Old 03-27-2016, 11:13 AM   #101
dsraven
Re: Danforth Cross Member Install
hey coach, what does the front end of your truck look like at ride height? the last pic, I assume, is with the bags deflated? do you have a pic of the same view with air in the bags and sitting at ride height?
just concerned with the angle of the tie rods. as the truck goes up and the tie rods level out they will get longer, due to the arc of the circle they travel in, so the toe in will get wider. will that be a factor to consider? it could be a hairy ride at highway speeds if you hit a whoopee bump on a corner.
Old 03-28-2016, 10:10 AM   #102
Coach529
Coach529's Avatar
I do not have a picture of the rack installed at ride height yet.
I measure my toe at ride height. Driving the truck below ride height will be very limited, and at slow speeds only. Got my fingers crossed that this will not be an issue.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 04-15-2016, 08:53 AM   #103
Coach529
Coach529's Avatar
Steering done....
1949 Chevy 3600
Old 06-08-2016, 11:23 AM   #104
Coach529
Coach529's Avatar
All set up and ride height.
1949 Chevy 3600
Old 06-15-2016, 08:55 AM   #105
Coach529
Coach529's Avatar
The sheet metal is back on and I have to say I am a little disappointed.
Below is a picture of my truck sitting on a 4" drop Sid's axle with a couple leaves removed. Notice the placement of the tire in the fender opening.
This is a picture of my truck with the Danforth Crossmember installed. Notice how the wheel is further forward in the fender opening?
I have contacted Scott and inquired about any complaints regarding the wheel not being centered in the opening. He states he has never had a complaint. I discussed with a couple friends on Facebook who are installing the same crossmember and they both have the same problem.
My first instinct was to slid the cab and front clip forward 3/4", but I do not think my distributer will allow it.
Aired out.
Ride height.
1949 Chevy 3600
Old 06-15-2016, 11:56 AM   #106
dwcsr
Hollister Road Co.
dwcsr's Avatar
I do see what your saying but I didn't have an issue either, I'm not sure if you can tell from the picture or not but its centered fairly good. The stock trucks are slightly forward so when your turning and going over a bump like into a driveway the tire doesn't rub the fender
Measuring your pictures the SID axle is slightly backward of center and your Danforth is on center of the opening measured horizontally from the lower fender bump out to the front
Old 06-15-2016, 11:59 AM   #107
dunce79
Has an alignment already been done. Guessing that could move the wheel back just a hear with more caster?
dunce79 is offline   Reply With Quote
Old 06-15-2016, 02:10 PM   #108
Coach529
Coach529's Avatar
No, an alignment has not been done. Hopefully this weekend.
1949 Chevy 3600
Old 06-16-2016, 03:05 AM   #109
bobinbc
bobinbc's Avatar
To me it looks more centered now than before. Nice install! I'm sure it will look great after alignment.
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 06-27-2016, 10:01 AM   #110
Coach529
Coach529's Avatar
Originally Posted by dwcsr View Post
We have it in and its a whole lot better steering than it was. It is about an 1/8" from the stops. We did have to use Tbrid inner tie rods EV117 and cut them about 3/4' on each end. The rod end were 7" long from a 93 corvette re-tapped to fit the tie rods. On a very tight turn it does scrub a bit but its only when its up against the stop. we do need to raise it 1.5".
I am still tinkering on my install and have taken a couple short trips around the neighborhood.
One thing I noticed is the steering radius sucks. I see you replaced the inner tie rod ends.
What was the reason for that?
Thanks!!
1949 Chevy 3600
Old 06-27-2016, 10:57 AM   #111
dwcsr
Hollister Road Co.
dwcsr's Avatar
Thanks!!
The inner tie rods that came with the rack were to long. I was seriously concerned when I first drove it around the lot here, our turn radius sucked, it pushed on corners, it jerked on a tight corners like a 4X4 until we got the toe right and aligned and its now as good or better than the stock axle. The customer has about 3000 miles on it with no steering complaints after we went to the 3 turn rack.
