08-04-2016, 12:52 PM | #1 |
Just bought a 24v viair 330c. Will it run 12v????
So I just bought a viair 330c for really cheap. After I checked out I noticed it was a 24v compressor. Yikes! will it work with a 12 volt system????
I normally check and double check and triple check before buying anything. Did I mess up? Can I just hook it up like a 12v compressor?
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
08-04-2016, 02:59 PM | #2 |
Never Ending Projects
Re: Just bought a 24v viair 330c. Will it run 12v????
Nope, you need 24v to run correctly and even if it was to turn on, it would run at 1/2 speed and likely overheat doing so. Now you know why it was really cheap.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-04-2016, 03:25 PM | #3 |
You may be able to buy a 12v to 24v converter, just double check the amp draw.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
08-04-2016, 04:13 PM | #4 |
thanks guys. I was afraid of that. it was $70 used and they run $235 new.
I guess i'll hook it up and run it til it dies.
08-05-2016, 05:52 AM | #5 |
Or maybe run a 2nd battery to it?
08-05-2016, 07:48 AM | #6 |
Java Mechanic
You can install 2 smaller batteries in series in an isolated circuit (they would need an isolated ground path, not the chassis ground) to run the compressor.
There are isolation kits around so they can charge from the alternator but not interfere with primary system. Here is an example (not a recommendation, just a link to show what I am talking about) http://www.powerstream.com/battery-i...olid-state.htm Of course -- 2 batteries, hardware and an isolator would totally defeat the "I got it cheap!" advantage here... but running an isolated system might have other advantages worth considering.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
08-12-2016, 12:07 PM | #7 |
yes, I got the compressor and hooked across my battery to see what it would do. It runs about half speed and I couldn't really feel any air flow out of line. Oh well. I guess i'll put it up on ebay and warn buyers its not for a 12v air bag system.
