03-30-2016, 09:59 PM | #26 |
Check The Champ, Demonstrator
Re: Suburban Rear Bumper
Yet another mystery.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
03-30-2016, 10:18 PM | #27 |
Took a look in the TECHNICAL SERVICE DEPARTMENT manual for 1963.
The specs are the same as the front bumper. CK 1405, 06, 16 C3605 Material: High Tensile Steel Gauge, nominal: .147 Width, maximum: 78.54 Height, maximum: 6.67 Availability: Standard Painted RPO V37 Chrome There's no notes mentioning a cutout.
03-30-2016, 10:31 PM | #28 | |
1961 crewcab
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
03-30-2016, 10:51 PM | #29 | |
ron |
03-31-2016, 05:19 AM | #30 |
That was my thinking as well. You would usually find a different part number if anything changed in the design. GM would have stated if there was a different part number for optioned wheel changes.
03-31-2016, 06:29 PM | #31 |
1961 crewcab
here are my pics, both of mine are Fremont 'burbs
03-31-2016, 06:33 PM | #32 |
1961 crewcab
the other one, and a front and rear together:
04-09-2016, 09:12 PM | #33 |
One foot in front of the other
The panel truck rear bumper I have also has that cutout.
04-09-2016, 10:51 PM | #34 |
Junior Member
My 63 GMC Suburban has the notch also.
04-15-2016, 09:10 PM | #35 |
Thanks jonzcustomshop for all the side-by-side comparison photos.
This is the only vehicle I know of that uses the essentially the same bumper front & rear. And neither looks out of place- like it was forced to work. Really a great design and great example of re-using parts to save money. Anyone know of another car/truck that can claim this? Now I say a great design but at the same time it was lousy in the sense that it provided no step which would have been useful on the barn door trucks. On the tailgate 'burbs it was not necessary. |
04-15-2016, 09:15 PM | #36 |
06-09-2016, 10:45 PM | #37 |
Does anybody have some input on the rubber flashing between the rear bumper and back of the suburban. Is it neccesary? Is this part reproduced?
Thanks |
06-10-2016, 06:38 PM | #38 |
I don't think that seal is reproduced. I took a piece of it to a local A/C/Heating shop and told them what I needed and they made me one from aluminum. I had to cut the ends of where it curves around the body, but the main piece is there and is mounted using the original screws. I then paint it to match the body. I will post a picture of it here shortly so you can see it.
06-10-2016, 06:49 PM | #39 |
Here are some pics of the metal shield I had made. It's real hard to see being painted black, but when I re primer the back door, I will get a better shot. There is also a pic from underneath, and the piece of pipe tape, is for a short seal I am trying to make from some sponge-rubber I got at an old job.
06-17-2016, 01:30 AM | #40 |
Yeah it's kind of hard to see in the pictures. Thanks for the help.
QUOTE=65chevysub;7621160]Here are some pics of the metal shield I had made. It's real hard to see being painted black, but when I re primer the back door, I will get a better shot. There is also a pic from underneath, and the piece of pipe tape, is for a short seal I am trying to make from some sponge-rubber I got at an old job.[/QUOTE] Posted via Mobile Device |
06-17-2016, 07:35 PM | #41 |
sorry. I'm going to be primering the rear door Sunday so will take the bumper off and get a better pic then from the top and the end.
06-18-2016, 11:25 PM | #42 |
here are some better shots of my rear bumper to body seal that I had made. Couple of pics on my Sub, and some off.
06-19-2016, 06:14 PM | #43 |
06-19-2016, 06:39 PM | #44 |
Your Welcome. I just cleaned and put it in gray primer. I am definately going to put some sealer between it and the body, as it collects dirt in the seam and I don't want any rust.
