09-16-2016, 07:40 PM | #1 |
54 3600 lincoln aviator
i started a thread using a mountaineer, but when i got it home from auction the previous owner had ripped out the front drive shaft and transfer case. so i went back to auction and found something even better! a 2005 lincoln aviator with 100k miles for $1100. listen to these specs.
AWD , 4 hi & lo Heat/Ac power seats Cruise I'll keep. Along with as much of the aviator console/dash I can make work 3.73 independent 8.8 rearend 4 wheel upgraded 13" discbrakes 4.6 dohc 32 valve 302 hp coyote motor 113.7 x 60.8 front 60.9 rear Traction and tilt control with on/off switch 0-60 in 5.9 sec 89 mph that should increase a lot when it loses 1500 lbs. and cats. When I have it tuned with a k&n intake. I should get close to 400 hp. I may still want more, but I was impressed with its speed when it had the aviator cab on it. I live an 1/8th of a mile from the kennedale 1/8th drag strip. I'm looking forward to taking it there. If anyone knows any best bang for the buck upgrades for a 4.6 it would be truly appreciated! im going to sit the aviator cab on an explorer chassis so i can still sale it for enough to get my money back, I hope.
51 motor buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=718113. 54 3600 Lincoln aviator chassis swap http://67-72chevytrucks.com/vboard/s...d.php?t=717927 Last edited by Cjcolbyjack; 10-06-2016 at 04:39 AM. Reason: Changed |
09-16-2016, 07:46 PM | #2 |
Re: 54 3600 lincoln aviator
still having problems uploading pics! says i have a security token missing. i had to do it one at a time!
51 motor buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=718113. 54 3600 Lincoln aviator chassis swap http://67-72chevytrucks.com/vboard/s...d.php?t=717927 |
09-16-2016, 10:18 PM | #3 |
Pretty cool im looking forward to seeing this take shape
09-19-2016, 10:43 PM | #4 |
Sounds interesting. Independent rear is a nice plus. The track width is right on. The wheelbase will be a little shy though. An AD I believe is 116 and a regular cab long bed S10 commonly used is 117 and some change. Are you going to stretch the frame? One thought, you could always shorten the bed and the running boards. Might be easier. Or, even easier is a flatbed. I've seen a couple that look cool with flatbeds. Either way, this should be fun to watch.
09-20-2016, 07:01 PM | #5 | |
10-06-2016, 02:23 AM | #6 |
So a little progress. I couldn't be happier with what I found once the cab was off. I'll probably have to notch a little off the rear of the cab, but other then that. It's a perfect fit. So far it looks like I can make the Lincoln steering column, brakes and middle console fit. I may change the cab I use though because I plan on using a large portion of the aviator center flooring to get over the trans. I'm hoping then I can also use the shifter from the aviator.
10-06-2016, 04:25 AM | #7 |
A few more. The existing cab mounts are 45" center to center. The widest part of the chassis where the cab will sit is 43".
10-09-2016, 01:02 AM | #8 |
so I'm wondering if anyone has used the firewall along with the floor of a donor vehicle? I was originally going to use a yellow caterpillar service truck and leave it like it is patina and all. Now that I'm using an aviator chassis and everything I can use from it. I'm thinking it needs to be in a truck that has a nice paint job. Then I can also match the tan interior. I happen to have another truck that is really straight, but the floor and firewall are totally shot. I realize matching the 2 up is probably going to be a beating, but what the heck? Unless it's impossible? Measurements match up pretty close.
10-09-2016, 01:11 AM | #9 |
Ive done it.
if I had to do it again, I would be smarter about it, and move the parts around to fit the column in the proper place before welding it all, in my case the donor was narrow and the donee was wide, so the column ended up low and 6 inches offset to the center. my goal was to use the donor HVAC and pedals unmodified, which I was able to do, but I had to have the steering column moved by a guy with more skill than me.
