04-26-2016, 12:13 AM | #26 |
Re: AWD c10
What's the latest? I'm slowly working on the rear step notch where I shortened the wheel base, wire harness and new wheels. How far into the firewall did the engine impede? After you removed the cab braces, was there sufficient clearance with the trans and t case?
Thanks, Ben. |
05-13-2016, 11:59 AM | #27 |
Re: AWD c10
Here's the latest on my truck-van. Sold the frame, engine/transmission, and wheels so no turning back now. Pulled the cab and managed to find the center sweet spot, came right off nice and even, putting it on the new frame was a different story, ended up almost tipping right off the picker. The rest of the day was a clean fest in the garage.
05-13-2016, 12:03 PM | #28 |
Re: AWD c10
More of the madness
05-14-2016, 07:31 PM | #29 |
Re: AWD c10
Set the clip on, loosely to check track width, and looks perfect after I fix the camber. I'm planning on using the hydro boost from the van but am short about 2". It's not threaded like the stock one, anyone extended the hydro boost staft? I suppose I could weld it longer but I'm getting tired of welding/fabing and would love bolt on.
05-16-2016, 08:32 PM | #30 |
Re: AWD c10
Blending your truck to the AWD van is looking really good. Quote from a friend, ( nothing we do is off the shelf ) Hope you find a quick easy fix for the hydro boost.
05-16-2016, 09:23 PM | #31 | |
Re: AWD c10
Anyone done this? Old reservoir/master cylinder on a new hydro boost? I should probably post this in the brake section. |
05-17-2016, 07:00 PM | #32 |
Re: AWD c10
Some pictures of my hydroboost mounted. Some research shows a 1990 ASTRO van master cylinder will work so it's coming full circle back to a van!
05-20-2016, 06:19 AM | #33 |
Re: AWD c10
I don't do many brake lines, I have the Eastwood brake flaring tool set and have bought metric lines and cut 1 end off and replaced with the size I need. From the skills you are showing this is just another, Bump...then... solved that problem whats next. What are your plans for the dash? I am going to put 93 Caprice running gear under my Blazer and would like to blend all the dash wiring and A/C in with it.
05-20-2016, 07:43 AM | #34 |
Re: AWD c10
Looks like the Astro van mc uses the same size lines as the c10 so I can ditch the 8 brake lines and the ABS pump. For the gauges I'm going with Speedhut OBDII, when funds are there. Cut the floor open to give the transfer case room to move, looks like it sticks up higher than it really is, maybe 4".
05-20-2016, 07:59 AM | #35 |
Java Mechanic
Re: AWD c10
You probably already know this but .....
As the owner of a couple AWD vehicles; when it gets far enough along that it matters, be sure that all four tires are the exact same rolling diameter and have the same compound. Having different compounds and diameters can cause differential failure.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
05-20-2016, 08:19 AM | #36 |
Re: AWD c10
Thanks for the insight on the tires, I picked up some transport wheels with fairly new tires, all same size.
06-08-2016, 08:37 PM | #37 |
Re: AWD c10
Cut the passenger side firewall back about 2" so the cab could sit in the proper location, the drivers side fits just fine. Finally figured out my brake lines, just need to bend then up. Set the front clip on and cut the frame off. Not sure how to rotate the pictures, sorry.
06-17-2016, 07:51 AM | #38 |
A guy with a truck
Re: AWD c10
This is cool. Watching.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-21-2016, 06:47 PM | #39 |
Re: AWD c10
Thanks, I can't tell you how many times I've had to take the cab and clip off for measurements, it's getting old! I'm painting the frame and firewall at this time then on to the body mounts. Can't wait to bolt it down for the last time, or so I tell myself.
06-24-2016, 08:59 PM | #40 |
Re: AWD c10
Panhard pictures, it'd been slow going lately.
06-24-2016, 09:02 PM | #41 |
Re: AWD c10
The driver side firewall fits good but I had to bump the passenger side in.
10-24-2016, 05:53 PM | #42 |
Re: AWD c10
Love bleeding brakes, by myself, for two hours. It's the best
10-24-2016, 05:55 PM | #43 |
Re: AWD c10
"Muffler" I grabbed off a prius at pick-n-pull.
10-24-2016, 09:37 PM | #44 |
A guy with a truck
Re: AWD c10
Yeah, that's the best. About as much fun as replacing vent window seals...
11-17-2020, 09:39 AM | #45 |
Re: AWD c10
Did this ever finish?
11-24-2020, 07:27 PM | #46 |
Re: AWD c10
Almost. Just have to finish the bed and then I’ll be switching over to rear coilovers.
11-24-2020, 11:58 PM | #47 |
Re: AWD c10
This is gonna be cool..
