Old 07-14-2016, 05:30 PM   #76
OutlawDrifter
liltroy on this board had the same thing with his ls(also an ly6) swap into a short stepper, i wonder if the ly6's had an issue?
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 07-15-2016, 02:00 PM   #77
phillipm
For some reason the 6.0's are more likely to have bearing issues.. Not sure why really.
However, we picked up a brand new long block from a local dealer who put out a sale on some engines. Guess it pays to know people some times. We turned in the old one as a core and now we're putting this brand new 6.0 back in.
Old 07-15-2016, 02:01 PM   #78
phillipm
Originally Posted by tinydb84 View Post
Ouch...
And that was just the #1 main and cap. I'm sure it didn't get better going back!
Old 07-15-2016, 03:03 PM   #79
aggie91
I'm just glad to be here!
aggie91's Avatar
Love this build. To bad about the engine, but that new one should be even nicer.
I saw about the tube you added to the transmission cross member, but what transmission cross member is that? Is that the stock 2wd Blazer cross member?
Thanks!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-15-2016, 03:16 PM   #80
phillipm
Cool, thanks Karl.
You are correct, the cross-member was the stock 2WD blazer unit.
Old 07-19-2016, 02:56 PM   #81
phillipm
Well, here are some of the photos of the Blazer put all back together. New engine runs great, and my Dad is charging the A/C today. As long as that goes okay then we're all set.
Old 07-22-2016, 07:23 AM   #82
TooTall
in case I missed it.
Was there anything on how you did the A/C lines and wiring to make it work? I saw where you have the compressor mounted in the stock location.
1984 K10, 8" lift on 35s
2011 Yukon XL | Bone stock
2013 Audi Q5
Old 07-22-2016, 12:22 PM   #83
68Timber
I know the pieces fit
68Timber's Avatar
Beautiful!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-22-2016, 01:20 PM   #84
phillipm
I didn't really go into it. However I used parts from www.coldhose.com to get it all hooked up. I bought my condenser on E-bay from a shop in Iowa. It was the largest that I could fit. I'd say there were a couple adapter fittings that I needed to make it work. If there is something specific that you are wondering about feel free to ask. It works fairly well, however I think I might be taking it all out and putting a Vintage Air Gen IV kit in. They are just light years ahead in technology compared to this system.
Old 07-25-2016, 11:54 AM   #85
phillipm
Just an update on the Blazer. I need to raise it up some. My front lower control arms are only 2.75" from the ground and they hit pretty much anything thicker than a leaf on the ground. I also will need to raise the rear some to match. I plan on starting in on this tonight.
The drivers side seat foam needs to be replaced. Does anyone sell that by it's self? I of course only need the bottom section. Just thought I'd ask.
Old 07-25-2016, 12:21 PM   #86
68Timber
68Timber's Avatar
There was a thread about replacement seat foam recently, IIRC you can buy it for bench seats but not buckets.
John
74 Honda Z50 build
Old 07-25-2016, 12:22 PM   #87
phillipm
Yeah I saw that too. No help. Haha. I've talked to my interior guy and he's going to try and just rebuild the bottom with new foam. I'll let you guys know how it turns out.
Old 07-26-2016, 12:00 PM   #88
phillipm
Got some time on the Blazer last night. I was able to get the front springs swapped out with the 1" drop springs. So far it looks like it raised the truck 1.25". I've now got 4.25" of clearance at the LCA. From my research that should be just fine. I may put new shocks on it to control the movement more if I still have an issue. But I don't foresee one.
Hoping to run over and grab my new leaf springs on Wednesday. Then I can get the back lifted up and 1" or maybe 2". I'll just have to see what looks best.
My new measurement at the front fender is 26" from there to the ground.
Old 07-26-2016, 12:55 PM   #89
OutlawDrifter
Tucking just the right amount of tire up front!
1991 Z/28, 6.0L/T56
Old 07-26-2016, 02:28 PM   #90
phillipm
Cool thanks. Just picked up my front wheels and tires from having them re-balanced. I think the guy that did them the first time maybe had a few puffs before. They were quite a bit off.
Old 07-28-2016, 11:53 AM   #91
phillipm
Just a small update. I ran over to my buddies house and picked up an extra pair of leaf springs he had in his shed. Well, they are much longer than the one that I've got! Like 4" longer! So, I decided to just pull one leaf out of his pack and add to mine in an effort to raise the truck a couple inches.. I'm not sure if 1 leaf will do it so I'll just have to trial and error it I think. I was only got one side done last night but this weekend I will get the other side done as well. before I left I sprayed the other side with PB blaster so it should all come apart easily. Side note, someone installed the front spring eye bolts before they put the body on the frame so the bolts were going the wrong direction. Nothing surprises me any more...
I also got around to slash cutting my tail pipes. I had left them just straight and long while I confirmed that their placement would work..
Another project I'm working on is adding a small panel in the console to hold a couple cigarette chargers and a USB charger. I also have an XM roady head unit that I'd like to mount on here. Once it's all don'e I'll sand blast it and paint it the same color as the console.
Old 07-28-2016, 01:25 PM   #92
buffydores
buffydores's Avatar
Never heard back from you on the cruise servo. You still interested in selling?
Old 07-28-2016, 04:26 PM   #93
phillipm
Shoot yeah. Let me get some pics of the cruise stuff next time I'm out in the shop.
Old 07-28-2016, 08:46 PM   #94
lolife99
67-72 parts collector,…
lolife99's Avatar
There were two different length leaf springs. 52" and 56".
Blazers had the 52" version.
And that bolt you're talking about was done that way at the factory.
I alway push them out a little and cut the head off, and remove it the easy way.
Cost the price of a new bolt, but saves a lot of time and agony.
Keith
Convert to disc brakes.
Old 07-28-2016, 10:14 PM   #95
phillipm
Wow that's crazy to me! I've got it in the other way now so good to go I guess. Thx for the reply.
Old 07-29-2016, 02:36 PM   #96
tobiahr
tobiahr's Avatar
If my memory is correct the bolt was done that way as a safety precaution so that if the nut came off the bolt couldn't back all the way out.
tobiahr is offline   Reply With Quote
Old 07-29-2016, 02:48 PM   #97
phillipm
That's crazy. Guess we'll never really know. I've owned dozens of Camaros and other gm leaf sprung cars. Never run across that ever. Thanks for the reply.
Old 08-01-2016, 03:50 AM   #98
PEDROSKI
PEDROSKI's Avatar
CPP lca should raise your clearance aswell.
Old 08-01-2016, 02:36 PM   #99
phillipm
Okay cool. Thanks!
Old 08-01-2016, 02:39 PM   #100
phillipm
Just another quick update. I got the leafs all finished. Just as a recap I added one leaf between my bottom and helper. It seems to have raised the truck about 3/4" but has also raised the spring rate so it doesn't sink down so far with fuel in it! Over all with the new front springs and the new rear leafs finished it drive and rides awesome. I drove in to work today and didn't bottom out or hit my control arms even once. Also my tires don't hit when I turn anymore either. So that's a double bonus.
1978, 6l90e, lowered, ly6
