Closed Thread
Old 08-10-2016, 09:08 PM   #4101
TrshTrk
TrshTrk's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by OregonNed View Post
Yesterday my bed project is finally finished! Myself and a few other old guys are a little sore today. Quarter sawn red oak.
what a beaut! great work
Trash Truck
69 GMC
TrshTrk is offline
Old 08-10-2016, 09:28 PM   #4102
SoCoC10
SoCoC10's Avatar
Repainted the Cheyenne Super's upper mouldings.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline
Old 08-10-2016, 09:47 PM   #4103
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Looks great. Did you do that while they were still on the truck. If so, just free hand or did you do any masking.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 08-10-2016, 09:47 PM   #4104
In The Ten Ring
Ochre! I love you dude! Excellent color choice.
Here is what I did since I ripped that same gasket off on the first attempt to put the heater box back onto the firewall.
In The Ten Ring is offline
Old 08-10-2016, 11:49 PM   #4105
SoCoC10
SoCoC10's Avatar
LOTS of masking. Used my rear bumper's box to make a 2" "window" in 4ft section. Only masked the upper and lower with the expensive/good tape then used cheap tape/duct to join the window to the good tape. Painted with my touch up gun with Rustoleum 4 parts flat to 1 part gloss 1 part acetone. Key is to use a flat surface (like a paint stick in my case)and wrap paper tight around it. Wet with acetone and use even pressure to expose to two shiny high ridges. Tedious but worth the effort.
SoCoC10 is offline
Old 08-11-2016, 01:38 AM   #4106
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Looked at a parts truck. 72 Super with every option. The engine sounds great, it has many nice parts, and the references I'm looking for (e.g., trim hole locations). It's mostly stock and the SPID correct. Factory A/C still installed (doesn't work), but bonus. The cab is toast in my novice opinion. Rust has eaten through the top gutter, front corners and likely the rear corners too. Some front fender rust too, eaten through. I didn't even take it for a spin, but I've since left a message with the seller he has a deal if the tranny, suspension, rear-end and steering check out. It's not expensive.
So anyway, that's what I did "for" my truck anyway. Peter to pay paul on location. Hope I get it.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 08-11-2016, 09:32 PM   #4107
SoCoC10
SoCoC10's Avatar
Cleaned, polished, painted and installed woodgrain insert on lower trim.
SoCoC10 is offline
Old 08-11-2016, 09:36 PM   #4108
In The Ten Ring
Today saw me (and dad) getting the heater box back onto the firewall and I just got in from running a NOS fender to a painter.
Old 08-12-2016, 01:10 AM   #4109
71CHEVYSHORTBED402
Ochre grows on me daily. That's nice.
Tony
Old 08-12-2016, 10:49 AM   #4110
OregonNed
OregonNed's Avatar
Angry Re: What did you do to your truck today? Chapter II
Yesterday after I finished a graveyard shift, I went home and put in new spark plugs, then ended the evening cleaning it all up for a car show on Saturday. The best part was the last spark plug falling down between the start solenoid and the oil pan...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 08-12-2016, 12:17 PM   #4111
flashed
O Ned ,that is a sharp truck ,love the colors .
flashed is offline
Old 08-13-2016, 09:56 AM   #4112
Corey'sgotachev
I didn't actually do this myself, but I paid for it. I stopped the gear oil leak coming out of the transfer case. The previous owner used RTV to seal it and it didn't hold. I have no experience rebuilding transfer cases and thought it prudent to have it done by a professional.
...and they had the missing part so now my speedo works!!!!
Corey'sgotachev is offline
Old 08-13-2016, 02:11 PM   #4113
ohboy321
ohboy321's Avatar
Cleaned up and polished my West Coast Jr's, installed new glass, and new SS hardware.
The one on the drivers side is not very useful, but it looks good which is all that matters.
ohboy321 is offline
Old 08-13-2016, 08:14 PM   #4114
GR8-68
GR8-68's Avatar
To hot and humid to work, a bit of rest and relaxation today
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline
Old 08-13-2016, 08:27 PM   #4115
TwoFiftyShifter
Took it to the tire shop to get a couple of tires mounted on her. Drove there with a center cap loosely bolted on, lost it on the way there.
Also wired my tachometer lights to the cluster lights.
Little by little.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline
Old 08-13-2016, 10:45 PM   #4116
SoCoC10
SoCoC10's Avatar
Seat and door panels installed as well as new carpet.
SoCoC10 is offline
Old 08-14-2016, 06:16 PM   #4117
66clow
66clow's Avatar
Started some sanding, found an empty lot. Love the west coast trucks, found all metal . Just sanded down chips. Boy I miss my house and garage. Painted cluster panel. Removed shim from starter, now starts correctly. Painted and installed corner core support brackets.
66clow is offline
Old 08-14-2016, 08:38 PM   #4118
Possmguts
Possmguts's Avatar
Just worked a bit on the Pass side bed side... had lots to work out.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 08-15-2016, 12:49 AM   #4119
OregonNed
OregonNed's Avatar
Polished my steering where adapter, and then decided I want a different steering wheel
Old 08-15-2016, 07:55 AM   #4120
Mator
Mator's Avatar
Won best GM at local car show on Saturday with 104 cars. Participant voting.
Mator is offline
Old 08-15-2016, 08:05 AM   #4121
colgad
colgad's Avatar
That took more than a minute to make it look that good!
Nice work on that bed side!!!
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 08-15-2016, 08:20 AM   #4122
Possmguts
Possmguts's Avatar
yeah.. its about 4 days worth of work on that area. It had lots of holes drilled in it to hold a ton of bondo.. I welded the holes shut and warped it and had to heat shrink it back out and dolly the hell out of it. The filler is really thin, but its from the top of the wheel well to the front edge.
Old 08-15-2016, 01:23 PM   #4123
dfwright
dfwright's Avatar
If those before and after pictures don't give you a warm, fuzzy feeling, then I don't know what to say. Those bedsides turned out very nice
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline
Old 08-15-2016, 01:31 PM   #4124
Possmguts
Possmguts's Avatar
Thanks.. both sides was rough under all the layers of paint and bondo.. but there was no rust at all, so I had no choice but to save them and put the money elsewhere... The back corners are the biggest challenge of all...
Old 08-15-2016, 01:44 PM   #4125
kilrcady
Very nice work my friend. I have no patience
kilrcady is offline
Closed Thread
