Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-10-2016, 08:57 PM   #76
Birdman72
Re: Fitech swap on my 1972 K20
Me to I will keep it updated.
Birdman72 is offline   Reply With Quote
Old 06-11-2016, 09:15 AM   #77
y5mgisi
Second Chance Program
y5mgisi's Avatar
I don't understand why there needs to be a needle and seat setup in there. Why can't the mechanical pump just pump it full?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 06-11-2016, 09:24 AM   #78
First c10
First c10's Avatar
If not then the fcc would not stay full. Then it would also become a pressure vessel and I am not sure it is designed to live in 7-9 psi. Hope this makes sense
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 06-15-2016, 09:35 AM   #79
coopdog
coopdog's Avatar
So fellas how's the trucks going? I got this shot the other day, makes Monday mornings a hole lot better
.................._____
__________//___{\____
/__---____//____/__---/
.....(O). ..................(O).
BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4
coopdog is offline   Reply With Quote
Old 06-15-2016, 10:31 AM   #80
snj8198
snj8198's Avatar
tease!
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 06-21-2016, 09:11 PM   #81
Birdman72
Coopdog what size air cleaner you have on your truck. Is it touching your firewall ?
Old 06-22-2016, 02:03 AM   #82
swamp rat
swamp rat's Avatar
Man i wish i could open my garage door and see that!
So is that an International in the back?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-02-2016, 09:54 PM   #83
Birdman72
Angry Re: Fitech swap on my 1972 K20
Well here is a little update. Sent FCC back to fitech they said float was set wrong and sticking. Said the replaced and ran on there motor with no hose on vent and had no fuel come out. Got FCC back on truck first fire up was good no fuel . Next day crank up and fuel trickling out of vent. Gets worse when driving . Put 20oz bottle on vent hose drive 1mile filed up bottle.
Old 09-29-2016, 02:31 PM   #84
coopdog
coopdog's Avatar
yes yes, that's my brother's 1954 R110 international, was a fun project, we put a 6.0 LS, and air ride in it, went from a farm truck to street truck.
here's the link http://67-72chevytrucks.com/vboard/s...d.php?t=657553
Old 09-30-2016, 10:38 AM   #85
y5mgisi
y5mgisi's Avatar
I don't understand still why they can't just have a return line going back to the tank on the top of the fcc and eliminate the whole float deal. Seems like the mechanical pump could just fill the vessel and when it's full the return line to the tank from the top of the fcc would make it to where the vessel is never pressurized.
Old 10-01-2016, 11:05 AM   #86
GSP7
GSP7's Avatar
Originally Posted by coopdog View Post
Currently I'm running a 750 double pump mechanical secoundary, dart aluminum heads , headers , flat top pistons , and a 274 comp cam
Coopdog... Are you running the Comp Cams - Xtreme Energy XE274H ?
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 10-03-2016, 08:26 PM   #87
coopdog
coopdog's Avatar
Yes yes, that's the one, it sounds great, would totally recommend it
Old 10-03-2016, 08:27 PM   #88
coopdog
coopdog's Avatar
Want to keep the thread alive, so here some recent picks
Old 10-03-2016, 08:27 PM   #89
coopdog
coopdog's Avatar
