05-29-2016, 01:35 PM | #1 | |
Active Member
Re: 5.7L Vortec issue
I bought the spider/regulator asm on ebay and the old injectors were so bad, they were brittle and broke off when removing them.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
05-29-2016, 07:08 PM | #2 | |
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
05-29-2016, 09:26 PM | #3 | |
Active Member
My symptoms were running rough when first started and sometimes loud backfiring when cranking. From doing research online I found out that leaking fuel pressure regulator will cause the backfiring and rough idling when starting -similar to flooding carburetor but worse. Since mine was a high mileage (app. 200K) 1996 Tahoe, replacing the asm as a unit was a better option.
