Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 08-14-2016, 11:33 AM   #51
67ChevyRedneck
67ChevyRedneck's Avatar
Re: '67-'72 Power Brake Booster Bracket With Hydraulic Clutch Conversion
Originally Posted by Captainfab View Post
The total cost for one '67-'72 hydraulic clutch conversion with just the base plate and in bare steel with shipping is $191.85.
I see that you're on vacation, have fun! When you get back I would be interested in this kit as well, without the brake booster bracket.
Can a different style wildwood MC be used? I don't really like that the line has to be run out of the back on top? So I have to go up and loop the line down?
I also have to ask... why is the 67-72 clutch pedal linkage so complex, but when I click on your 60-66 link it's just this:
I mean, I can do that easily.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-14-2016, 02:57 PM   #52
Captainfab
60-66 Nut
Depending on what bore size of master you need, a different style of clutch master may add to the cost.
That picture is of the original linkage that I started with. It did not allow full pedal travel and is no longer used in any of my hydraulic clutch convetsions.
Old 08-14-2016, 03:23 PM   #53
67ChevyRedneck
Gotcha!
I'm installing a 2001 4.3L S10 NV3500 in my 67 C10, the trans has the internal slave. I've seen several people us this one: 70174-750? But if that won't work with your pedal, that's OK. I want the best combo that will work. That MC bowl looks tiny... is there enough fluid to push the slave cylinder that I need it to?
Jesse James
Project "On a Dime"
Old 08-14-2016, 03:46 PM   #54
Captainfab
60-66 Nut
I don"t have good enough wi-if right now here in Fredrickstad, Norway to look up that part number. I have not had any complaints with the clutch masters that I typically supply. I believe that internal slave needs a .700 bore master. I will have to verify that later.
Old 08-14-2016, 06:17 PM   #55
67ChevyRedneck
No problem, NOT in a hurry at all. Enjoy your trip, we'll figure it out when you get back.
Jesse James
Project "On a Dime"
Old 08-15-2016, 03:08 PM   #56
Captainfab
60-66 Nut
That number you gave does not show up in Wilwood's line.
Old 08-15-2016, 04:37 PM   #57
Captainfab
60-66 Nut
I was able to find that Wilwood clutch master. The number you gave is an old outdated number. I can supply that master at an additional cost. I will have to check and see where I can get the best price.
Old 08-15-2016, 09:46 PM   #58
low70c10
do you have to have the the mounting plate (outside of locating where to drill the hole for the clutch master) im running a wilwood manual brake set up and would rather not have a plate if possible
low70c10 is offline   Reply With Quote
Old 08-16-2016, 02:51 AM   #59
Captainfab
60-66 Nut
Aside from locating the clutch master, the plate does stiffen the firewall. I can sell you everything except the booster bracket if you like.
Old 10-08-2016, 09:32 PM   #60
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
PM sent to you with a question!!!
THanks
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 10-09-2016, 12:47 AM   #61
Captainfab
60-66 Nut
PM replied to.
THanks
Old 11-03-2016, 11:03 PM   #62
Hinz28
Hinz28's Avatar
Anyone have any pictures of 69-72 installed inside the cab. There's quite the rib that needs trimmed out. The directions explain it pretty well but I have yet to see a picture? Maybe I'll get one once I have it notched out
1970 Chevrolet C10 SWB 6.0 LSx
1971 Chevrolet K10/30 5.3 LSx
1972 K5 Blazer 8 lug LSX
Hinz28 is offline   Reply With Quote
Old 11-07-2016, 01:57 AM   #63
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Ttt
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is online now   Reply With Quote
Old 11-11-2016, 01:39 AM   #64
1970 CST Short Wide
Senior Moment
Best $ I've spent in a long time. Shipping was FAST , product was Fantastic, worked exactly like it was supposed to even though I had to modify because of MY set up.
Thanks John
Steve 1970 CST Short Wide
Pittsburg Ca
94565
Old 11-11-2016, 09:12 PM   #65
colgad
colgad's Avatar
Installed the flat plate version today after painting and it went perfect. A great product thanks for the quick delivery.
Dave
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 11-11-2016, 10:35 PM   #66
Jocker64
How much would you sell the clutch brackets kit, no master cylinder?
Jocker64 is offline   Reply With Quote
Old 11-12-2016, 12:48 AM   #67
Captainfab
60-66 Nut
It would be $50.00 less than the price in post #1.
Old 01-27-2017, 07:02 PM   #68
JPsChevy
JPsChevy's Avatar
I'm interseted in buying a kit, I'm installing an NV3500 that came out of an 06 1500 that had the 4.3/5spd. Did you come up with a master with a line out the bottom?
Opportunity is missed by most because it is dressed in overalls and looks like work.
- Thomas Edison
JPsChevy is offline   Reply With Quote
Old 01-28-2017, 01:09 AM   #69
Captainfab
60-66 Nut
No I do not have a source for a clutch master with the port on the bottom. With the Wilwood's it is either on the top or front.
Old 01-28-2017, 08:48 AM   #70
JPsChevy
JPsChevy's Avatar
That is fine I was just wondering, I will take a complete kit not powder coated. Pm me your PayPal and a total.
- Thomas Edison
Old 01-29-2017, 12:14 AM   #71
Captainfab
60-66 Nut
I sent you a PM
Old 02-17-2017, 11:52 AM   #72
67ChevyRedneck
Gotcha!
Ready to finally buy this. The trans I'm using is posted above. I don't need the MC that I posted above if you know of one that works with my application, but I do want it to come out the front, I DO NOT want one that comes out of the top.
I just want the unpainted mount plate for the clutch and the clutch parts like below:
Thanks!
Jesse James
Project "On a Dime"
Old 02-18-2017, 01:05 AM   #73
Captainfab
60-66 Nut
This is the other style of Wilwood clutch masters that I use. It has the port on the front. It just depends on what you want. The other one you posted about will raise the cost.
https://www.summitracing.com/parts/wil-260-6764
Old 02-18-2017, 10:14 AM   #74
67ChevyRedneck
Nice, I like that way better than the plastic tank one!
Yes, I want the front routing, makes the install a lot cleaner looking dropping the line straight down.
If that ones matches up with my NV3500 trans I'll take it. Is it still $191.85 (odd number for the forum )?
PM me your paypal info. Thanks!
Jesse James
Project "On a Dime"
Old 02-19-2017, 01:47 AM   #75
Captainfab
60-66 Nut
I will send you a PM.
