#26 | |
PITbut
Re: Diagnosing a misfire
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! ![]() My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
#27 |
My edelbrock 1405 ran rich the fuel pump pressure was toohigh I installed regulator. It ran so rich the idle mixture screws had noeffect i could close them and engine still ran. After installing reg. I was able to tune carb changing metering rods.You have a carb that is running rich clean floatbowls install fresh fuel filter and then trytuning carb.Big carbs and big exhaust is meant for full throttle high rpm work
#28 | |
#29 |
We need more info 1did the carb ever run well? if it did then clean and rebuild adjust floats. 2 ha ve you changed anything else? on the carb or fuel delivery system? pump? regulator?? good luck might want to change oil if it has gas in it
#30 |
That's a good point - check your oil to make sure it's not overfilled now (which would indicate a bunch of gasoline has made it past and into the crankcase).
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#31 | |
Maybe this will afford me a chance to finally use my cool starter button that I got for setting lash but then found out it's better to hand crank the engine lol I got a Bosch compression checker, hoping that's a decent brand tool. The rotohammers I've used were always great so I figured the Bosch one would be a good tool. I think after work today I'll get a good vacuum gauge too, I keep hearing that guys tune Holleys with one so I better add that to my tool collection. It's funny now that I think about it, my first thread a looong time ago when I was trying to identify what can I had, my tool set consisted of basic box wrenches and a socket set in one of those 100 peice tool kits lol now I have all kinds of pullers and timing lights, every depth and diameter gauge there is, and all kinds of other crap. I never thought I'd end up with all that stuff and know how to use it. |
#32 |
you have quite a ride brought a smile to my face. yeah my 750 was faster top end too not like yours though. looking forward to hearing the solution
#33 |
It started when I bought a new set of aluminum Ultra Gold full roller rockers because this new solid cam kept on beating my polylocks to the point where the set screw was stripped. I got the roller rockers and a nice set of polylocks to snug everything down but then the misfire started up. I checked lash to rule out the valves not closing all the way which makes the cylinder leak compression, and it's at .015" cold so I think that's where my problem is. The cam card from Comp says to set lash at .020", and bein this is my first solid cam I'm certainly no expert, but .005" less than the recommended lash is probably too tight.
#34 |
I can just hear GrumpyOldMan now, "how do you like those HIGH PERFORMANCE parts now huh??" lol its comin, just wait
#35 | |
#36 |
been trying to post not working operator error im sure... fuel coming out of vacuum port needs to be addressed maybe more than one thing is wrong but dont adjust valve train to oblivion carb is running rich not because of size
#37 | |
![]() Join Date: Dec 2013
![]() Quote:
![]() You've saved me money on haircuts because I keep pulling it out reading your engine build threads .... almost weekly ..... ![]() I've edited my signature below for your benifit !
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#38 |
I guess i have to keep my post short I have a vacuum guage mounted inside cab. also a vacuum pump is handy for testing under the hood
#39 |
I am impressed with the amount of work that you have done and hope i dont offend anyone but fuel from vacuum port needs attention maybe a holley expert would help you out. Its not the size of carb
#40 |
just sittin here waiting for parts the vacuum pump has a gauge on it the vacuumgauge in cab helps me tunemy carb and save gas. torque wrenches are a must. I noticed you invest in tools so just thought id suggest . ive got a cool multimeter has digital tach even a temp probe
#41 |
I reviewed thread and I would GUESS that when you installed valve train parts you got some debris in carb...as plugs became fouled it ran richer if you change plugs it will run better until they foul too
#42 | |
You're right on about the carb, I put a set of spark plugs in it 2 weeks ago and they looked just like the ones I pulled yesterday after only a few short trips to the store. These guys have seen me go from not being able to use a timing light to rebuilding a top end on my small block, and there's kind of an ongoing joke about how much unnecessary (and sometimes detrimental lol) wrenching I do on my truck haha I actually REPLACED HEAD GASKETS once about 4 months ago because I thought I blew one, and when I got it all back together it turned out to be one of my spark plug wires wasn't clipped in all the way on the distributor cap lol it's been fun. |
#43 |
you could pop of gauge from under dash plug line then use gauge under hood. I use gauge under dash to select step up springs in edelbrock. I use manual to select rods and jets.BTW the more gas in manifold the bigger the backfire
#44 |
they wouldnt pick on you if they didnt like you. thats what i was told about 50 years ago
#45 |
Just thought i wouldmention this fuel in oil can ruin an engine even a small amount may not show up on dipstick. and your plugs? wow pardon me but sure you are not burning oil? Oil creates bluish smokeand fuel moreblack.
#46 | |
#47 |
Anyone ever try using this calculator to figure out which size carb your vehicle needs? Last time I checked, it said my stock 350 cid needs about 340cfm
http://www.carburetion.com/calc.asp |
#48 | |
A Chevy 350 -just- maxes out a 2GV, becasue adding a 4MV is worth 5hp (250hp vs 255hp). So I figure whatever a 2GV flows, that's what a normal 350 can use.
#49 | |
#50 |
yes displacement and rpm . It sounds like your truck runs pretty well with 750. with my gearing and sm465 I only got to enjoy it getting on on ramp never did find out when it stop pulling too chicken with those drum brakes
