04-06-2016, 12:47 AM | #151 |
Re: What can be said about the 4-speed New Process NV833 overdrive manual transmissio
unfortunately that side cover belonged to another customer, but Larry disappeared for a few minutes and reappeared with another side cover, it looked grungy but it too had the pin going all the way through, he said "FIFTY BUCKS"
I said "FOURTY" He said "FOURTY FIVE" I said "FOURTY PALEAZE" He said "DEAL" he was happy, and I was thrilled!!! the mystery of the stupid design GM pin was solved!!! |
04-06-2016, 12:49 AM | #152 |
see how on mine (the cleaner cover) there is no pin sticking out on the bottom below the top pin
and now see how on the corrected / fixed / retrofitted cover (the dirtier one) there is a pin with a snip on washer clipping it through the side cover and holding it in place, the way God intended |
04-06-2016, 12:54 AM | #153 |
and of course once you know the part number you can Google it and we find that a good cover (with the pin sticking out) is for sale on eBay right now for $135 bucks plus another $25 for shipping!!! yaykes The Greg done good gettin' his for $40
04-06-2016, 06:39 AM | #154 |
Well damn.......... win for Greg but not for us with the hole less covers........
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
04-06-2016, 08:48 AM | #155 | |
and here's what their side cover looks like |
04-06-2016, 08:57 AM | #156 |
better yet, the Mopar A833 Overdrive version of this transmission is way more popular than our GM one and guess what it uses the exact same side cover part number and all, C-13550-2 (well the new and improved side cover that is, with the pin hole, like we want)
here's a pic |
04-06-2016, 01:52 PM | #157 |
Moderator
Is there any reason not to just bore the hole the rest of the way through the older cover on a milling machine or good tight drillpress?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
04-06-2016, 02:16 PM | #158 |
Your right, probably the easiest way to go.....
04-06-2016, 10:37 PM | #159 |
Moderator
Some oil hardening tool steel and a small lathe like my 7x14 little green monster would come in handy here. There's really not much to that pin. The little Chicom lathes are too expensive now for what they are. Mine was just under $300 in 2000 and after some cleanup and upgrades like the 14" bed it's been a good little machine. Little is the operative word... but pins and bushings fall right into its' tiny work envelope. I can stuff it under the bench after a spraying the unpainted parts with Rustlick 631 on a shelf with an oiled canvas cover. The 16x42 South Bend ain't so portable and I don't like making small pieces on it even using a 3" chuck or collets
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-07-2016 at 12:38 PM. |
04-13-2016, 03:19 PM | #160 | |
I'm pretty sure that weld on the shifter was not factory, and was added later. I am fixing to install a cast iron version of one of the A833 transmission in my truck and there is no weld on either one of the two shifters I have. I was originally thinking the shifter was slipped in and then squeezed shut by a pressing operation, but now after seeing the information you posted, I'm thinking it is removable. ________________________________ Another thing to consider if you need a driveshaft. This A833 transmission uses the same 27 spline yoke as a Turbo 350/700R4 (it also uses the same tail-shaft bushing, which is easy to replace... My transmission shop installed mine for $3.00, which included the bushing). I haven't checked this out yet, but there is a chance that the transmission, when bolted to the clutch housing, might have the same length as either one of these two transmissions. If it does, we'll know what truck to look for at the nearest Pick&Pull. Last edited by Flathead Smith; 04-13-2016 at 03:49 PM. |
04-13-2016, 03:45 PM | #161 | ||
K Quote:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-09-2016, 09:45 AM | #162 |
I have one of these transmissions for sale if anyone is interested. 1986 Chevy half ton.
05-09-2016, 02:11 PM | #163 |
05-09-2016, 04:28 PM | #164 |
I have no time for this
I saw one of these transmissions in a 4wd diesel back in the eighties.
1986 Chevy short box ( PROJECT ) 1994 Chevy Blazer lifted 6" 2009 Gmc 2500 HD 1999 Hugger orange Camaro SS 2007 BMW X5 Sport |
05-09-2016, 05:00 PM | #165 | |
1968 C-10 Suburban - Original 396/TH400 2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen 2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck 2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have. |
05-09-2016, 05:59 PM | #166 |
Junior Member
It should be a hydraulic if it's an 86. I also have a set up complete hydraulic out of an 87 for sale. It's the harder to find 4 x 4 version though. It's even cast-iron.
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
05-09-2016, 10:05 PM | #167 |
Hydraulic. It also will come with the Hurst shifter and all things in the picture.
05-09-2016, 10:23 PM | #168 |
05-22-2016, 01:44 PM | #169 |
Junior Member
Thought this was very interesting when i pulled the pedal assy out of the 87 i got my set up from.
06-29-2016, 08:17 PM | #170 |
some numbers for you after my swap
70 MPH at 2000 RPM 75 MPH at 2250 RPM I am loving this new 833 overdrive transmission, now I have 4 useable gears not just 3 |
06-29-2016, 08:28 PM | #171 |
Those cruise RPM's are perfect for my taste.
06-29-2016, 09:18 PM | #172 |
Moderator
These turn a half ton truck into a pretty civilized cruiser and they'll put up with some towing.
Something a lot of folks overlook is that you can ship bulky things on Greyhound for less than the courier services you just have to package them carefully. I've shipped doors and trunk lids on Greyhound after packaging them. With a transmission or transfer case you need to make sure the oil is drained thoroughly and the box is reinforced enough that it doesn't poke through so you don't get filth on someone elses stuff.
07-16-2016, 08:01 PM | #173 |
I saw this at a pick-n-pull today. I was wondering if it would be worth getting to save it from the crusher? The side cover is loose, so I suspect it has issues. It is from a 4x4 truck. The shifter is there also.
07-16-2016, 09:00 PM | #174 | |
See if it has the hydraulic clutch bell housing if so get the bell and the clutch all of it and I'll buy it off of you ha ha Its a great trsnsmission I love my 2WD |
07-16-2016, 09:16 PM | #175 |
That's weird I thought I posted a picture of the transmission on the previous post. The trans and shifter could probably be had for $150 or less.
