Old 03-14-2011, 03:30 PM   #1
speedfoxracing
Question converting front drums to disc's brakes on 69c10
so i have a 1969 c10 8ft bed and has drums all the way around. and i want to know if any other vehicle spindles brake booster and prop. valve will fit my truck from a junk yard or where ever instead of forking out the grand to order it threw lmc. any help is good. even other websites where i can get cheaper parts. thanks
speedfoxracing is offline   Reply With Quote
Old 03-14-2011, 03:41 PM   #2
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: converting front drums to disc's brakes on 69c10
70 to 78 model trucks are great donor vehicles for the front ends. Someone will chime in if I am incorrect on my years, but these are the most common for swaps. Mine is a 71 front end.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 03-14-2011, 04:09 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
All of these are good sources.
71-87 trucks.
71-91 suburbans.
71-82 2wd blazers.
Keith
Convert to disc brakes.
Old 03-14-2011, 04:13 PM   #4
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks lolife! I gotta store that in my memory banks.
Old 03-16-2011, 04:06 PM   #5
speedfoxracing
ok man thanks. im gonna head to junk yard this weekend and see wut i can find. i,ll update yall on what they have
Old 03-16-2011, 05:54 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Get the booster,MC and prop valve also.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-16-2011, 06:09 PM   #7
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: converting front drums to disc's brakes on 69c10
WWW.TRUCKANDCARSHOP.COM shipping is a lot cheaper and the parts are way better there in Calif they have a on line catalog you can flip throw
stsalvage is offline   Reply With Quote
Old 03-16-2011, 06:32 PM   #8
jserrato714
jserrato714's Avatar
I was thinking of going to the junkyard when i was doing my truck but i did not want the headache.. i hit up power brakes in orange ca and got a kit for 500. I got drop spindels so it was more. A bolt on kit is under 400. And u get to use your factory a arms. They have a web site. If u have any questions pm. Goodluck.
jserrato714 is offline   Reply With Quote
Old 03-18-2011, 03:33 AM   #9
profe56
I sugest to read
http://www.classicperform.com/discdrop.htm
profe56 is offline   Reply With Quote
Old 03-18-2011, 09:47 AM   #10
BOZO
Old School
BOZO's Avatar
If you want to keep your 6 lug wheels and not have to change your rear end over, a good junk yard swap is converting to the later light 3/4 ton setup. I copied the following info info from this site a while back and if I'd known then what I know now I would have gone this route.
((Swap 6 bolt drum brakes over to 6 bolt disc brakes by using the front pieces off a 1988 Chevrolet pickup. Chevy made 6 lug 2wd 3/4ton trucks from 88 on. The 88 spindle, rotor, calipers, ball joints, and outer tie rods are used. Replace bottom a-arm from a 67 to 70 1/2 ton to a 67 to 70 3/4 ton a-arm. The top ball joint is the same but the bottom one has to be changed to an 88 ball joint. It pops right into the 3/4 ton a-arm. The top 88 ball joint fits into the upper 1/2 ton 69 a-arm, and the bottom 88 ball joint fits on the 67 to 70 ¾ ton a-arm. The top 88 ball joint you have to grind the rivets off of the 88 a-arm and then bolt it to the 69 a-arm.
Use the 69 intermediate shaft with the 88 outer tie rods. The inside tie rod end is changed to PART# : MOOG ES2020RL.(tie rod end). The 88 tie rods are also bulkier than the original 68 setup.))
As far as a good (and cheap) junk yard power brake setup, the Chevy Astro hydroboost unit is the way to go. You can look on this forum for more info on the hydroboost and the 6 lug disk brake swap.
#1 Project...69 Chevy swb Fleetside (Dad's truck)
#2...1983 El Camino SS (Choo Choo Custom)
#3...1974 Datsun truck (4.3L V6/4L60E)
#4...1951 Cadillac Limo (1975 Caddy running gear)
#5...1938 Dodge M38 3/4 ton Military truck
#6...1968 Sportster XLCH trail bike
5 GMC & Chevy parts trucks 68 to 72
Last but not least;
My 1978 Harley Davidson Electraglide
(trusted & reliable companion for the last 30 years)
BOZO is offline   Reply With Quote
Old 03-18-2011, 10:00 AM   #11
lolife99
lolife99's Avatar
I don't want to argue,... but I never see this swap as a cheap alternative anymore.
The aftermarket makes standard spindles and drop spindle that will bolt right on your truck.
No balljoint change.
No tie rod change.
No a-arm change.
www.performanceonline.com sells the spindles for $228.
