#151 | |
Re: Hooker 73-87 GM truck LS swap system
#152 |
#153 |
![]() Join Date: Jul 2012
A bit off topic though here is the exhaust system I put together using the 73 - 87 downpipes. The downpipes worked perfectly for this application.
Thanks again Todd. |
#154 |
#155 |
Todd,
how much better is the flow of the cast iron headers than stock truck, tbss, or Camara manifolds? Thanks
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532 |
#156 |
There's never been any comparative testing done between those various manifolds at Holley, but I can tell you the Hooker manifolds were modeled after (but more tightly tucked to the engine) the geometry of the 2010-up Camaro manifolds and would offer similar performance as them.
#157 |
Have a question...I picked up a set of the cast manifolds for a customer job and I am having a heck of a time finding the gasket to fit the s.s flange that comes with the manifolds.
On the website it states 2010 camaro exhaust gasket will fit. I have ordered 4 different sets and are all the same (center to center on flange is 3 3/4") and the gaskets are 4 3/8" and the round portion that is supposed to fit into the groove on the s.s flange is way bigger. Any help would be appreciated. Thanks Mark.
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#158 | |
#159 | |
#160 |
Thanks for the reply...
No I have not ordered that one yet (GM#) these were from the local parts house Ill give them a try. Mark...
#161 |
Can anyone confirm if the Headers sold in the kit hang below the frame rails? In the pictures it looks pretty close but hard to say for sure. If they do hang lower is there any fitment issues with using other brands of shorties or midlength headers hitting the mounts at all?
'80 GMC C15, still in progress... http://67-72chevytrucks.com/vboard/s...d.php?t=651276 |
#162 | |
#163 | |
As for the engine brackets I don't think I was clear on what I mean't, Sorry. I was referring to the engine mounts that are sold in the 2334K1 Kit.
#164 |
That kit number you posted is something the Jeg's packages and sells on its own, but going off of the image of the components on their website, they are the Hooker GM truck engine mounts (12621HKR) I had in mind when I gave my answer as to the fitment of non-Hooker headers.
#165 |
Any more info on the dual tank setup on the red truck?
wondering if an 87+ blazer tank will work with the 3in exhaust. |
#166 | |
Posted via Mobile Device |
#167 |
I've not posted any new information in this thread in a while and thought I'd share some new Holley accessory drive options that apply to this application.
Holley has recently released a new accessory drive system that shares the same component configuration as the 4th-gen F-body FEAD. This set-up is capable of being installed at both the F-body and truck offsets with the parts contained in the packaging; installation at the Corvette-offset is not possible. A very cool feature of this set-up is it allows the user to install the small or large truck type alternators as you can see in the attached photos. The new Holley low-mount A/C compressor bracket for the Sanden SD7B10 also shown in the photos has the capability of being installed at the Corvette, F-body or truck offsets, depending on the vehicle application and the specific engine swap brackets being used. For those of you using the Hooker 12612HKR 73-87 GM truck brackets, the A/C compressor bracket can be installed at the F-body and truck offsets without have to cut or modify anything. The parts shown in the photos were painted black by the vehicle owner and are not available from Holley in that finish; all production components are bare aluminum.[IMG] ![]() ![]() ![]() ![]() |
#168 |
Hope to have my LY6 6.0 on a test stand soon. Where is everybody ordering the Holley parts from? Haven't really found the swap parts cheaper than holley.com??
#169 |
Any idea as to when the AC bracket will ship? I pre-ordered a month ago and the estimated ship date keeps getting pushed back to maintain a two week gap to the present day.
#170 | |
#171 |
Todd,
While I remember you posting somewhere (ls1tech maybe) you had developed the mounts for the LT power train in the 73 - 87 trucks, I have been struggling to find them on the Holley website. There is no reference to the LT in the products section. Would you be able to provide a link or part numbers? Thank you! |
#172 | |
#173 | |
Are they on your “To Do” list? I was thinking they had been developed based on post 79 in 87Chevy.com LT swap...http://67-72chevytrucks.com/vboard/s...=712571&page=4 Also, the Holley mid mount accessory drive system is on my purchase list for my 48 Burb. Really appreciate the product support you guys are providing!
Doug Advanced Design’s 1977 Blazer Build Advanced Design's '48 'Burb Build Mrs Advanced Design's '72 Suburban Advanced Design's 56 BelAir LS swap Last edited by Advanced Design; 05-14-2018 at 09:45 PM. |
#174 |
This is what I put together using stock lines.....
#175 |
Does anyone know if the Holley engine mounts and crossmember will work for a 6l90e transmission on a 2wd C10 with low hump?
