04-24-2016, 11:53 PM   #42
tinydb84
tinydb84's Avatar
Man that is sooooo much work!
David
Instagram: myfabguy
Old 04-25-2016, 05:37 PM   #43
Jrgunn5150
Did you have to cut the door pillar up past where the nut plate is inside? Because I'm fitting mine and it really seems like it has to go that high, and yours looks like it does also.
J.R.
Old 04-25-2016, 05:48 PM   #44
daddyjeep
daddyjeep's Avatar
Cut the new rocker as high as necessary to get to good metal that you can weld to. It would be way more work than necessary to deal with that plate if you don't have to. I think I cut about an inch or so off my new rocker in that area.
04 1500 crew cab
Old 04-25-2016, 05:52 PM   #45
Jrgunn5150
Ah I see, you trimmed both to fit. My new outer from Classic Parts is far larger than what I need. Now I'll have to be very careful lol.
J.R.
Old 04-25-2016, 10:41 PM   #46
chevytrucksforme
Mine goes up to the point where the brace your referring to is located. I only went to the bottom of it. I agree that trimming yours is the best bet.
Old 04-25-2016, 10:46 PM   #47
chevytrucksforme
Smile Re: 1974 Stepside Project
Yes David, but so worth it!!
