Old 07-06-2016, 09:30 PM   #151
joedoh
joedoh's Avatar
Re: LIL ERV the 50
I saw your question on the door window install and came across these pictures from MotherTrucker on the Hamb, hope they help.
Old 07-07-2016, 05:33 AM   #152
crossfire84
crossfire84's Avatar
Re: LIL ERV the 50
wow! thank you.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 07-12-2016, 06:36 PM   #153
crossfire84
Re: LIL ERV the 50
Installed the new gages today.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-12-2016, 06:42 PM   #154
99 to Life
99 to Life's Avatar
Re: LIL ERV the 50
nice, those are about the only aftermarket gauges I can stand. They look good.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-12-2016, 07:41 PM   #155
crossfire84
Re: LIL ERV the 50
thank you! they are a nice fit.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-22-2016, 05:46 PM   #156
crossfire84
Re: LIL ERV the 50
A little more done, Assembling front clip and running wires. Should have all parts back from paint tomorrow, And yes its hot here 92 in garage with fans.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-22-2016, 11:41 PM   #157
99 to Life
99 to Life's Avatar
Re: LIL ERV the 50
coming together. So hot here too, Im dreading working tomorrow in the humidity. I have to go buy a fan cause I don't have a work fan. keep it up, you'll be cruising soon.
Old 07-27-2016, 06:53 PM   #158
crossfire84
Re: LIL ERV the 50
So today I set the new glass in the frames with setting tape. I did a small how to on this, hope this helps someone.
The new tape has a cloth face and a rubber back with a peel off liner, there is no adhesion on the tape. Place rubber side on glass and use electrical tape to hold it on.
Cut small notches at corners as you go around the window.
Slide window in frame, It may be snug so tap easy, I put mine on a bath towel.
Leave the tape on it's so thin its fine.
Assemble then take a razor blade and trim around the frame and your done.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-27-2016, 07:35 PM   #159
99 to Life
99 to Life's Avatar
Re: LIL ERV the 50
nice job
Old 07-27-2016, 08:45 PM   #160
Advanced Design
Advanced Design's Avatar
Re: LIL ERV the 50
Good tutorial, looks very nice!
Advanced Design is offline   Reply With Quote
Old 07-28-2016, 05:31 AM   #161
crossfire84
Re: LIL ERV the 50
thanks
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 08-12-2016, 07:20 PM   #162
crossfire84
Re: LIL ERV the 50
So today I put the wind lace in, not a fun job so after trying dish soap,Vaseline,WD40 I found the perfect stuff to use. The goop that electricians use to pull wire. Menards has it and it worked perfect.
Be liberal in its use you cannot use too much.
Goop the back of rubber then do the tracks and outside of tracks.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 08-12-2016, 11:20 PM   #163
joedoh
joedoh's Avatar
Re: LIL ERV the 50
looks great!
I wish more things applied to this advice!
Old 08-13-2016, 02:21 PM   #164
solidaxel
solidaxel's Avatar
Re: LIL ERV the 50
I have used that to pull cable, good idea!
Be sure to wipe up the excess before it dries, seems like it desolves with water
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-13-2016, 06:49 PM   #165
crossfire84
Re: LIL ERV the 50
Works great and cleans up with a damp rag.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 08-13-2016, 07:16 PM   #166
99 to Life
99 to Life's Avatar
Re: LIL ERV the 50
good job, I just screwed mine in. Wasn't wanting to go in, maybe I'll have more patience next time and try this!
Old 08-14-2016, 08:43 AM   #167
crossfire84
Re: LIL ERV the 50
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 10-27-2016, 05:51 PM   #168
crossfire84
Re: LIL ERV the 50
So today I finished running the fuel and return lines.
I put a large canister filter in back and a 40 micron in front of carb.
I ran aluminum lines down the frame rail.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 02-22-2017, 07:26 PM   #169
crossfire84
Re: LIL ERV the 50
Rear brake lines in and radiator in, Getting close now!
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 02-22-2017, 11:36 PM   #170
99 to Life
99 to Life's Avatar
Re: LIL ERV the 50
nice, just in time for spring!
Old 06-17-2017, 04:58 PM   #171
crossfire84
Re: LIL ERV the 50
Its been a while but more work this week.
Shifter and boot+ring in.
Under dash A/C in, still have to plumb it.
Parking brake handle, lines in.
Engine hoses, fuel, vacuum in.
Carpet in.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 06-19-2017, 10:48 PM   #172
joedoh
joedoh's Avatar
Re: LIL ERV the 50
looks good! I bet you are chomping at the bit to run with it.
Old 06-20-2017, 06:27 PM   #173
99 to Life
99 to Life's Avatar
Re: LIL ERV the 50
ah the final stretch, can seem never ending too!
Old 06-22-2017, 12:49 PM   #174
crossfire84
Re: LIL ERV the 50
getting close!
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 09-16-2017, 04:50 PM   #175
crossfire84
Re: LIL ERV the 50
Getting closer, however the hyd clutch does not engage far enough to shift. Going to have to look for a longer throw. But it sounds sweet!
LIL ERV the 50-3600
C4 rear
Porter built a arms
