08-10-2016, 09:08 PM | #4101 |
Re: What did you do to your truck today? Chapter II
what a beaut! great work
Trash Truck 69 GMC |
08-10-2016, 09:28 PM | #4102 |
Repainted the Cheyenne Super's upper mouldings.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
08-10-2016, 09:47 PM | #4103 |
70+ ( Old Skool Club )
Looks great. Did you do that while they were still on the truck. If so, just free hand or did you do any masking.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-10-2016, 09:47 PM | #4104 |
08-10-2016, 11:49 PM | #4105 |
LOTS of masking. Used my rear bumper's box to make a 2" "window" in 4ft section. Only masked the upper and lower with the expensive/good tape then used cheap tape/duct to join the window to the good tape. Painted with my touch up gun with Rustoleum 4 parts flat to 1 part gloss 1 part acetone. Key is to use a flat surface (like a paint stick in my case)and wrap paper tight around it. Wet with acetone and use even pressure to expose to two shiny high ridges. Tedious but worth the effort.
08-11-2016, 01:38 AM | #4106 |
Looked at a parts truck. 72 Super with every option. The engine sounds great, it has many nice parts, and the references I'm looking for (e.g., trim hole locations). It's mostly stock and the SPID correct. Factory A/C still installed (doesn't work), but bonus. The cab is toast in my novice opinion. Rust has eaten through the top gutter, front corners and likely the rear corners too. Some front fender rust too, eaten through. I didn't even take it for a spin, but I've since left a message with the seller he has a deal if the tranny, suspension, rear-end and steering check out. It's not expensive.
So anyway, that's what I did "for" my truck anyway. Peter to pay paul on location. Hope I get it.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-11-2016, 09:32 PM | #4107 |
Cleaned, polished, painted and installed woodgrain insert on lower trim.
08-11-2016, 09:36 PM | #4108 |
Today saw me (and dad) getting the heater box back onto the firewall and I just got in from running a NOS fender to a painter.
08-12-2016, 01:10 AM | #4109 |
Ochre grows on me daily. That's nice.
08-12-2016, 10:49 AM | #4110 |
Yesterday after I finished a graveyard shift, I went home and put in new spark plugs, then ended the evening cleaning it all up for a car show on Saturday. The best part was the last spark plug falling down between the start solenoid and the oil pan...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-12-2016, 12:17 PM | #4111 |
O Ned ,that is a sharp truck ,love the colors .
08-13-2016, 09:56 AM | #4112 |
I didn't actually do this myself, but I paid for it. I stopped the gear oil leak coming out of the transfer case. The previous owner used RTV to seal it and it didn't hold. I have no experience rebuilding transfer cases and thought it prudent to have it done by a professional.
...and they had the missing part so now my speedo works!!!! |
08-13-2016, 02:11 PM | #4113 |
Cleaned up and polished my West Coast Jr's, installed new glass, and new SS hardware.
The one on the drivers side is not very useful, but it looks good which is all that matters. |
08-13-2016, 08:14 PM | #4114 |
To hot and humid to work, a bit of rest and relaxation today
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
08-13-2016, 08:27 PM | #4115 |
Took it to the tire shop to get a couple of tires mounted on her. Drove there with a center cap loosely bolted on, lost it on the way there.
Also wired my tachometer lights to the cluster lights. Little by little.
1982 K10 SWB 1987 V20 - Sold - Doh! |
08-13-2016, 10:45 PM | #4116 |
Seat and door panels installed as well as new carpet.
08-14-2016, 06:16 PM | #4117 |
Started some sanding, found an empty lot. Love the west coast trucks, found all metal . Just sanded down chips. Boy I miss my house and garage. Painted cluster panel. Removed shim from starter, now starts correctly. Painted and installed corner core support brackets.
08-14-2016, 08:38 PM | #4118 |
Just worked a bit on the Pass side bed side... had lots to work out.
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
08-15-2016, 12:49 AM | #4119 |
Polished my steering where adapter, and then decided I want a different steering wheel
08-15-2016, 07:55 AM | #4120 |
Won best GM at local car show on Saturday with 104 cars. Participant voting.
08-15-2016, 08:05 AM | #4121 | |
Nice work on that bed side!!!
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
08-15-2016, 08:20 AM | #4122 |
yeah.. its about 4 days worth of work on that area. It had lots of holes drilled in it to hold a ton of bondo.. I welded the holes shut and warped it and had to heat shrink it back out and dolly the hell out of it. The filler is really thin, but its from the top of the wheel well to the front edge.
08-15-2016, 01:23 PM | #4123 |
If those before and after pictures don't give you a warm, fuzzy feeling, then I don't know what to say. Those bedsides turned out very nice
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
08-15-2016, 01:31 PM | #4124 |
Thanks.. both sides was rough under all the layers of paint and bondo.. but there was no rust at all, so I had no choice but to save them and put the money elsewhere... The back corners are the biggest challenge of all...
08-15-2016, 01:44 PM | #4125 |
Very nice work my friend. I have no patience
