Closed Thread
Old 05-27-2016, 10:12 PM   #3776
FLA_Instigator
Re: What did you do to your truck today? Chapter II
Today the cab got insulated, next on the list is heater by-pass valves to stop the flow of heat through the blower. This pic was before all the seams were taped up. All told less than $50.
FLA_Instigator is offline
Old 05-29-2016, 12:08 AM   #3777
DarkFlounder
Finally had the time to diagnose my lack of horn. Connection point under horn was filthy and simply needed to be cleaned.
Dual horn setup, one horn working, one horn not working. Soaking the non-working horn in WD40 to see if that clears up the issue.
Either way, got a working horn. Better than leaning out the window and yelling at bay area drivers.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline
Old 05-29-2016, 01:08 AM   #3778
un4gvn!
un4gvn!'s Avatar
Originally Posted by Rich69shortfleet View Post
Are those Procar Pro90 lowback seats? If so, how do you like them? I was toying with the idea of installing those in my truck. I can get them at Speedway Motors which is local to me so I'd save a ton on shipping.
I installed the same seat but with the head rest I love them. The only thing is if you use the procar seat frame that is made for our year trucks, they are really high. My head was about a inch and a half from the head liner and I couldn't see out my door window without bending down a little. The frame is nice and sturdy. I shortened mine two inches. Work s great now.
un4gvn! is offline
Old 05-29-2016, 10:44 AM   #3779
matthamby
What is the height of your seats, I measured mine in the cab to be 15" from floor to top front of seat, the ones I'm planning on putting in are 13" measured the same way, I thought of making a frame that would bolt into the cab using factory holes then allowing me to use factory holes in the new seats while raising them between 2 to 3 inches.
matthamby is offline
Old 05-29-2016, 12:41 PM   #3780
midniteblues
midniteblues's Avatar
Picked up a set of these 8 lug accuride wheels yesterday from a local for less than a case of cheap beer.
I wouldn't pay any more than that for f#!d parts.
They cleaned up nicely though.
Even though it won't be correct(not much on the k will be) I'll spray them with some leftover 526 from my 67 build.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 05-29-2016, 04:00 PM   #3781
Metaldoc
Metaldoc's Avatar
Just need to paint all the frame work, but all fits.
Metaldoc is offline
Old 05-29-2016, 05:50 PM   #3782
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
Horns are pretty easy to re awaken ~ you need a good battery and test light , test for continuity , if there's continuity *slowly* tighten the adjuster screw until the test light goes out then back it off -barely- until the light comes back on , mount it and test it ~ the adjuster is really sensitive , a 1/10th turn is a lot .
I always recommend using a relay in heavy current consumers like horns .
The older ones , you can drill out / grind off the rivets and polish the contacts , , re assemble and adjust to suit .
Remember ! : a horn will not sound correctly unless it's solidly mounted .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 05-29-2016, 06:14 PM   #3783
chevy2tom
chevy2tom's Avatar
Metaldoc, more info on this setup please!
chevy2tom is offline
Old 05-29-2016, 07:06 PM   #3784
fleetimus
fleetimus's Avatar
Fabricating mounts & brackets on the BBC.
68 Chevy l/b, 4 whl disc in the foothills of No Calif
fleetimus is offline
Old 05-29-2016, 07:33 PM   #3785
Metaldoc
Metaldoc's Avatar
I used the original center holes to start. Re-drilled the cross members 6 1/8 on centers out from there. Welded nuts in all the holes. 1 1/2 x 3/16 flat bar as hold downs drilled 5/16 holes through. 5 3/8 x 1 composite deck board. I'll be using 1/4 x 1 allen cap screws from the top. I cut the boards from 12 foot lengths.
8 x 12' composite
10 x 1 1/2 x 3/16 flat bar
200 nuts, bolts
Metaldoc is offline
Old 05-29-2016, 08:14 PM   #3786
midniteblues
Dang nate wish I would known that before I chucked all the horns I had that didn't work highs and lows....live and learn.
Old 05-29-2016, 09:17 PM   #3787
SKT
SKT's Avatar
Originally Posted by PaddyO2053 View Post
Had some pics taken today for classic truck magazine
Attachment 1533723
Seriously!?!
