Old 07-19-2016, 02:09 AM   #326
jeh
jeh's Avatar
Re: Project "Redemption" 68 SWB Fleetside
That sucks Kieth, hope they get things worked out for you.
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 07-19-2016, 08:03 AM   #327
mcbassin
Still Learning
mcbassin's Avatar
Bummer about the wheels, hope it's a quick fix. Billet Specialties needs to make it right with you for sure..
Old 07-20-2016, 10:15 AM   #328
MMcMasters
MMcMasters's Avatar
Originally Posted by Bennett68C10 View Post
Went with 22x8.5/22x10 5" backspacing front and 4.25" backspacing rear Billet Specialties Heritage!
Keith,
If you have time, what is the measurement from wheel mounting surface to wheel mounting surface of your rear end with the rotors installed?
Thanks,
Mike
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 07-21-2016, 10:13 PM   #329
Raguemoe
Junior Member
Raguemoe's Avatar
The set of Intro's I ordered have been delayed because they are having trble with their wheel barrel supplier. They are for the 22x12's, but may be the same supplier to Billet Specialties. They indicated that the barrels they rec'd were oversized and had issues with the tires mounting.
Anyways, I feel your pain & hope it gets resolved soon!
Raguemoe is offline   Reply With Quote
Old 07-22-2016, 08:36 AM   #330
Bennett68C10
Bennett68C10's Avatar
Originally Posted by rincones View Post
I feel for you brother. Awesome progress on da frame
Thanks Guys, we will see what happens. I already shipped them back, guess I have to sit around and wait to find out what their going to do. I'm still very upset over this happening, I don't understand how you ship out wheels that tires can't be mounted on. Seems to me like some quality control was skipped before these wheels got shipped. I guess I expect to much for the price you pay and from a company like Billet Specialties.
Originally Posted by MMcMasters View Post
Keith,
Thanks,
Mike
No problem Mike, I'll get you a measurement this weekend. Keep in mind with the 4.25" backspacing I was planning on running, I would need to narrow the rear around 1"-1.25" per side.
At least they found the mistake before shipping your wheels out. I wish Billet Specialties would have checked the barrels before shipping me the wheels and wasting my time.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-22-2016, 11:02 AM   #331
knomadd
knomadd's Avatar
So were they built on a Monday or a Friday? Following the same story of assembly line workers who are hung over and tired on Monday, or checked out and ready for the weekend on Friday... I hope they make it right for you, and not waste more of your time with that problem.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-22-2016, 04:42 PM   #332
Bennett68C10
I hope so too! It makes you wonder how it happened!
Keith
66 Suburban
IG: bennett68c10
Old 07-25-2016, 08:15 AM   #333
Bennett68C10
Despite the issue with the wheels, I'm still plugging away at the frame! Got the motor and trans installed. I think the motor is sitting a little high because the best I can get is them at 7 degrees down! I can't raise the trans up anymore because it hits the Porterbuilt inner frame stiffener! I sent an email to Travis at AZProPerformance to see if Choppin block can get me some different motor mounts so I can lower the motor down a little.
Keith
66 Suburban
IG: bennett68c10
Old 07-25-2016, 08:16 AM   #334
Bennett68C10
Another angle
Keith
66 Suburban
IG: bennett68c10
Old 07-25-2016, 08:17 AM   #335
mcbassin
Still Learning
mcbassin's Avatar
Chassis looks great with that beast of a power plant in there.
Old 07-25-2016, 08:18 AM   #336
Bennett68C10
This is how tight it is from the trans to the inner frame stiffener.
Keith
66 Suburban
IG: bennett68c10
Old 07-25-2016, 08:30 AM   #337
Bennett68C10
Thanks Mike, it's nice to have the motor and trans sitting in the frame. Once I get the angles fixed I can start on the exhaust.
Keith
66 Suburban
IG: bennett68c10
Old 07-25-2016, 01:08 PM   #338
boostedc10
boostedc10's Avatar
Keith are you going to have room to plug that VSS sensor in? That looks really tight for sure!
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 07-25-2016, 02:02 PM   #339
Dustmaker65
Dustmaker65's Avatar
How much room you have between oil pan and cross member?
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 07-25-2016, 03:38 PM   #340
Bennett68C10
Currently no! I contacted Travis and he is working with Choppin Block to get me some new mounts to lower the motor down. Apparently they redesigned them after I received my crossmember.
I'd say I have a good 2.5-3" so the motor has plenty of room to go down!
Keith
66 Suburban
IG: bennett68c10
Old 07-25-2016, 06:02 PM   #341
jeh
jeh's Avatar
The cleanup and paint you did on the motor looks great. Going to be a nice ride when you get it finished.
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 07-25-2016, 07:37 PM   #342
Bennett68C10
Thanks Jason, someday the rest of the truck will look as good as the motor
Keith
66 Suburban
IG: bennett68c10
Old 07-29-2016, 03:43 PM   #343
Bennett68C10
I got the wheels back from Billet Specialties today. They milled the barrels down and polished them so hopefully I can get some tires mounted this time I guess I'll find out tomorrow morning when I take them to get mounted!
Keith
66 Suburban
IG: bennett68c10
Old 07-29-2016, 03:48 PM   #344
MMcMasters
MMcMasters's Avatar
Man that was a quick turn around. Very happy for you that they took care of it so quickly!
Mike
Old 07-29-2016, 03:59 PM   #345
Dareeper
I have the same problem with my Raceline Burst 5's. I'm wondering how common this is. I've got to send them back as well.
Dareeper is offline   Reply With Quote
Old 07-29-2016, 04:48 PM   #346
Woodnears
Very nice work
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417
Woodnears is offline   Reply With Quote
Old 07-29-2016, 05:52 PM   #347
jeh
jeh's Avatar
A person would think these high dollar wheel companies would turn out better items, or is it maybe a quality control problem???
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 07-29-2016, 10:11 PM   #348
7wolf
hopefully they didn't have to take much material off. looking forward to seeing the chassis finished up.
7wolf is offline   Reply With Quote
Old 07-30-2016, 06:51 PM   #349
Bennett68C10
Well I'm officially done with Billet Specialties. After getting the wheels back for a second time, I still can't get a tire to mount! I wasted my time today going to 2 different tires shops and neither one could get the wheels mounted up! The tires still won't fit down over the barrels no matter what you try! I'm disgusted right now. They can have their junk wheels back!
Keith
66 Suburban
IG: bennett68c10
Old 07-30-2016, 07:25 PM   #350
ajgriffin
ajgriffin's Avatar
I understand your frustration, but as an alternative, you can ask them to have the tires mounted for you. It sounds like you've made a solid effort on your own. I'd even see if they can throw you a little discount or credit for something else from them for the inconvenience.
Keep pressing man! You're doing great!
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
