01-28-2012, 08:25 PM | #1 |
Best way to lower my 70 c10?
The truck is a 1970 c10, 2wd. My truck has rear leaf springs, no coils in the rear. My front end has 71 model parts making it 5 lug and disc brakes.
The truck has been lowered by the previous owner up front by heating the springs. The rear has been lowered by removing some of the leaf springs. I am interested in doing it the right way with about a 4.5/6 inch drop. What have some of you guys used, especially for the rear? Posted via Mobile Device |
01-28-2012, 08:49 PM | #2 |
Re: Best way to lower my 70 c10?
drop spindles and drop shakles
01-29-2012, 04:27 AM | #3 |
Lemme show you something!!
Drop spindles and 2 inch lowered springs in front. Lowered springs and/or flip kit in back.
Posted via Mobile Device Posted via Mobile Device
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
01-29-2012, 11:59 AM | #4 |
Thanks guys. On the rear do I just need drop shackles and then drop leaf springs? What about the spring hanger that's on the front of the leaf spring? I haven't been able to find any drop hangers. Do I leave that stock and it still works?
01-29-2012, 12:43 PM | #5 |
Happy to be here
You will get a variety of opinions, so let me throw mine in. I "always" prefer to get as much static drop as possible then lower with springs from there. That would include spindles in front, and a hanger and shackle or flip kit for the rear.
Once that is done normally I suggest cutting a half coil for 1" or a complete coil for another 2" drop. That is assuming you have a usable stock coil. Since your have been heated, throw them away and buy a 1" or 2" lowering spring.
01-29-2012, 02:16 PM | #6 | |
btw the flip kit will get you more lower then the shackles and hangers |
01-29-2012, 10:23 PM | #7 |
if i have to, I will buy new stock rear leaf springs. I just want it to be done right.
For the rear flip kit. What i seen says it lowers it 5-6 inches. Does this require the frame to be c-notched? |
01-30-2012, 03:39 AM | #8 |
I know some guys that dont notch the frame but they live with bottoming out (frame hits the axle) I think it should be since metal on metal is never a good thing and it would ride nicer with the notch
02-02-2012, 07:16 PM | #9 |
Could I just cut my coils in front and back and keep the stock spindles?
02-02-2012, 07:31 PM | #10 |
you can cut your coils. yes. Start with one coil and then go 1/2 coil at a time from there if it aint enough.
Today I ordered actual 3" drop springs for the front. My stock springs were heated and i didnt trust them, and the drop springs were only $20 more than stockers. For the rear I ordered 4" drop LEAF springs from GMCPauls. Also ordered belltech drop shocks. I am gonna see how this looks. From there I will lower with spindles in front and shackles in rear. If I had rear coil springs, it woulda been so much easier. |
02-02-2012, 07:39 PM | #11 | |
02-02-2012, 08:08 PM | #12 |
02-02-2012, 08:10 PM | #13 | |
02-02-2012, 10:08 PM | #14 |
idk. im afraid to comment on that. Ive had a bunch of little s10 trucks where we have cut the front springs and lowered the front end 4". With spindles, it helps to keep all the front suspension in line and keep the same travel as stock. But with drop springs, or cut springs. Anyone thats really good at aligning vehicles should be able to get the alignment right. My old truck had cut front coils and was 4" dropped in front and I didnt have any trouble. I dont know how much was cut tho. (1971 c10)
02-02-2012, 10:12 PM | #15 | |
02-02-2012, 10:30 PM | #16 |
m 3" springs were $120. I figure, if it isnt enough drop then I can get spindles later on to go from 1" to 2.5" more. The rear leafs were $425, and later I can get shackles to go another 1"-2" which 5-6" will be more than enough for the rear.
I am hoping 3" front and 4" rear does the trick and looks good. |
02-02-2012, 10:47 PM | #17 | |
09-11-2016, 05:31 AM | #18 |
some of these posts scare the crap out of me.
budget lowering is fine but stop cutting springs. springs are heat treated metal which have perches engineered into each side to " fit " the vehicle they were intended for. i have seen too many idiots come into my shop with a spring end snapped off and rubbing on a brake line or another suspension part because someone thought it was a good idea to use a torch to cut them. lowering springs are not that much and you can find lowering spindles on ebay for about 120 a pair if you cant afford the basics, please dont endanger your life or the lives of others on the road by trying short cuts |
09-16-2016, 10:16 PM | #19 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
