Old 10-14-2016, 07:18 PM   #251
Chevy Apache
Re: Ian's Tennessee Honey '64 Short Box Step-side - England
That tin worm gets every we're don't know what I'm gonna find when I start mine.
Great progress
Chevy Apache is offline   Reply With Quote
Old 10-15-2016, 11:26 AM   #252
ibrown50
ibrown50's Avatar
Great progress
Thanks Pete, you're absolutely right, here are a couple of unexpected ones, I couldn't find anyone who did repops and my local breakers didn't have any either
This bracket bolts to the top of the fender and actually looked great until I hit it with a wire brush,
nothing else for it, I had to make one.
The tin worm in the L bracket that holds the fender seal was a little easier to spot
had to make one of these too
Thing is they're not flat, but luckily for me the one part that hadn't completely disintergrated was the shaped part, which gave me something to use as a pattern.
Came out Ok in the end
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 10-15-2016, 01:55 PM   #253
Chevy Apache
I had the same with my rear fenders along the bottom edges,
I did fix them but there is some filler in them so didn't strip them all the way back until I rebuild the old girl fab work looks good i am sure I will be doing
Some of that lol
Old 10-15-2016, 07:03 PM   #254
65sub
65sub's Avatar
Nice job fabricating those parts Ian. Probably fit better than repops and cost you less
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 10-19-2016, 01:26 PM   #255
ibrown50
ibrown50's Avatar
Thanks Dale
Before I refit the fender I'll have to fit fresh seals. The original seals are stapled in place. I discovered that the factory staples have exactly the same pitch as T50 staples that you would use for upholstery DIT and the like. I don't have a staple gun man enough to punch through steel, but I had a cunning plan
I glued the new rubber seals to the steel mounting plates with a contact adhesive (I would not recomend this as it reacts with the paint ) Luckily it's hidden under the seal
Then using the original staple holes ran a 1/16" drill through the new rubber seal.
Name:  Fender seal2.jpg
After that it was a simple job to push some new staples throught both steel and rubber and clench them over with a paralell punch.
Name:  Fender seal3.jpg
Name:  Fender seal4.jpg
Before and after
Name:  Fender seal5.jpg
Old 10-19-2016, 02:03 PM   #256
ibrown50
ibrown50's Avatar
I could find a match for the original clips to mount the fender seal here in the UK so I used these "fir tree" clips.
Name:  fitted seal clips.jpg
Because they're a paralell clip you have to enlarge the holes on the seal bracket to the same size as the ones in the fender support (from 5/16" to 3/8")
They're a tight fit so you'll need a mallet to tap them in
And they're plastic so no rust issues
Name:  fitted seal 1.jpg
Old 12-03-2016, 03:48 AM   #257
ibrown50
ibrown50's Avatar
A quick progress update, (well probably about 4 updates back to back )
I have now finished the passenger side floor repairs so while painting the fender seal bracket I gave it a quick coat of body colour.
I trial fitted the fender which still fits well, before beginning the door repairs.
First job on the door was the rear corner, the blasting revealed a couple of holes but the door seams were good so I only removed the rusted area preserving as much of the original door (and door profile) as possible.
Name:  rear corner 0.jpg
Name:  rear corner 1.jpg
Name:  Rear corner 5.jpg
Old 12-03-2016, 03:54 AM   #258
ibrown50
ibrown50's Avatar
The front skin needed a small repair too
Name:  Rear Corner 3.jpg
Name:  Rear corner 4.jpg
The front corner proved to be a little worse, with the rust extending into the hinge area and beyond the area covered by the repair panel.
Name:  Front corner0.jpg
Name:  Front corner1.jpg
I had a full door bottom but decided to only use a small section as the rest of the door bottom is in good shape.
Name:  Front corner2.jpg
Old 12-03-2016, 04:00 AM   #259
ibrown50
ibrown50's Avatar
I made the upper section which turned out ok.
Name:  Front corner5.jpg
Name:  Front corner3.jpg
Name:  Front corner4.jpg
Old 12-03-2016, 04:05 AM   #260
ibrown50
ibrown50's Avatar
The next job was the speaker hole, Don had given Rian a section from one of his old doors to use as a repair panel luckily for me (thank you gentlemen) the panel came with the door.
Name:  Speaker hole1.jpg
I have to say getting it lined up was just about the most “fiddly” job I’ve ever done
Name:  Spearker hole 2.jpg
Name:  Speaker hole 3.jpg
It’s still not finished but this is what it looks like at the moment,
Name:  Speaker hole 4.jpg
Old 12-03-2016, 05:33 AM   #261
uk54
Ian, I have to admire your skills and problem solving solutions when parts just are'nt available off the shelf
uk54 is offline   Reply With Quote
Old 12-03-2016, 07:21 AM   #262
Grizz1963
Grizz1963's Avatar
Just taking my rear brakes apart. First time on the truck in a while.
