Active Member
![]() Join Date: Aug 2013
1975 Bucket seats fit in 69-72 Blazer
Has anyone put 1975 bucket seats into your Blazer? I'm thinking about buying a pair for my 72 blazer and want to make sure they fit and if they don't how hard is it to make them fit.
![]() Join Date: Jan 2001
Re: 1975 Bucket seats fit in 69-72 Blazer
If you're talking about second generation Blazer seats, they fit, but the passenger seat will hit the windshield when you tilt it forward. It won't go forward very far.
Active Member
Yeah I probably should have said 73-75/ 2nd generation. Is that because they a little taller but you think the brackets will match up. Thanks Truckster
They are taller; I'm not sure if the brackets line up exactly. That's what my Blazer had when I bought it years ago, but I didn't keep them and I really don't remember what the PO did with the brackets.
Carpe manana
![]() ![]() Join Date: Dec 2010
I pulled some plastic seatbacks from a 73 blazer that were the same as those on my 72s. I'm fairly sure the frames are the same but brackets differ though I could be wrong. Several threads have covered this topic.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: Oct 2006
As long as they are low back seats from a 2nd gen, the frames are the same, but the skirts are slightly different. With 1st gen brackets they'll work perfectly, but I'm not sure about 2nd gen brackets.
Active Member
Thanks everyone for your help.
1974 blazer seats wont bolt right on to the 72 you have to make new holes and if you buy original 72 brackes,the driver brackets will bolt right on to the 1974 seat, but not the passenger front brackets.
Active Member
Preciador6 due they make a reproduction bracket?
I have some 3rd Gen low back buckets (from a 88)that tilt all the way forward and would work nice? They need recovered.I could do 185.89 shipped.pm me if interested.
