Closed Thread
Old 06-12-2016, 10:10 AM   #3851
VWNate1
VWNate1's Avatar
Unhappy Oops ~
I scratched the heck out of the beautiful paint in my bed but it's my work rig so no real harm done .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 06-12-2016, 07:51 PM   #3852
firedemon
Re: What did you do to your truck today? Chapter II
yesterday sanded primed and sound deadner the doors today the new panels from grumpy he does good work
firedemon is offline
Old 06-12-2016, 08:01 PM   #3853
GR8-68
GR8-68's Avatar
I found out my drivers door doesn't fit as the po didn't install the new rocker correctly
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline
Old 06-12-2016, 08:19 PM   #3854
66clow
66clow's Avatar
Removed the roof caulking
66clow is offline
Old 06-12-2016, 10:41 PM   #3855
Cleaned top end parts so they are ready to go when I get my valve job back. Soaked the new polished finned aluminum front differential cover I just got in muriatic acid solution so it was a closer match to the old same type rear cover, slots, and overall condition of my '72.
special-K is offline
Old 06-12-2016, 10:55 PM   #3856
Raleighswb
Washed the dust off to motivate me.
Raleighswb is offline
Old 06-13-2016, 06:16 PM   #3857
RodnRudy
RodnRudy's Avatar
I spot painted the maroon on the cab, trying to retain most of the old paint job.
RodnRudy is offline
Old 06-14-2016, 09:37 PM   #3858
firedemon
got my new inside heater box in today too dark for pics try tomorrow
Old 06-15-2016, 10:26 AM   #3859
Mator
Mator's Avatar
Added a few shinny pieces. Not complete yet but hopefully tonight.
I went from this to shinny.
Mator is offline
Old 06-15-2016, 12:58 PM   #3860
rustytruck50
rustytruck50's Avatar
Replaced the drivers headlight, tossed out the faded dash mat and 86'd the crappy seat cover in my new to me '72.
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline
Old 06-15-2016, 01:30 PM   #3861
Raleighswb
Real nice!
Old 06-15-2016, 01:54 PM   #3862
Myoldtruck
Myoldtruck's Avatar
I pulled the truck into the garage and started doing the 3spd on the floor to original 4spd on the floor conversion. I cut out the floor to install the high hump. I rust primered floor pans, they had some surface rust on them. I removed the old 3 speed trans. Tomorrow will be another day.
Myoldtruck is offline
Old 06-15-2016, 03:33 PM   #3863
RINC
RINC's Avatar
Just got home with a tailgate I found locally. Have it just sitting in there. Internal parts need to be installed but hey ..... I'll be able to haul stuff without the fear of said stuff rolling out of the bed.
Chris
'69 C-20
'04 Jeep TJ
RINC is offline
Old 06-15-2016, 04:01 PM   #3864
chevytruckguy70
Finally completed the refurbish and installed my grille. The little lady isn't looking too bad.
Only Two...... Only two have laid down their lives for you, Jesus Christ and the American GI.
2007 Chevy 2500HD 4x4 Duramax
1970 Chevy K20 (SOLD)
1972 Chevy C15 (1/2 C10, 1/2 c20)
1970 Chevy C10 (parting out)
chevytruckguy70 is offline
Old 06-15-2016, 04:33 PM   #3865
ole dollor
ole dollor's Avatar
WOW thats just nice all over ....congrats .....
ole dollor is offline
Old 06-15-2016, 04:44 PM   #3866
chevytruckguy70
Thanks. It's coming around. Not a show truck, just a fun everyday driver.
Old 06-16-2016, 06:35 PM   #3867
Crappie Hog
Crappie Hog's Avatar
Gave her a good bath today after starting her up for the first time in 12 years. She smoked a bit when I first started her up but quickly cleared up. I didn't even have to clean the points off and shes perfect. May try and put some wax on her tomorrow.
Crappie Hog is offline
Old 06-16-2016, 07:08 PM   #3868
66clow
66clow's Avatar
Tried to see if some jb weld will seal a small leak. Fingers crossed.
66clow is offline
Old 06-16-2016, 07:12 PM   #3869
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
JB Weld or any other Epoxy , isn't much good for cooling system leaks , I'm keen to hear how it works here .
-Nate
Geezer
VWNate1 is offline
Old 06-16-2016, 07:18 PM   #3870
66clow
66clow's Avatar
Seems to be a hair line crack and only leaks after I turn it off. I've seen mixed reviews online. All I will have lost is about 30 minutes of my time. Cheaper than $200. I'll update you, probably won't get it out till the weekend.
66clow is offline
Old 06-16-2016, 07:42 PM   #3871
VWNate1
VWNate1's Avatar
How many pounds pressure cap are you running ? .
Always remember : the boiling point of plain water goes up for each pound of pressure so few vehicles ever need more than a 3# cap .
Many can run fine with a marginal cooling system and no pressure at all but the coolant will evaporate as you drive .
Slowly but it's a thing to think about ~ I've driven across America with klunkers that couldn't take any cooling system pressure at all without leaking .
-Nate
Geezer
VWNate1 is offline
Old 06-17-2016, 07:49 AM   #3872
jethro5333
got my insurance yesterday. going to get tags today. drive this weekend?
jethro5333 is offline
Old 06-17-2016, 08:00 AM   #3873
flashed
Jethro, that is a good looking truck ,you know we would be willing to look at more pics of it.
flashed is offline
Old 06-17-2016, 01:47 PM   #3874
hamjet
hamjet's Avatar
Put some 265/70/15 cooper tires on the back. time for inspection...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 06-17-2016, 03:41 PM   #3875
Metaldoc
Metaldoc's Avatar
Test drive around the block and back. All seems good with all the rest of the parts on.
Metaldoc is offline
Closed Thread
