Old 10-24-2016, 01:44 PM   #126
Dave0
Re: Putting Camaro front in 55 second gen
Originally Posted by Rude Dude View Post
Don't forget to check if you need to add or remove shims on the cab to the cab frame mounts sometimes this affects door alignments and is often overlooked
Check! Its bolted down, the core support is too. Im not going for show car gaps anyway... I'm thinking mocking the patina thats there. One day, I may change my mind though... Lol
Another couple pics!
A good comparison from the day I drug it home, last day of March....
Dave0 is offline   Reply With Quote
Old 10-24-2016, 05:13 PM   #127
Kim57
Kim57's Avatar
Those look like typical 50s door gaps.
Takes a ton of work to get them all even.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-24-2016, 05:56 PM   #128
Dave0
Kim
I know, I want them fairly uniform. This isnt any type of show truck, maybe later down the road though...
Old 10-25-2016, 02:04 AM   #129
56hotrodred
Just took the time to look through your build again and just had to comment this time.
Serious fabrication skills all around.
Nice work!
56hotrodred is offline   Reply With Quote
Old 10-25-2016, 04:05 PM   #130
Dave0
Nice work!
Thanks!
Nothing to ground breaking, just a whole lot of planning and work... All this fits under the stock bed floor, one of my wants going into it, I wanted to keep it at stock level.
Old 11-03-2016, 04:23 PM   #131
Bobbyh68
DaveO, Thanks for the advise on the Lokar shifter. I purchased one off Evil Bay and it bolted right up, very Simple. Now I'm trying to hook up my steering shaft and need to know what u joint you used. I noticed it in your pic of the trans linkage (BLACK U JOINT). I have a GM column and firebird frontend like you.
I've got a lot of great ideas from you! thanks' IN ADVANCE.
Bobbyh68 is offline   Reply With Quote
Old 11-03-2016, 06:57 PM   #132
Dave0
Mine is a mid 70 camaro column and 70s camaro box and shaft. Do your homework, count splines and measure shaft. This one worked for me...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 11-03-2016, 07:21 PM   #133
Bobbyh68
Thanks for the education. Your the man!
Your truck is coming along great. I like checking in and seeing your progress. Your just a couple steps ahead of me.
Old 11-11-2016, 06:14 PM   #134
Dave0
Slid the frame out from under the cab today. After taking all the suspension off...Worked out pretty slick!
Getting serious now, I need to get the frame all welded up before Wed, then off to be blasted along with the cab....
Anyone recommend some camaro tubular A-arms? I dont want China junk...
Old 11-12-2016, 12:11 AM   #135
Kim57
Kim57's Avatar
I used these guys stuff on my Chevelle clip.
Very nice quality parts.
Easy to deal with and very knowledgeable.
They have different sets depending on what year Camaro you have.
http://scandc.com/new/catalog/12
These are mine.
Kim
My build thread
Old 11-17-2016, 08:13 PM   #136
Dave0
Damn, those things are pricey!
Blasted the frame, rear end and all suspension components... Frame is in the booth!
Old 11-17-2016, 09:29 PM   #137
56hotrodred
That looks great. I have just wiped my frame down once more and hope to be priming in the next couple of days. Hoping for it to warm up a bit first.
I am spraying Eastwood epoxy primer then their ceramic chassis coating.
Just about all the small parts are disassembled and ready also.
Old 11-17-2016, 10:15 PM   #138
lv2tri2
I am anxious to see this finished, good looking project
lv2tri2 is offline   Reply With Quote
Old 11-18-2016, 04:35 PM   #139
Dave0
And so it begins.... Again!
Old 11-18-2016, 06:41 PM   #140
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
Old 11-19-2016, 05:35 AM   #141
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Slick!
ChuckDriver is offline   Reply With Quote
Old 11-25-2016, 07:58 PM   #142
CMACDONALD1
CMACDONALD1's Avatar
Looks great so far!
1966 427 biscayne with a 5 spd tremec on old school torque thrusts.
1972 Cheyenne Short Bed
1958 Apache short fleet
1980 Chevy short bed
http://67-72chevytrucks.com/vboard/s...d.php?t=761005
1959 "Henry"
http://67-72chevytrucks.com/vboard/s...d.php?t=670461
1966 Biscayne
http://67-72chevytrucks.com/vboard/s...d.php?t=444419
1972 Suburban
http://67-72chevytrucks.com/vboard/s...d.php?t=478828
CMACDONALD1 is offline   Reply With Quote
Old 12-01-2016, 10:58 PM   #143
Dave0
Back at home on stands....Collecting bolts, painting brackets and bolts. LOL
Old 12-01-2016, 11:39 PM   #144
Trucker79
Trucker79's Avatar
Atta boy Dave0!!! Looks really awesome! How did you get another inch or two lower? I like the way she sits. I hope mine looks that good.
Trucker79 is offline   Reply With Quote
Old 12-02-2016, 12:44 AM   #145
Kim57
Kim57's Avatar
Looking real good.
Kim
My build thread
Old 12-02-2016, 08:47 AM   #146
Dave0
I chopped a half a coil off!
Old 12-10-2016, 11:42 PM   #147
Dave0
The only reason you need not to buy china fittings, These are both -6 an, which one would you rather have feeding your fuel lines....
Old 12-24-2016, 09:19 PM   #148
Dave0
Tank in, rear end mounted, front suspension together, spent the last 2 hours power washing the engine.... As soon as I get the oil pan modified, its going in!
Old 12-25-2016, 10:46 AM   #149
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
Old 12-25-2016, 02:42 PM   #150
ptc
ptc's Avatar
Looking really good - you are knocking this thing out!~ its goes pretty quick once you have all the parts and everything painted. I used the QA-1 front parts on my Camaro clip. Mines about where you are now too.
Keep it up!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
