Old 09-06-2016, 11:10 PM   #1
66C10LB
Shifter removal, 4 spd.
Hi. Does anybody know how to remove this shifter (see image with this thread) in a 1966 C10 Pickup 283 4spd.? I have read some other threads on the topic but haven't managed to remove it yet. (In case you are wondering, I have removed the back up light switch).
66C10LB is offline   Reply With Quote
Old 09-06-2016, 11:31 PM   #2
franken
Re: Shifter removal, 4 spd.
Push down and turn to the left a bit the round sheetmetal thing at the base of the shifter.
Old 09-07-2016, 11:02 AM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
A large pair of waterpump pliers works well to open wide and grab just the sheetmetal retainer.
A picture of what it looks like might help,, The retainer looks like this
http://www.bearingkit.com/SM465-Shif...5-b8t7220d.htm
and like Frank said,, push down and COUNTERCLOCKWISE to remove
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-07-2016, 04:05 PM   #4
66C10LB
Thanks Franken and Marv! I tried again today with success. Thanks again for the advice.
I used a bit of a novel method.....I took two short pieces of oak flooring, bungeed them together, slid them over the shifter so that they rested on top of the sphere....holding onto both extended ends of the oak flooring, I pushed down and twisted, easily removing the shifter.
Old 09-07-2016, 04:14 PM   #5
GSTAuthor
I promise you that's the first time that's ever been done!
GSTAuthor is offline   Reply With Quote
Old 09-07-2016, 10:01 PM   #6
franken
I had trouble at the scrapyard getting one apart and used random bits of wood to get one to pop--its a pain.
4spd, removal, shifter, transmission
