Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 03-03-2016, 09:57 AM   #1
Hart_Rod
Hart_Rod's Avatar
LS3 parts Cam, pushrods, valve springs
I have a set of LS3 factory pushrods (7.4) and valve springs with less than 150 miles on them. I also have a L99 factory cam with less 150 miles on it. I replaced the parts when I went with a bigger cam. I will take $100 a set for the valve springs and pushrods and $100 for the cam. Let me know if you have any questions.
Hart_Rod is offline   Reply With Quote
Old 03-04-2016, 03:45 PM   #2
First c10
First c10's Avatar
Re: LS3 parts Cam, pushrods, valve springs
Hey rob,
How would this Cam do in a 5.3 LC9 Gen IV? the stock cam spec's are .467/.479-196/201 at .05 not sure the Lobe separation...
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-04-2016, 03:50 PM   #3
Hart_Rod
Hart_Rod's Avatar
Originally Posted by First c10 View Post
Hey rob,
I'm not really sure. Does it have VVT and DOD?
Old 03-04-2016, 03:53 PM   #4
First c10
First c10's Avatar
its a 2011 with DOD no VVT. It also has the 6L80E trans all currently stock
GO GO!!!
Old 03-04-2016, 05:17 PM   #5
michael bustamante
michael bustamante's Avatar
looks promising rob. will this set up work in my 03 yukon 5.3 set up 4l60 dbw?
1967custom
michael bustamante is offline   Reply With Quote
Old 03-08-2016, 10:14 PM   #6
Hart_Rod
Hart_Rod's Avatar
Does it have a 1 bolt cam? Thats what this one is.
Michael - your motor has a 3 bolt cam, so this won't wok on your motor.
Old 03-09-2016, 12:06 AM   #7
First c10
First c10's Avatar
I am not sure on the 2011 LC9 but on the 4.8 I had to replace the sprocket to 3 bolt because the comp cam was a 3 bolt. So I have a singe bolt sprocket. I need to check lift and make sure it wont bring up any problems because the truck runs great just would like a little bigger cam.
GO GO!!!
Old 03-09-2016, 08:50 AM   #8
Hart_Rod
Hart_Rod's Avatar
Kewl. Let me know if it will all work, .
Old 07-20-2016, 03:14 PM   #9
f.monroe
f.monroe's Avatar
How was the idle with this cam? Noticeable chop or smooth? I need to check my sons truck but he has a GM reman 5.3 that he wants to swap the cam in. His truck is a 2006. If I can determine that it will work for him he would take all of it.
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 07-20-2016, 03:52 PM   #10
Hart_Rod
Hart_Rod's Avatar
Originally Posted by f.monroe View Post
how was the idle with this cam? Noticeable chop or smooth? I need to check my sons truck but he has a gm reman 5.3 that he wants to swap the cam in. His truck is a 2006. If i can determine that it will work for him he would take all of it.
lmk!
Old 07-23-2016, 10:56 AM   #11
f.monroe
f.monroe's Avatar
My son says he needs a different cam so we will pass.
Old 05-02-2018, 08:54 AM   #12
Hart_Rod
Hart_Rod's Avatar
bump