A sharp looking truck like that and you're just gonna post one pic on this forum?
Let's see some more pics of this beauty!
SKT is offline
Old 05-29-2016, 09:30 PM   #3788
wesmigletz
wesmigletz's Avatar
Drove 320 miles round-trip today in my 67 SWB to get a hood, grill and fender from forum member Inlandsurfer. I need these to replace the onse my son damaged when he smacked a pole.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline
Old 05-30-2016, 12:36 AM   #3789
VWNate1
VWNate1's Avatar
Post Horn Service
Yeah ;
Me too ! .
I used to chuck 'em back in the days when new ones were cheap but I never really liked the sound of the new ones , once I began taking apart and repairing old , dead and discarded Klaxons (motorized ah-OOO-gah) , I decided why not take apart a pre war BOSCH vibrator typ horn , then I began to experiment much to the dismay of everyone else wherever I worked , my Son , Ex Wife , Brother , Neighbors , etc. , etc. because I save them by the box full and rarely does any vehicle I have , ever use the original horns.....
My Base Model C/10 had the DeLuxe dual horns I stripped off some abandoned junker somewhere...
It takes a gentle touch but it's worth the effort IMO .
Lastly , when selecting horns , choose two horns that toot off key individually , when they both blow at the same time , they harmonize and sound musical ~ try it ~ .
-Nate
Geezer
VWNate1 is offline
Old 05-30-2016, 12:38 AM   #3790
69chevytrucker
69chevytrucker's Avatar
https://www.youtube.com/watch?v=x-j6UGygoVw
made it go under its own power for the first time
69chevytrucker is offline
Old 05-30-2016, 12:46 AM   #3791
OregonNed
OregonNed's Avatar
Sanded the inside of the bed for the last couple of weeks, and also prepped some new parts. It got the first coats of primer today by my friend Justin, and now the sanding starts again.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 05-30-2016, 10:31 AM   #3792
66clow
66clow's Avatar
Did your son survive after he told you he wrecked the truck?
66clow is offline
Old 05-30-2016, 10:36 AM   #3793
66clow
66clow's Avatar
8 x 12' composite
200 nuts, bolts
Tell me you have an instructional video too. Let's see the final deal when complete. Those boards come slotted already on the sides? Looks great!
66clow is offline
Old 05-30-2016, 01:14 PM   #3794
wesmigletz
wesmigletz's Avatar
Yeah, but just barely...
BTW, that is a picture of him with the tan truck in my avatar.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 05-30-2016, 04:41 PM   #3795
firedemon
last 3 days actually got both quarters the hood and upper cowl all sanded to bare metal and primed . found way too much bondo going to be lots of work ahead
firedemon is offline
Old 05-30-2016, 05:14 PM   #3796
RodnRudy
RodnRudy's Avatar
I wire brushed the inside edge of the cab openings to get rid of the old glue from the weather strip, primed and spot painted them. Also got the top Da sanded ready for primer, seam sealer, and paint. I utilized an impromptu paint booth, the beech tree beside my garage!
RodnRudy is offline
Old 05-30-2016, 06:58 PM   #3797
66clow
66clow's Avatar
Cancel spring wouldn't stay in place, I think a piece of the plastic broke off. Added a little jb weld to keep it in place. Tried to clean the speedo cable to get odometer working but problem must be in the trans gear. Aligned the hood a bit. Tightened the right valve cover was leaking a little in the rear.
66clow is offline
Old 05-30-2016, 09:03 PM   #3798
74baggedbug
Received this pic from my buddy who's painting my truck.. Can't wait to see it in person
74baggedbug is offline
Old 05-30-2016, 09:12 PM   #3799
GR8-68
GR8-68's Avatar
Stood here and stared at it, wishing I could ride it..
GR8-68 is offline
Old 05-30-2016, 09:50 PM   #3800
Metaldoc
Metaldoc's Avatar
Those are composite deck boards from Rona pre grooved for speed clips. I'm painting the strips now. It was an idea that is turning out great. I want the wood look but no maintenance and not worried about scratches. No video just me in the shop. I just made the material list to buy, that's why I knew what is required. I will post pics later this week on install.
Metaldoc is offline
Closed Thread