That is a massive amount of time and progress Ian.
Well done.
I still have a hole to correct on my drivers door, and suspect I will find as much rust and damage to repair. I know my rear bed panel has up to 10mm of filler......
Really good to speak with you yesterday as well.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 12-03-2016, 07:23 AM   #263
Ta2Don
Ta2Don's Avatar
Great work mate! Glad I could be a contributor even in a roundabout way...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 12-03-2016, 06:25 PM   #264
Chevy Apache
Looking good Ian lots of progress dreading what I will find when I pull mine apart got some holes in the same places
Old 12-03-2016, 06:44 PM   #265
MacQuigley
Nice work Ian. Your getting there.
Beginning to wish id done what your doing rather than take the easy way and reksin and whole bottoms. May have needed less filling and sanding!!!
MacQuigley is offline   Reply With Quote
Old 12-04-2016, 05:07 AM   #266
ibrown50
ibrown50's Avatar
Thanks Michael, I still need to check out your new truck was planning a ride over with Paul sometime soon
Well done.
Thanks Rian
Thanks Don and I've still got the section of door skin to fit too, stay tuned.........
Thanks Pete, hopefully you won't find as much as I have, you would not believe some of the "repairs" I have found
Thanks Bill, I still have a fair bit of filling and sanding to look forward too, I've tried all different sorts of filler and tools but it's hard work no matter what you do
Old 12-12-2016, 07:46 PM   #267
mjh1965
mjh1965's Avatar
Nice job on the doors Ian . The floor looks great . You'll have it back on the road soon at this rate .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 12-30-2016, 04:59 PM   #268
ibrown50
ibrown50's Avatar
The following post is definitely the most pictures for the least amount of time spent on a job I have posted so far
I am still doing repairs to the passenger door, one of the little jobs that needed doing was to replace the captive nuts that hold the inner door panel in place. A common fault on our trucks, some of the screws had rusted in place and had to be drilled out to remove the panel.
Now your probably thinking 1/4" x 20 unc captive nuts.... no big deal, well in Europe they are a lot less easily available than you may think, we're all metric over here .....(I blame the French it's all their fault )
This whole job took 20 minutes start to finish and was done with stuff I had lying around so cost $0.00.
I started with a piece of 1" x 1/4" flat stock marked at 3/8" and centre punched,
Drilled out to 0.2"
I then ground a step on each side (using a 24 grit disc) leaving a 3/8 raised section down the centre
and then cut it into 3/8 "strips"
Old 12-30-2016, 05:02 PM   #269
ibrown50
ibrown50's Avatar
these were then tapped to 1/4" x 20
I was originally going to spot weld these in place but decided JB Weld would do the job
A little dab on each end and "presto"
So 20 minutes later another job ticked of the list
Old 12-30-2016, 05:50 PM   #270
MacQuigley
Got any Spares?
Old 12-30-2016, 06:54 PM   #271
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Very clever work!
a few of mine had twisted out on disassembly, but I only needed to run a tap through them & epoxy them back into place.
Ingenuity at its finest!
Modges'66 is offline   Reply With Quote
Old 12-31-2016, 03:03 AM   #272
Grizz1963
Grizz1963's Avatar
Thanks for sharing Ian.
I had a few of mine self destruct, despite my most gentle effort
Will most certainly remember this post when I get to this point.
Old 01-08-2017, 03:43 PM   #273
ibrown50
ibrown50's Avatar
Got any Spares?
Not at the minute but I'm sure to be making some more how many do you need ?
Originally Posted by Modges'66 View Post
Very clever work!
Thank you, living in England ingenuity often = $ saved
Thanks Rian
Today I had a couple of hours of truck time, so decided to tackle something that’s been on my “to do” list for a while. It was one of those jobs that you know is just going to end up bigger than it looks. The truck had a few bubbles on the top of the passenger side B pillar, which turned out to be holes
Which turned out to be a bit of a “tin worm” infestation. Nothing else for it keep cutiing until you find good metal
I folded the inner piece first which was tacked
and then finish welded.
Welding under the gutter was tricky, I after ginding the weld to blend it into the gutter I found a couple of holes, access wearing my welding helmet was arkward so I ended finishing the welds using the position the torch, close your eyes, pull the trigger method. Please don't mix up the steps as I did once, you'll find position the torch, pull the trigger (forget to) close your eyes, will leave you blind for a good 10 minutes
Old 01-08-2017, 03:45 PM   #274
ibrown50
ibrown50's Avatar
Did the same for the outer piece, I include a few “spot weld” holes so that the finished repair will match,
I got it to here ………….and then ran out of gas
Old 01-08-2017, 04:15 PM   #275
65sub
65sub's Avatar
Looking good Ian. I love how a paint bubble ends up being a 2 inch hole by the time you find something to weld to
Dale
