Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > 99+ Chevy and GMC Parts Board
Old 12-06-2015, 06:28 PM   #1
esbstuff
WTB High Idle Switch
WTB High Idle or PTO Switch for a 99-07. I need the switch, bezel and at least some of the wiring... Shipped to 65584.
This is located just to the right of the HVAC controls if the truck has it...
Thanks!
esbstuff is offline   Reply With Quote
Old 12-21-2015, 01:24 AM   #2
esbstuff
Re: WTB High Idle Switch
ttt...
Old 07-31-2016, 01:51 AM   #3
esbstuff
ttt...
Old 11-20-2016, 03:51 PM   #4
esbstuff
Bump
Old 07-04-2022, 03:05 AM   #5
esbstuff
ttt...
Old 08-02-2022, 11:49 AM   #6
biketopia
depending on your engine and trans you can do this with a single wire into the ECM powered off the brake switch. I know on my 03 duramax I ran the wire and would just have to set the parking brake then you would hit the cruise button for one set point and the resume button for a slightly higher set point. Tap the brakes and it would cancel out, if it was in gear it obviously wouldn't engage, cruise would work as normal.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
