#2201 |
![]() ![]() Join Date: Jul 2002
Re: Donz '65 SWB Stepper Budget Build...
Speed bumps seems to always be there to make us hit those brakes. Glad you got it rolling/running again.
#2202 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Forge ahead Don!!!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
#2203 |
Was going again... I've hit a wall, while adjusting the valves Thursday, all of a sudden the electrical system decided to go on vacation. Long story short, out of the blue, when the ignition switch is switched to the on position from off, the voltage at the ignition switch drops to 5 volts. Battery is good, but will take to work tomorrow to test. Starter, wiring, and ignition switch are all new. Battery is grounded to the motor, frame and engine are grounded to frame. Bed is grounded to frame as well. Help! Any ideas and suggestions are welcome...
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#2204 |
Don't let the new parts fool ya. I had a set of 2 week old Napa spark plug wires fool me and a bunch of local rodders. The "new" part makes you take it out of the equation.
Chris
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
#2205 |
Ahhhh, ignition gremlins.
That was supposed to be my excuse!!!! LOL! This problem is the only thing stopping me from going to Clem's!!!!
#2206 |
![]() Join Date: Jul 2015
Something is shorted or grounding out that is only on when the ignition is on, disconnect one thing at a time until the voltage gets better.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881 1972 C-10 SWB 1962 3/4 ton LWB 2011 GMC Sierra LML Z71 crewcab shortbed |
#2207 |
Thanx for the input guyz... Well today was productive and the stepper is once again Alive and kicking.
![]() ![]() I replaced both battery cables and re-routed the ground cable to the frame... I then checkedthe voltage at the switch, full battery voltage when switched on! ![]() With the electrical system back in operation it was time to adjust the passenger side valves... that job done.... it was time for the Stepper's Maiden Voyage into town... ![]() ![]() Back in 2012, shortly after getting the Stepper and engine, I bought a serpentine belt setup complete with Brackets, P/S pump, Alternator, A/C compressor and Water pump for $100... the P/S pump started leaking shortly after getting the engine running, but thanx to Lucas P/S stop leak, that leak has stopped. The Alternator was replaced after the new wiring harness was installed, and at that time the water pump was hanging in there still... So tomorrow after work a new water pump will be installed... ![]() Later guyz... Pics comming soon!
#2208 | |
#2209 |
Replaced defunct water pump yesterday after work and drove the Stepper to work this morning...
![]() ![]() Rian (GRIZZ) showed up a little after 1, on his way to Clem's... ![]() ![]() Here's a pic of Rian in the Stepper... ![]() ![]() He arrived bearing gifts, as well as retrieving a clock for his mate Craig in the UK... Craig is building a '48 Chevy Fleetmaster and found this clock on eBay... it arrived a week or so back and Rian is packing it back to Craig... ![]() Here's a coffe mug and tea, and a killer mug for yours truly... ![]() ![]() ![]() A bag for my Lovely bride, affectionately known as Mrs. Boss! ![]() Here's the clock upon it's arrival here in Searcy... ![]() Following Rian's departure, after a lunch hour spent visiting a Walmart Neighborhood Market, and grabbing a Chicago Dog from Sonic... ![]() A new friend arrived at work with his '64... sporting the wheels I sold him recently... They were the ones originally on the stepper when purchased... He needed 6 lug wheels and I didn't... ![]() ![]() ![]() Will be looking forward to updates and pics following Clem's bash this year... ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 10-12-2016 at 08:18 PM. Reason: spelling |
#2210 |
![]() Join Date: Mar 2013
Awesome update brotha! Good feeling driving them for the first time.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#2211 |
Thanx Brotha!!!