Add auto parts store rotors and calipers and be done.
Keith
Old 03-18-2011, 10:00 AM   #12
brad_man_72
the boat guy
brad_man_72's Avatar
pretty sure this is a stickie at the top of the page...
buy a donor truck wheels, tires, all of the brakes, rear axle, extra engine and trans. Sell any good parts scrap the rest. I used a 76 heavy half. F40 brakes, 373 posi, sway bar, sold engine and trans. I bought the truck running for $600, I made money on my disc brake swap.
brad_man_72 is offline   Reply With Quote
Old 03-18-2011, 12:46 PM   #13
jserrato714
Enough said lo life.Who wants the headache. I bolted on my kit right up. No grinding or cursing. When on like butter on toast.
Old 03-21-2011, 03:38 PM   #14
tdp67
tdp67's Avatar
They have a web site?
tdp67 is offline   Reply With Quote
Old 03-21-2011, 03:55 PM   #15
Dano69c10
Dano69c10's Avatar
Don't forget the prop. valve.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 03-21-2011, 05:47 PM   #16
jserrato714
Here you go. Its called abs power brakes and they are in the city of Orange, Ca www.abspowerbrake.com
Old 12-15-2011, 03:16 PM   #17
JoeNational
Yup, the kit is 484-6 from www.abspowerbrake.com .... and it has everything you need... Just got off the phone with them and if you already have power brakes you just need the master and prop valve for $650... Nothing else needs to be changed dont even need an alignment afterwards... They also offer tech for it since they actually install these systems themselves to the local customers...
http://jalopyjoe.blogspot.com/
JoeNational is offline   Reply With Quote
Old 09-08-2014, 12:43 PM   #18
In The Ten Ring
I love the search feature on this website!
I'm considering buying a 1967 truck and if I do, I might want to switch to disk brakes also.
In The Ten Ring is offline   Reply With Quote
Old 09-08-2014, 03:50 PM   #19
lolife99
lolife99's Avatar
If you do,... the easiest way to get disc brakes is to use 63-70 conversion spindles.
The days of swapping 71-72 and 73-87 WORN OUT parts SHOULD BE long over.
This is 2014,... buy new parts to stop your truck!!!
Keith
Old 09-08-2014, 04:02 PM   #20
In The Ten Ring
I am not new to junkyards but I am new to brake work. I'd go for a new setup if I could but does one have to go to a 19" wheel? I thought that's what that one site (link in this thread) called for.
Old 02-15-2015, 06:00 PM   #21
TR32
TR32's Avatar
That's all fine and dandy if you have a pocket full of cash. For those of us broke suckers the junk yard is the way to go.......just make sure the parts you get aren't already worn out, and if you have to, replace the important stuff like ball joints and brake hoses.....JMO
Scott
TR32 is offline   Reply With Quote
Old 06-27-2016, 02:35 PM   #22
jricharc
I have a '70 C10 and it has power drums up front can I use the brake booster I have or do I need to swap that out as well? What parts are needed if I can keep the current brake booster. Spindles, ball joints, calipers and rotors?
jricharc is offline   Reply With Quote
Old 06-27-2016, 02:53 PM   #23
TR32
TR32's Avatar
You should be fine with the booster unless its worn out. I went the junk yard way, spindles, rotors, calipers, and upper/lower ball joints from a c2500 heavy half. That's if you want to keep six lug. With my setup it required 67-68 3/4 ton lower control arms. I got a bit of a hard time going with this setup because folks said they couldn't get the alignment right. I don't have that issue and actually got a few benefits from it. I already had 2 1/2 coils cut on the front but the heavy half spindles gave me a little extra drop and about another inch in width. I run 6 lug rally wheels so it works for me. If you want more info let me know. If you want to keep it simple buy the aftermarket conversion....JMO
1969 C10 SWB, 68 Front Clip, Tired azz 350 w/built 700R4, 3.73 Peg Leg...........
Old 06-27-2016, 02:57 PM   #24
jricharc
Thanks for the info, I have been replacing all the brake lines and the drums are decent I just wanted to upgrade at some point to make the routine maintenance a little easier on me.
I was trying to sell the truck to get a little later model C10 but people aren't willing to even pay $2k for a fully running/driving truck so I am not giving it away.
Old 06-27-2016, 05:16 PM   #25
TR32
TR32's Avatar
All my original stuff was wore out so I got ball joints and the shaft kits from rockauto. The new 90's heavy brake lines even mounted up to the stock lines. The lower shaft kit also has the locator drill for improved caster.
