Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-28-2016, 07:06 PM   #1
68 SWB
68 SWB's Avatar
Restore/ hot rod an air compressor?
So I've got parts from two different air compressors that I thought about building a good one out of. The pump I have was from a working compressor that the motor went out on. The "complete" compressor I have the pump is bad on and maybe the motor also, but the tank is good. The rpms for the motor on the complete compressor are too high for the good pump anyhow.
So what do you guys think... new motor, rebuild pump, cleanup and custom paint the tank? We build custom trucks, why not a compressor?
Edit: not sure why attaching the pictures rotated them.
68 SWB is offline   Reply With Quote
Old 10-28-2016, 10:14 PM   #2
truckster
truckster's Avatar
Re: Restore/ hot rod an air compressor?
I would just say you need to do a good inspection of the tank. That's a lot of force that will let go all at once if it fails.
truckster is online now   Reply With Quote
Old 10-29-2016, 02:03 AM   #3
franken
Match the motor speed or pulley ratio to the pump and they'll be happy (~1k) pump RPM is good. Then look at tank pressure. 3540 motors tend to hawk up a lung.
Old 10-29-2016, 09:33 AM   #4
Warrens69GMC
Warrens69GMC's Avatar
The green pump appears to be a Kellogg American pump. I would use that pump for sure.
Old 10-29-2016, 12:03 PM   #5
68 SWB
68 SWB's Avatar
The old motor for that pump was a 1740 rpm with a 1 1/8 inch shaft. I still have it so I'll have to get the measurements from it to figure out what to get.
Old 10-29-2016, 01:08 PM   #6
BIGglaSS
BIGglaSS's Avatar
I'm not quite convinced it is a Kellogg, I need better pictures of the green pump. I can't quite identify it from that picture. The old pumps are great. They can be rebuilt many times, and simple/easy to work on. I would use the old pump, and put it on the red tank. Add a new Baldor motor, and your hotrod compressor will outrun any import from one of the home-improvement stores.
Here is a chart of Kellogg pumps. http://aircompeq.com/ka.htm
BIGglaSS is offline   Reply With Quote
Old 10-29-2016, 03:31 PM   #7
68 SWB
68 SWB's Avatar
Let me know what pictures you need. I swear it was a Rol-air but can't remember.
Old 10-29-2016, 04:41 PM   #8
BIGglaSS
BIGglaSS's Avatar
Hey neighbor, just noticed your location. I'm in Eagle... I don't know anything about Rol-air pumps, I just wanted to point out that it wasn't a Kellogg. Either way, I'd rebuild an old quality pump over a new import any day! Got a good front and side picture? I was wondering if it was a single cylinder or a two-stage pump. If you have 240v power, a true 2-stage 5hp pump in the 15-20 cfm range is the best hot rod compressor for a home shop. If that is a 1 stage, less than 10 cfm pump, I wouldn't bother rebuilding it unless it is just for filling tires or you only had 120v power.
Slightly off topic, the best "old" pumps out there to look for: Champion, Kellogg, Quincy, or Saylor-Bealle. They all make "real" CFM, run quiet, and are rebuildable for many generations.
Old 10-29-2016, 06:11 PM   #9
68 SWB
68 SWB's Avatar
I just moved from Meridian to east Idaho for work, I should update that. Here are more pictures of the pump.
Old 10-29-2016, 06:12 PM   #10
68 SWB
68 SWB's Avatar
Here is another number I found on it.
Looks like maybe a Campbell Hausfeld TF pump.
Old 10-29-2016, 09:13 PM   #11
BIGglaSS
BIGglaSS's Avatar
I can't identify that pump, it is nothing I am familiar with. By the piping and cylinder, it is a two stage pump. It is definitely not a Kellogg pump, but with some similarities.
As I type this, I looked up CH TF pump. I agree this is what it is. http://www.mastertoolrepair.com/air-...p-p-26500.html
I would run this pump with no reservation. At the right RPM with a 5hp motor, it will be a REAL +/- 17 CFM compressor. Watch eBay for a 5hp Baldor 1725 rpm motor. If you are patient, you can get them brand new for under $300 shipped.
Old 10-30-2016, 01:26 AM   #12
Warrens69GMC
Sorry, I was thinking it was a 335tv but now I see its not. Looks like a good start for your compressor.
Old 10-31-2016, 08:12 PM   #13
68 SWB
68 SWB's Avatar
How about this motor?
http://www.ebay.com/itm/280843722591
Old 10-31-2016, 10:42 PM   #14
Warrens69GMC
Same one i'm watching on ebay
Old 10-31-2016, 11:01 PM   #15
68 SWB
68 SWB's Avatar
Have you looked at this model, looks like it might be a little better.
http://www.baldordirect.com/searchqu...ywords=El1410t
Old 11-01-2016, 01:04 PM   #16
BIGglaSS
BIGglaSS's Avatar
The ebay one is the one that I have. It will work just fine at half the price.
Old 11-01-2016, 02:28 PM   #17
BIGglaSS
BIGglaSS's Avatar
Here's a thread on GJ for one of those:
http://www.garagejournal.com/forum/s...d.php?t=217326
Old 11-01-2016, 05:46 PM   #18
68 SWB
68 SWB's Avatar
That's funny, I had already found that and signed up for that forum just to see the pictures. Thank you for the link.
