Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-15-2015, 06:45 AM   #101
Cobalt964ruf
Cobalt964ruf's Avatar
Re: 1971 K30 burb - LS3, 4l80e, np205, Dana 70f, 14bff, Detroit lckrs, 4"lift, 35" BF
hood is off, fluids drained, griffin radiator pulled and set aside.... so it begins.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 08-08-2016, 07:09 PM   #102
Cobalt964ruf
life has changed a few things around as it always does. so a carbed ls3 and th400 with np205 is going in the truck for the winter. maybe next summer i can do the 4l80e and fi
Old 09-02-2016, 05:47 PM   #103
Cobalt964ruf
we used the ls3 for a different build but dont fret, this truck is getting a LS6 build; new old stock 5.3 iron block bored to ls1/ls6 specs, new gmpp ls9 forged crank, new gmpp ls9 forged rods, new king main and rod bearings, new gmpp ls6 pistons, new mahle rings, new gmpp ls7 lifters, new old stock gmpp 243 ls6 ported and polished heads, new gmpp C7R road race cam, arp main studs, arp head studs, arp rod bolts, every fastener on and in engine is arp, new ls6 oil pump ported, new truck pan pickup tube and windage tray. new 409 stainless obxR headers, ict billet valley plate, ict billet oil pan level billet plug, new edlebrock performer rpm intake, new holley 650 carb, new msd ignition controller, etc etc etc.
Old 09-02-2016, 05:51 PM   #104
Cobalt964ruf
more pics.....
Old 09-02-2016, 05:53 PM   #105
Cobalt964ruf
more pics...
Old 09-02-2016, 05:57 PM   #106
Cobalt964ruf
more pics....
Old 09-02-2016, 05:59 PM   #107
Cobalt964ruf
np205 teardown and rebuild...
Old 09-02-2016, 06:01 PM   #108
Cobalt964ruf
np205 case cleaned and ceramic heat coated...
Old 09-07-2016, 08:17 AM   #109
Cobalt964ruf
LS6 update; copper head gaskets, 243 heads buttoned down finally. headers and copper exh gaskets.
Old 09-07-2016, 08:47 PM   #110
72MARIO
72MARIO's Avatar
following..... I am going to be swapping a 6.0/4l80 205 into my 1968 longhorn chassis.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-08-2016, 02:09 AM   #111
Cobalt964ruf
sounds like a good swap. i was going to do a ls4/80e/205 and have another ls3/4l80e waiting on the shelf. at this moment i dont want to revamp the entire fuel system, do the wiring, and have the truck down for more time. so for now, its the ls6 with carb, th400, np205. and maybe i will prep the ls3 and 4l80e wiring, and have a tank already done with intank pump and all ready and waiting before i remove this setup later. that way the truck isnt down for long periods of time. at this point i want to drive it and enjoy it. but enjoy yours for the both of us with the overdrive lol. at this time its not in the cards for me. tooo busy
Old 09-08-2016, 02:11 AM   #112
Cobalt964ruf
on a side note, with the dana60 front axle, 14bolt ff rear axle, both with lockers, th400, np205. and ls6 with minimal wiring and a carb, this truck makes a good SHTF truck.
Old 09-08-2016, 07:18 AM   #113
72MARIO
72MARIO's Avatar
I hear ya on the time. Just finished a lq4 /4L80 swap and kept it injected. Took me nearly 2 weeks of 12 hour days. The fuel tank was my biggest struggle. If i was to do another suburban of this era I would buy the ECE tank.
2005 TAHOE DD
Old 09-09-2016, 02:57 AM   #114
Cobalt964ruf
sounds like you have some nice projects, keep up the good work!
Old 09-13-2016, 06:02 AM   #115
Cobalt964ruf
building a dual snorkel air cleaner for the old burb. give it a kinda vintage look even tho it will sit on top of a ls. the pic is not mine, but it is the look im after.
Old 09-13-2016, 04:15 PM   #116
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That's a nice power plant you're building there! The air cleaner will look great too.
Ryan
1969 Chevy milk truck
Old 09-13-2016, 11:25 PM   #117
Cobalt964ruf
Thank you Diesel! here is a pic of engine and air cleaner tonight. still a little metalwork to go on air cleaner, then sandblast, primer, and paint.
Old 09-14-2016, 08:24 PM   #118
Cobalt964ruf
here is the air cleaner finished up...
Old 09-14-2016, 09:18 PM   #119
Dieselwrencher
That is very nice!
Ryan
Old 09-15-2016, 05:43 AM   #120
Cobalt964ruf
Originally Posted by Dieselwrencher View Post
That is very nice!
Thank you for the kind words Diesel!
Old 09-15-2016, 10:04 AM   #121
lowrodderchev
lowrodderchev's Avatar
Amazing job your making me want to carb my ls motor the air cleaner I sweet
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 09-16-2016, 09:00 AM   #122
Cobalt964ruf
Thank you Lowrodder!
Old 09-16-2016, 11:34 PM   #123
Average Joe
Average Joe's Avatar
The air cleaner is a neat touch on a cool combo. Looks great!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 09-17-2016, 04:27 AM   #124
Cobalt964ruf
Thank you Joe.
Old 09-17-2016, 04:35 AM   #125
Cobalt964ruf
Todays progress; i rebuilt my Th400. 4l85e 5 gear planets, kevlar clutches, kevlar reverse band, 34 element sprag, new pump, new valve body, HD filter and billet pan.
