#26 |
Re: So when in 1972 did GM start installing single wall tops?
Why did they switch to single wall? Cheaper?
#27 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Wish I knew for certain. I'd speculate that the double wall tops were sagging and required the owner of a CST to remove the rear panels before top removal (a pita) so GM tried a new design ahead of the 73 model year. Thus far the data shows that single wall tops were used for only a portion of the 72 MY and only on K5s built at flint.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#28 |
Carpe manana
Flint built 1x wall 126497
#29 |
Carpe manana
one more
#30 |
Carpe manana
Switch from 2x wall to 1x wall at Flint some where between sequence #'s 7,636 and 12,592.
#31 |
Carpe manana
Another early 1972 MY Flint built Blazer (sequence 102567) with 2x wall top and a speaker below the dash:
#32 |
Carpe manana
A first for the record???
St Louis built 72 Blazer seq # 146724 that looks to be a near survivor and has a 1x wall top. On the hunt for additional St Louis built k5s that have the reasonable expectation of being originally outfitted with a 1x wall top. Link to more pics: http://www.ebay.com/itm/1972-Chevrol...FYx1Cl&vxp=mtr
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 03-15-2017 at 11:56 PM. |
#33 |
Carpe manana
One by one on the iPad....
#34 |
Carpe manana
Another...
#35 |
Carpe manana
More...
#36 |
Carpe manana
Uno mas...
#37 |
![]() Join Date: Apr 2013
I believe that 72 was the only year, that had double wall. With the ribbing running side to side. That's the way my three were configured. 69 4wd, 71 4wd
72 2wd highlander grapefruit yellow w/avocado cst. Just a theory. |
#38 |
Carpe manana
Here's a transition Flint built Blazer that has a single wall top and lacks speaker holes atop the dash so uses a below dash speaker. This truck has a November assembly month per the blue door vin decal. Sequence # 127656
Any single wall St Louis survivors?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 07-24-2018 at 10:04 PM. |
#39 |
Carpe manana
#40 |
Carpe manana
More....
#41 |
Carpe manana
Top...
#42 |
Here's my tag, built June of 72. Single wall top and speaker on the top of the dash just like the pickups.
#43 |
Carpe manana
Thanks for posting. June is late in the model year - makes me wonder who on the board has the last 72 that rolled off the assembly line...
#44 |
Carpe manana
Clean looking 2wd on eBay (https://www.ebay.com/itm/1972-Chevro...temCondition=4) - Flint built 1x wall top w speaker below the dash. Looks reasonably unmolested. Not best image of the dash top.
Sequence # 156067
#45 |
My Blazer has a build date of 3/72 with swt and the radio speaker up under the dash between the defrost vents. Has a higher vin number, can that even be possible ???
#46 |
Carpe manana
Thanks for posting. If the ochre is correct, it suggests the switch to an internal dash speaker like a pickup happened between 156067 and 165204 at Flint.
The double wall top was dropped for a single wall top. Later in the model year, the traditional K5 dash was phased out for the pickup style with a speaker grill. Interesting.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 08-03-2019 at 06:05 PM. |
#47 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Pete
I have or had 3 72' Flint Blazers. Spids below. One came with a double wall the other two are or were single wall. Only the DW Blazer still has the blue door tag but I can't make out the date on it. The other one has been painted over. All three did not have speaker grill in top of dash. .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#48 |
Carpe manana
Helpful info - thanks for posting. Let me guess, SPID for sequence # 111983 was the 2x wall example?
Your info would narrow down the dash change to between 160889 - 165204
#49 |
Correct the olive green one is the 2x
#50 |
Carpe manana
That narrows the switch from double wall tops to single wall tops between sequence numbers 111,983 - 112,592. These numbers must be within a day or so of each other in terms or rolling off the line as finished vehicles.