Old 06-27-2016, 12:47 PM   #112
Coach529
Coach529's Avatar
What caster number did you end up with?
1949 Chevy 3600
Old 06-27-2016, 01:21 PM   #113
dwcsr
Hollister Road Co.
dwcsr's Avatar
It lined up at
left side
-0.1 degree camber <--- a little out of spec but not much
0.8 degree caster
.11 degree toe
right side
0.0 camber
1.4 caster
.11 toe
lined up as a 2003 S10 4x2
Old 10-17-2016, 11:17 AM   #114
Elder Rogue
Elder Rogue's Avatar
Hey Coach it's been a few months of driving with the new cross member.
What is your current opinion?
What would you do different?
Thanks,
Elder Rogue is offline   Reply With Quote
Old 10-18-2016, 07:33 AM   #115
Coach529
Coach529's Avatar
Thanks,
To be honest I have not given it a fair shake. I still have not had it aligned, other than some quick string lines at my shop.
It goes down the road straight, with no bump steer. Around town over 15 mph it seems great. It is the slow parking lot stuff that it bucks, pushes and the radius sucks.
I have about 500 miles on it at this point.
If I was to do it over I would not go this route. When issues arise Scott is pretty much worthless as far as support. Looking back I wish I would have gone with an Industrial Chassis Crossmember or a full Fatman set up. Live and learn I guess.
1949 Chevy 3600
Old 10-18-2016, 11:12 AM   #116
Elder Rogue
Thanks for the update.
I am still deciding what to do. I have the SD unit setting on the shop floor, but have not jumped on it yet.
I have thought about putting it up for sale and moving on to ether a MKII or just clipping the truck with a G-body clip.
Old 10-18-2016, 03:44 PM   #117
dwcsr
Hollister Road Co.
dwcsr's Avatar
I had those very same issues on the one we did and thought the same thing but when it was lined up correctly it was like night and day. No more pushing around tight corners and the radius was good.
Old 01-10-2018, 09:52 PM   #118
cwoodling1
Hi guys! I’m a newbie here, my name is Kit. I have been following both of your builds! I am installing a 3 turn gear in a Danforth Crossmember per the information I’ve gathered with you both. Any help or advice I could get I would greatly appreciate!
cwoodling1 is offline   Reply With Quote
Old 10-09-2019, 08:41 PM   #119
1953
What was the mesurements on your axle centerline how far back from the front shackle hole is the centerline
1953 is offline   Reply With Quote
Old 10-10-2019, 03:08 AM   #120
mr48chev
mr48chev's Avatar
Most every MII kit I have seen sets the axle center line at 18-1/8 inches behind the center of the front shackle pin/bolt.
The only familiarity I have with this crossmember is from reading their and a few other's install threads.
I should note that we lost DWCSR in late 2017 early 2018 when he passed away.
My ongoing truck projects:
Old 10-10-2019, 07:34 AM   #121
1953
Yeah just wondering i got a speedway motors and its saying 18 1/8 from the front shackle holes so i been seeing what other people has been doing 18 1/2 isnt much of a diffrence
Old 10-10-2019, 12:26 PM   #122
Coach529
Coach529's Avatar
I did not realize that. Thanks for sharing!!
RIP
1949 Chevy 3600
Old 10-10-2019, 08:38 PM   #123
slammed57
slammed57's Avatar
really never heard of them, but it does look pretty beefy and stout. let us know what you think. Do they have a web site?
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 10-11-2019, 12:55 AM   #124
mr48chev
mr48chev's Avatar
It is 18-1/8 an not 18-1/2 good catch. That's what happens when you write something and try to remember rather than check your facts first. My bad, I hope it didn't mess you up.
Old 10-14-2019, 03:27 PM   #125
Coach529
Coach529's Avatar
Not even sure if he sells them anymore.
1949 Chevy 3600