10-09-2016, 01:12 AM | #10 |
Even though it will be time consuming to make the firewall etc to line up. Once it's done then everything else that's normally time consuming will be very easy. Like seat mounts, Ac, steering and I'll also be able to use the his and her brake and gas pedal controls. I'm wanting to go as far as cut out the dash so I can even use all the gauges etc..I like how the Ac and blower is mounted. The gear shift I would also be able to keep in the middle.
10-09-2016, 01:15 AM | #11 | |
deja vu, I remember thinking exactly that same thing. it didnt work that way for me but hey! your hill of beans is probably completely different from my hill of beans. keep posting pictures!
10-09-2016, 01:15 AM | #12 | |
10-09-2016, 04:05 PM | #13 |
Subscribed! I've been considering this (2wd though) vs S-10 vs original frame with ifs and 4 bar rear.
JK |
10-09-2016, 05:41 PM | #14 |
Colby ..there's a burb build on here that's morphed with a envoy that's along the same lines as what joedoh did and what your doing...here it is..http://67-72chevytrucks.com/vboard/s...light=trailvoy
10-09-2016, 09:40 PM | #15 |
Thank you so much! I'm liking this idea more and more!
10-10-2016, 10:44 AM | #16 |
I'm just glad to be here!
I saw your link in your sig from another thread. This one looks interesting. I think I will follow along!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
10-10-2016, 11:26 AM | #17 |
I think you will be lightyears ahead if you move the steering/pedal mount section of the firewall to where it fits the 54 best!
10-10-2016, 07:38 PM | #18 |
Exactly what do you mean Joe? My plan is to remount the aviator floor, steering and brakes back on the chassis then see where it has to be connected to the ad cab and still have the front wheels centered in the fenders. Thanks for the help!!
10-10-2016, 10:25 PM | #19 |
yeah, thats how I did mine and the steering column was in completely the wrong spot, and the pedals were way to the right too. I had to move everything around which cost a lot. if I hadnt been such a dummy, I would have cut that part of the firewall out and moved the whole section where it fit better then trimmed it back in.
where I see your potential problem is with seating position between the two, the aviator you sit pretty close to the floor and have a deep firewall for your legs and feet. the AD is way more upright, if you just weld in the firewall, the seat mounts might be out the back of the cab and the steering column angle will have it in your crotch. but if you separate that section of the firewall and move it up, steering shafts and joints will correct the misalignment and the steering wheel will be in the right spot. you may also need a stand for the seats to keep you off the floor. it may weld in and be fine. I am only talking about the problem I had with mine as a potential snag for you. better to be aware of it up front and not have it, than weld it solid and have to redo it it like I did. also, I lined up the firewalls and welded them together, then moved the body mounts back to get the wheel in the right spot. like I said, the footwell on the aviator is short in height and deep in length, but opposite for the aviator. just something to be aware of!
10-12-2016, 12:04 AM | #20 |
That's a very good point I haven't thought about. I was thinking I may have to weld a 1x4 angle on top of the aviator firewall to push it forward. Regardless now that you told me about moving that foot section. I have no doubt I can make it work. Thank you! You've given me a lot to think about and I know you have prevented future headaches. I'll be getting into it real soon.
10-12-2016, 12:07 AM | #21 |
So far so good
10-12-2016, 12:11 AM | #22 |
Well thank you! It's nice to have a fellow Aggie come along! Gig em!
10-12-2016, 09:09 AM | #23 |
Whoop!
10-12-2016, 01:14 PM | #24 |
Where did THAT bolt go?
I like where this is going.....
The Swiss Car Club......A drinking club with a car problem.... |
10-18-2016, 11:51 PM | #25 |
So far so good. The front of the fire wall lines up within an inch. The bottom angle is within 6 "s. I'm having problems getting the floor and the cab lined up. It's just doesn't look right when I set the cab floor perfectly level to the aviator floor. I'm using the aviator cab mounts. So I guess it would make since to have the floor welding to the cab even all the way to the back with no angle?