![]() Yes, Awesome to finally drive for more than a mile or so up and down a gravel road... ![]() Today's a bit bittersweet for me... Wishing' I was waking up about 3 hours NW of here for Clem's bash, but Life stepped in and changed those plans... ![]() Instead, I'll drive the Stepper about 20 wiles west and put it in a Car show a friend is involved with... ![]() ![]() Awhile back, MarkeB01 offered up some items, and I was fortunate enough to be the recipient of a few items... ![]() As you can see in this pic, the mirror originally in the Stepper when purchased was discolored on the face and distracting when using... ![]() ![]() Holes drilled and ready to mount... ![]() Mounted and you van see the Number plate taped in the back window... ![]() ![]() ![]() Finally, a pic of the Vintage Number Plate that I got with the Stepper... ![]() ![]() Quick question... What's the easiest way to remove the mirror button that's glued to the windshield??? Enjoy your day Guyz and Galz!!! ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 10-15-2016 at 06:51 AM. Reason: Add ? |
#2212 |
That's interesting Don. My truck has the roof mounted rearview mirror. As far as I can tell it came from the factory that way.
I love the pic of Rian in your truck. I myself would frame that picture. Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
#2213 |
And I welded up the holes in my interior to use a newer style windshield mounted mirror...
#2214 | |
Not sure I would frame that pic but truck looks good on its own. Was good to see Don and even nicer sitting in the truck.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#2215 |
Thanx Bret and Mike, as for the mirror, the '60 has the roof mounted and I'm not sure what year they changed over to the windshield mounted... I've always liked the roof mounted, so that's the direction I chose...
![]() ![]() Unfortunately I was unable to make it to Clem's this year, but I did attend a Show about 20 miles west of home and enjoyed taking the Stepper and hanging around gearheadz all day... ![]() Here's a shot of the Stepper and I on the way to the show... ![]() The Stepper resting... ![]() My friend Tony's Rat 62 with a 63 cab on the left in the pic, He's seen in the following pic with the owner of the red '63... ![]() The Red '63 in the following pics won the Truck class, well deserved. The owner, wearing the straw hat in the first pic, has had this truck since new. Not sure how long ago, but the truck has been restored... ![]() ![]() ![]() ![]() This morning we rolled the '60 out into the driveway so I could load up some scrap for the haul into town... ![]() Here's the trailer load... came out to just shy of 1900 Lbs... ![]()
#2216 |
Glad to see the Stepper on the road. We missed you at Clems bro. Maybe next year.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
#2217 |
![]() Join Date: Oct 2012
Glad you got it on the road Don. I drove mine about 1/2 mile up the road Sunday after noon. Still a little bit to do but almost there. Your truck looks great
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
#2218 |
Rollin' Old Skool
Such a bummer that you couldn't make Clem's after all that hard work, but I'm glad you were able to enjoy attending the other show. That red '63 looks nice, but I wonder how the engine ended up blue when everything else looks pretty original.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#2219 |
Bummer you couldn't make it to Clem's brotha. But hey, ya did yer best and have made some super progress.
#2220 |
I'm glad to see you rolling around.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#2221 |
Thanx Guyz!!! Good to be driving and sorting out the issues that are deciding to arise...
![]() Did some trading over the past week and ended up with a set of CPP Rear lowering springs... ![]() ![]() Today I loaded up Jojo and took a ride into town to shoot a few pics of the Stepper at it's former home... The truck was originally purchased by the local school and worked for it's keep until 1978. Ironically, the years it was in school so was I... ![]() ![]() On to the pics... ![]() ![]() JoJo waiting for more ride time... ![]() ![]() Still lotsa little things to address... Never-ending... ![]() Laterz... ![]()
#2222 |
Got her on the road photo shoot to boot. Congrats big time. Looks great.
#2223 |
Nice one Don.
Well done.
#2224 |
Way to go Bro. and JoJo.
My stepper is getting way to much time on the lift with those many little and not so little things.
Vince Galatians 6:14 62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086 "If it's too loud, you're too old" ![]() |
#2225 |
Looking good brother
Tags |
65 swb, c10, step side, tattoo |
