07-16-2016, 09:22 PM | #176 |
Re: What can be said about the 4-speed New Process NV833 overdrive manual transmissio
07-16-2016, 09:26 PM | #177 |
07-16-2016, 09:41 PM | #178 | |
Important, do you see the three shifter fingers? They are also GM and impossible to find, get them, get it all and the tailshaft |
07-16-2016, 10:01 PM | #179 | |
07-20-2016, 09:34 AM | #180 |
I have been doing research on this transmission for like 10 months and have been looking for one as well so far no good leads.
07-20-2016, 02:34 PM | #181 |
Moderator
Might be worth the 3.5 hour trip to Salt Lake City.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
07-20-2016, 02:37 PM | #182 |
Its tempting lol I might have to call the yard see if they still have it
07-20-2016, 02:50 PM | #183 |
Hey bluek5 was that a complete unit shifter an bellhousing?
07-20-2016, 03:05 PM | #184 |
I think the bell housing is on the engine. It was a hydraulic clutch. You could try calling them 801-886-2345 , I really doubt if they could tell you if it was still there. The cover had been taken off of the transmission, so I would plan on it only being a core. I will probably go in there on my way to work Friday afternoon.
07-20-2016, 03:22 PM | #185 |
Yeah being a pick a part be kinda tough to tell lol yeah that be cool if its there just needs a shifter lol if u go could you get some pictures of it I wanna swap one in my 65 c10
07-20-2016, 03:28 PM | #186 |
The shifter is there also. This one is out of a 4x4 so you would need a transfer case with the round pattern or an adapter. I
07-20-2016, 03:29 PM | #187 |
Dang it lol I need a 2wd lol defintly be worth picking up if cheap enough
07-20-2016, 05:49 PM | #188 | |
http://www.ksl.com/?nid=218&ad=40692...chevy&ad_cid=6 |
07-20-2016, 05:51 PM | #189 |
Ill have to check that out for sure looks like all it needs is a shifter. You said the one in slc had a shifter?
07-20-2016, 05:56 PM | #190 |
07-20-2016, 06:16 PM | #191 |
Yeah I bet I wonder if the shifters r the same from 2wd to 4wd
07-20-2016, 06:20 PM | #192 |
07-20-2016, 08:48 PM | #193 | |
07-20-2016, 08:54 PM | #194 |
Yes I did the swap and the results are amazing, it's a difference of night and day, the first gear is now usuable and the overdrive is just brilliant. The third gear is perfect for down hilling without riding the brakes too. The details are in my build thread, it's quite long already but skip till you find it somewheres in the middle I think
Restoring Rusty |
07-21-2016, 12:51 AM | #195 | |
MY 66 needs it because as you know even tho the muncie 4 spd is an hammer and dependable ( mine lasted 36 yrs !! ) and I needed exactly what you reported about the first gear as usable for a change hahaha ! Is your truck an 66 3/4 ton or ? And may I ask what it can pull loadwise ? I ask because the easy fix would have been an T5 World Class 5 speed . But it might have broke or something . How did you address the speedometer issue if any ? Welding bracets Im sure . THANKS for the reply ! |
07-21-2016, 01:51 AM | #196 | |
This is an aluminum trans if you want strength all you have to do is find its iron case Mopar sister and swap the guts into it, and you will have the best of both worlds, bullet proof strength with overdrive Re read this thread I provide a link in it to Steve Dulcich doing just that: A-833 Aluminum Case Buildup - Maximum Overdrive Last edited by Gregski; 07-21-2016 at 02:05 AM. |
07-21-2016, 10:07 AM | #197 |
My 4wd one is different. Rods are heavier and shifter is offset a bit more, probably to give clearance to the t-case shifter.
Note that the shifter mounts on the tail extension on 2wd and on the t-case adaptor on the 4x4. Not sure if they are the exact same pattern and place fore / aft and crosscar. I believe the shifter itself is the same, just brackets and rods are different. Again we need to understand, these are LIGHT DUTY trans. They are NOT Hemi 833's . The gear swap resulted in overdrive, but the price is much lower torque capacity. GM never used them on anything more powerful that the 305, think ~200hp and 300ft-lb max. The iron case was used in the GM 4wd and it appears that the 2wd guts could be installed into it (output shafts have different lengths and splines). That helps the case wear issue but not the torque capacity.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors Last edited by D13; 07-21-2016 at 10:20 AM. |
07-21-2016, 10:14 AM | #198 |
Ok good to know I know that the shifters are hard to come by
07-21-2016, 12:01 PM | #199 |
According to the parts manuals there is no linkage difference between 2WD and 4WD of the same year, we had this discussion before early 80s are different from mid 80s models, I have a mix of 2WD and 4WD linkages and some spares / duplicates and they are identical
D13 are your 2WD and 4WD of the same year? I bet they is different, hence the difference |
07-21-2016, 12:38 PM | #200 |
I just wan a manual overdrive in my 65 c10 its just got a stock bf goodwrench 350 not a power house just building a cruiser, and that's awesome that they are the same identical rods just wanna get everything ready for the winter project
